Topic: Designing shields (Read 4384 times) previous topic - next topic
Henry_Best
Many times I see the sort of question: "How do I get shield X to work with shield Y when they both use pin Z?"
Surely it's not beyond the wit of shield designers to give the user a choice of pins (using, for example, configurable jumpers) to avoid conflicts. Shield designers seem to be of the Henry Ford variety..."You can have any pin arrangement you want, as long as it's the one I choose!"
I realise that there may be space constraints and that some shields require PWM and/or analogue pins that cannot be changed, but purely digital inputs/outputs could use almost any of the other pins. If there were simply pads that the user could solder jumpers to, it would not increase the cost of the shield.
The inclusion of the possibility to easily reconfigure the input/output pins would increase the versatility of the shield and, therefore, increase it's sales potential.
What brought this to mind is that I'm designing a shield that uses 6 purely digital inputs/outputs and currently I'm using pins A0 to A5 (probably the least conflicted pins). But what if the user needs his analogue pins for something else?
runaway_pancake
#1
May 27, 2014, 03:35 am Last Edit: May 27, 2014, 03:43 am by Runaway Pancake Reason: 1
Then there are those who cannot or will not solder.
No matter what, it just won't be universal enough.
It'll always be something.
> > > I've modified shields, too
http://forum.arduino.cc/index.php?topic=165923.msg1240333#msg1240333
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Henry_Best
Yes, but it's not a particularly difficult skill to acquire.
Quote
Agreed, but some versatility is better than none.
Quote
Yes, but why not mitigate where we can?
Quote
So have I.   :0 :0
CrossRoads
So why not make a shield with male pins, and use jumper wires to select what's connected to what?
No soldering needed then.
Does take up more room tho.
Henry_Best
Thanks for that suggestion, XRoads. I'll see if I've enough space to fit them on.
luisilva
I like the idea. But I will leave a default arrangement. If the user don't want that arrangement can cut a small bridge and solder a wire (or something else) between 2 holes, for example.
luisilva
Thanks woozle. I didn't know this.
