Topic: uhttpd config, index file, php vs. html (Read 14211 times) previous topic - next topic
5a2v0
Hi, in my Yun I installed PHP and it work fine..
Now I have a question:
If I put in the /www dir a index.php file and then go to http://my.yun.ip , the webserver redirects me to: http://my.yun.ipcgi-bin/luci/webpanel/homepage because in the /www dir there is a index.html file that does the redirect ..
How can I set index.php priority instead of html files ?
I tried to set in the /etc/config/uhttpd file the "option index_page" or "option index_file" as described here: http://wiki.openwrt.org/doc/uci/uhttpd.
After saving changes, i always did a utttpd restart but no one solution worked...
sonnyyu
#1
May 23, 2014, 02:53 pm Last Edit: May 23, 2014, 04:38 pm by sonnyyu Reason: 1
The output of
Code: [Select]
uci show uhttpd
if you are missing:
Code: [Select]
uhttpd.main.index_page=index.php
then need run:
Code: [Select]
uci set uhttpd.main.index_page=index.php
uci commit
/etc/init.d/uhttpd restart
empty cache of browser, at chrome clean the History, restart browser and visit http://ip_address_yun/.
5a2v0
thanks for the reply... the command
Quote
uci show uhttpd
didn't display the index_page=index.php...
I tried again to add the line:
Code: [Select]
option index_page       index.php
to the config and restarted it....now it works... (maybe before i did some mistake!)
now the command output is:
Code: [Select]
5a2v0
Hi, another time here because my old problem become my new problem...the situation:
/www folder is like original, with the index.html that works properly with the yun control page (I can connect using http://yun.ip/)
/www/keystore_manager_example/ have a index.html that doesn't work (I can't connect using http://yun.ip/keystore_manager_example but I can by adding /index.html)
/www/sd/ have a index.php that works properly (I can connect using http://yun.ip/sd/)
the uhttpd config:
Code: [Select]
        # Index file to use for directories, e.g. add index.php when using php
        list index_page         'index.html'
        list index_page         'index.php'
the command uci show uhttpd tells me:
Code: [Select]
uhttpd.main.index_page=index.html index.php
Why the index.html in the dir keystore_manager_example doesn't work ?
federicofissore
index_page is not a "list" option, so you can set only one. Easy trick is to always use index.html and it redirect to index.php when appropriate
federicofissore
No, I've played and googled around a bit, but seems like both index_file and index_page do not work as lists, so you can only specify one
federicofissore
#6
Oct 29, 2014, 01:26 pm Last Edit: Oct 29, 2014, 01:27 pm by Federico Fissore
OK I was able to achieve it by manually editing /etc/config/uhttpd, adding
Code: [Select]
list index_page index.htm index.html index.php
Notice the absence of both quotes and double quotes
However, this makes uci break with
Code: [Select]
uci: Parse error (too many arguments) at line 15, byte 37
so think twice about using it: it looks like uhttpd supports something uci doesn't :)
5a2v0
From here: link
I read:
Code: [Select]
index_file file name no index.html, index.htm, default.html, default.htm Index file to use for directories, e.g. add index.php when using php
index_page file name no index.html Index file to use for directories, e.g. add index.php when using php (last, 20131015, replace index_file ?) should be noted: list index_page "index.html"
and if I put in my config file:
Code: [Select]
        option index_page         'index.html'
        option index_page         'index.php'
Code: [Select]
infact i have a index.php in /sd that works! and the index.html in the /www that works also...the only one that doesn't work is the index.html in the /keystore_manager_example dir
sonnyyu
#8
Oct 29, 2014, 06:51 pm Last Edit: Oct 29, 2014, 06:53 pm by sonnyyu
To support both index.html and index.php same time:
Code: [Select]
uci set uhttpd.main.index_page='index.php index.html'
uci commit
Code: [Select]
uci show uhttpd
Code: [Select]
nano /etc/config/uhttpd
option index_page 'index.html index.php'
The order of index.html index.php  is very important, the last one has high high priority.
"index.html index.php" ; index.php  shows first, if index.php is missing then shows index.html.
"index.php index.html"; index.html shows first.
5a2v0
#9
Oct 30, 2014, 12:30 pm Last Edit: Oct 30, 2014, 12:31 pm by 5a2v0
@sonnyyu tried right now ! Same result...
http://yun.ip/ ==> open automatically http://yun.ip/cgi-bin/luci/webpanel/homepage
http://yun.ip/sd/ ==> open automatically the php files http://yun.ip/sd/index.php
but
http://yun.ip/keystore_manager_example/ ==> DOESN'T open the index.html file !! It returns the error "No such file or directory" ... I have to manually write:
http://yun.ip/keystore_manager_example/index.html for open the page !!!
sonnyyu
It works for me.
after backup your own data,
Code: [Select]
/usr/bin/reset-to-factory-anyway
will bring your Yun  back to factory default. then retry it.
federicofissore
Ahh that what brought to think it wasn't working: I thought first had higher priority. Clear now, even if counter intuitive
vitas76
#12
Nov 20, 2016, 09:20 am Last Edit: Nov 20, 2016, 02:17 pm by vitas76
Maybe too late but for everyone, I have The same problem and fix it.
If you need in webserver "uhttpd" run together html and php index ;)
Here is oficial man: https://wiki.openwrt.org/doc/uci/uhttpd#using_php5
Speed tutorial:
  • Must install PHP5:
    opkg update
    opkg install php5 php5-cgi
  • Must edit uhttpd config file
    vi /etc/config/uhttpd
    now must add 3 rows (lines)[without number & colon]:
    1:list interpreter '.php=/usr/bin/php-cgi'
    2:list index_page 'index.html, default.html, index.php'
    3:option index_file 'index.html, default.html, index.php'
  • And now just only restart uhttpd server:
  • If you want can you control it:
    uci show uhttpd
When you will see in uci list this 3 lines as:
uhttpd.main.interpreter='.php=/usr/bin/php-cgi'
uhttpd.main.index_page='index.html, default.html, index.php'
uhttpd.main.index_file='index.html, default.html, index.php'
Quote
You're a winner :)
