Loading...
Pages: [1]   Go Down
Author Topic: Aeroquad without aeroquad shield possible?  (Read 715 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Im planning to start an aeroquad project based on the build list and stuff here: http://www.aeroquad.com/content.php?114
However, i just found out that they do not stock the aeroquad shield at the moment due to development of a newer version of it.
I am wondering if it is possible to connect the 5DOF IMU and Gyro to the duemilanove using another method.
Help greatly appreciated.
Thanks
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Yes - they even mention on the site using a prototyping shield instead; if you look at the schematice for the aeroquad shield:
http://aeroquad.googlecode.com/svn/trunk/Documentation/Shield/AeroQuad_v1.7/AeroQuad_v17_Schematic.pdf
You will see it is pretty much nothing more than a breakout board; you should be able to set up something similar with a prototyping shield (or no shield at all!)...
 smiley
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
You could try building a baronpilot: http://www.elenafrancesco.org/arduino/baronpilot/
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for the input guys. But as a beginner, i dont really understand what a breakout board does. I understand that it is a board that stacks on top of the arduino and allows u to connect the various sensors more easily and neatly.
So, does using jumper wires to the respective pinholes mean that i can get rid of the shield entirely?
Thanks again.
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Let me clear something up: Technically, a breakout board is a board designed to route signal and other lines in a manner that makes the underlying system easier to interface with; in this case, the board groups things together for the sensors. It doesn't necessarily stack on top of the Arduino (ie, as a shield); though in this case it does. A breakout board can also be used, for instance, to allow you to easily use a part that might be otherwise difficult to use, especially in prototyping; for instance, an SMT IC or similar, to bring the tightly spaced pins out to wider spaced 0.1 inch pins, to fit in a breadboard, or be more easily soldered to. If you notice, by those definitions - the entire Arduino board is a "breakout" board (for the ATMega).
Quote
Yes. In the case of this board, you should follow the schematic given for it for the hookup (ie, there were a ton of capacitors on the analog IO lines for some of the sensors - they are probably needed for noise supression, etc - so they should be included).
 smiley
« Last Edit: August 26, 2010, 10:29:47 am by keeper63@cox.net » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks alot cr0sh. That answered my question. Alright i will try to look into the schematics and figure it out from there.
Logged
Pages: [1]   Go Up
Print
Jump to:
