Ok,
I've updated the zip
http://www.robotcraft.ca/webshop/download/zip/arduino-mega32-644-mod.zip file.
The update includes support for ATMega644 (in addition to ATMega32) micros.
http://www.robotcraft.ca/webshop/download/zip/arduino-mega32-644-modded-public.zip is still available but doesn't include support for ATMega644.
You will also need to add the following configuration information to your $ARDUINO_HOME/hardware/boards.txt file, so you could select ATMega32 and ATMega644 as target microprocessors from your Arduino IDE.
atmega32.name=ATmega32
atmega32.upload.protocol=stk500
atmega32.upload.maximum_size=14336
atmega32.upload.speed=19200
atmega32.bootloader.low_fuses=0xff
atmega32.bootloader.high_fuses=0xdd
atmega32.bootloader.extended_fuses=0x00
atmega32.bootloader.path=atmega8
atmega32.bootloader.file=ATmegaBOOT.hex
atmega32.bootloader.unlock_bits=0x3F
atmega32.bootloader.lock_bits=0x0F
atmega32.build.mcu=atmega32
atmega32.build.f_cpu=8000000L
atmega32.build.core=arduino
atmega644.name=ATmega644
atmega644.upload.protocol=stk500
atmega644.upload.maximum_size=14336
atmega644.upload.speed=19200
atmega644.bootloader.low_fuses=0xff
atmega644.bootloader.high_fuses=0xdd
atmega644.bootloader.extended_fuses=0x00
atmega644.bootloader.path=atmega8
atmega644.bootloader.file=ATmegaBOOT.hex
atmega644.bootloader.unlock_bits=0x3F
atmega644.bootloader.lock_bits=0x0F
atmega644.build.mcu=atmega644
atmega644.build.f_cpu=8000000L
atmega644.build.core=arduino
You may need to adjust atmega32.build.f_cpu/atmega644.build.f_cpu lines and specify appropriate clock speed that micro is running at. Mine was running at 8MHz.
The IDE uploading functionality is not working since the bootloader wasn't ported yet. You will need to use ISP hardware to load up your HEX files onto 32/644 megas.
