Topic: Help with a 1.27mm pin connection, please (Read 955 times) previous topic - next topic
.jacob
Hello,
I just picked up a SHT75 sensor from sensitron and it came on a 4 pin board with the pins spaced 1.27mm.  I want to connect each pin a 22awg wire preferrably using a connector.  Is that possible?  Can someone please help me find the appropriate connector.  I'm a bit lost...
The datasheet also says the sensor should not be soldered (1.2 on page 4), is it possible to use a connector without soldering?
The exact dimensions of the pins are on the datasheet here: http://www.sensirion.com/en/pdf/product_information/Datasheet-humidity-sensor-SHT7x.pdf
Thank you much,
Jacob
