Topic: About this resettable fuse, what are the bents for (Read 1 time) previous topic - next topic
liuzengqiang
Oct 23, 2010, 02:09 am Last Edit: Oct 23, 2010, 02:10 am by liuzengqiang Reason: 1
What are the bents for?
http://www.alliedelec.com/search/productdetail.aspx?SKU=4200063
I have a few of these. I don't know what to do with the bents. Are they just visual marks so they're not confused with caps?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
cmiyc
Probably to keep them away from the PCB.
As the current approaches (or exceeds) their cut-off, they will physically expand due to heat breaking the circuit.  By making sure the element is away from the PCB, it won't have a heat-sink effect.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
RuggedCircuits
I think they're a form of retention to keep the part in place while it's being soldered.
The Quick Shield: breakout all 28 pins to quick-connect terminals
Osgeld
I have caps that look the same, it just allows you to "snap" them into a board
though I could be totally wrong
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
retrolefty
They put those there to make the part look cooler and mysterious.
Lefty
TheLaw
#5
Oct 23, 2010, 06:25 am Last Edit: Oct 23, 2010, 06:33 am by TheLaw Reason: 1
I believe it is what osleg said.Not sure but its common on a lot of through hole parts, so it's not to differentiate it from a cap. There are plenty of caps with these bends in them.
liuzengqiang
Thanks. I see. Well, in my case I forced it into a couple of holes for a diode. :)
