Topic: Arduino Ethernet Shield (Read 25654 times) previous topic - next topic
bandito66
I've same problem with an arduino clone bought on this shop : http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=290344603702&ssPageName=STRK:MEWNX:IT#ht_695wt_1165 (ekitszone).
Using a LCD/Keypad shield, when I use it powered by USB, screen il quite unreadable. Using  power supply, no problem, everything works fine.
Using a genuine arduino, everything works fine on USB and power supply.
Razo
Thanks :-) Used this Simple Server for my 2nd Arduino project (1st was the blink sketch)
If you have never really coded before the code is a bit off putting, and other solutions might be better for you. but if you know your way around its not a too bad system.
There are bugs to iron out, but its not too bad. Atm I just put some ajax into the system and killing a few bugs.
But not bad for the few £ it cost to put together.
Using the system for some basic monitoring system and switches/controll units around the house.
