Loading...
Pages: [1]   Go Down
Author Topic: New Board--PICO1TRC, 2.1"x1.65", TH, Adj Reg, RTC  (Read 201 times)
Boston, MA
Offline Offline
Edison Member
wiblocks
View Profile
WWW
Yesterday at the MIT Flea I introduced a new board -- the PICO1TRC.
The PICO1TRC is a TH kit with a 2.1" x 1,65" PCB. The kit features an
ATmega328 with the Arduino bootloader. This board has an adjustable
voltage regulator, battery backed-up real-time clock and a
0.6" x 0.6" prototyping area. The kit is priced at $20.
The datasheet contains the schematic, BOM and
assembly instructions. See http://wiblocks.luciani.org/PICO/PICO1TRC-index.html
Features
    * 2.1" x 1.65"
    * TH components,
    * Replaceable ATmega/328
    * Real-time clock with battery backup
    * 2.1mm power jack and an adjustable regulator.
       The Vcc can be trimmed from 3.3V to 5V by changing a single
       resistor. There are resistors in the kit to trim Vcc to 3.3V and 5V.
    * 0.6" x 0.6" prototyping area
    * Six pin header compatible with the FTDI TTL-232R-3V3 cable.
    * Debug LED
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Logged
Pages: [1]   Go Up
Print
Jump to:
