Topic: Arduino-izing the AVR Butterfly (Read 23042 times) previous topic - next topic
Brokentoaster
I've removed the two transistors and soldered directly to the pads on the butterfly before, but unless you've done a lot of surface mount work probably not for the faint hearted.
http://www.flickr.com/photos/nicklott/338334971/
also check this link it is discussed here i think. http://dorkbotpdx.org/blog/feurig/dorkbotpdx_arduino_programmer
creatrope
Been a long time since I was on this thread, but I just broke out the butterflies.  I don't suppose anyone is hosting the latest and great arduino butterfly bootloader HEX files?
here's the most recent one I found, but it doesn't sound like he's picked up all your changes (or even using the same SVN tree)
http://stuffthingsandjunk.blogspot.com/2008/11/arduino-for-butterfly.html
-creatrope
Brokentoaster
#92
Mar 23, 2010, 05:47 pm Last Edit: Mar 23, 2010, 05:55 pm by Brokentoaster Reason: 1
You should be able to use the standard butterfly bootloader.
so long as you setup the arduino software boards.txt file with the following entry
Code: [Select]
bfly.name=Butterfly
bfly.upload.protocol=butterfly
bfly.upload.maximum_size=14336
bfly.upload.speed=19200
bfly.bootloader.low_fuses=0xE2
bfly.bootloader.high_fuses=0x98
bfly.bootloader.extended_fuses=0xFF
bfly.bootloader.path=butterfly
bfly.bootloader.file=bf_boot.hex
bfly.bootloader.unlock_bits=0x3F
bfly.bootloader.lock_bits=0x0F
bfly.build.mcu=atmega169
bfly.build.f_cpu=8000000L
bfly.build.core=butterfly
Also check out this link http://code.google.com/p/butteruino/
creatrope
#93
Mar 26, 2010, 02:29 am Last Edit: Mar 26, 2010, 02:29 am by creatrope Reason: 1
I've grabbed the latest code using TortoiseSVN under Arduino-0018.
I'm getting WProgram.h: no such file or direction in function void setup() for all example programs.
I have the files under arduino-0018/hardware/butterino/cores/arduino. WProgram.h is there and this directory structure is symmetric with a working Sanguino structure, file by file.
I've tried moving things around a bit to see if it locates the file.
Can someone verify a compile of the latest example programs under Arduino-0018 for the Butterfly?
thanks - creatrope
msproul
I got blink to compile under 0018 on the Mac
I downloaded the butterfly files from
I put the folder in
           /Applications/Arduino.app/Contents/Resources/Java/hardware
I deleted everything except the butterfly entry in boards.txt
I had to make these changes
    rename main.cxx to main.cpp
    add #include <WProgram.h> to main.cpp
I do not have a butterfly to check out to see if it works.
I tried compiling a couple of programs, anything that used TWI (I2C) does not compile.
Mark
creatrope
Ok, compile problem resolved.
I've set bfly.upload.using=butterfly in the boards.txt
(also tried in preferences.txt)
Verified UART connection is working by entering 'name' via freshly loaded stock butterfly firmware.
I tried various combinations of pressing the button, resetting and uploading.
Upload eventually times out with:
Connecting to programmer: .
Found programmer: Id = ""; type =
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
The sequence of start the upload and pressing the button - anyone have a recommendation for a known sequence/timing that works reliably?
--creatrope
Brokentoaster
I normally go for tapping the button and then start the download while tapping the whole time.
Although I haven't tried this for a while.
sathopper
#97
Oct 28, 2010, 01:54 pm Last Edit: Oct 28, 2010, 01:55 pm by sathopper Reason: 1
fortunality all the links to the arduino012_butterfly.zip file are broken.
Where can I download this file or can someone email the file (email button)
Thanks  ;)
Brokentoaster
Sorry I've had my website compromised. I had to clean out some files. The new link should be.
http://brokentoaster.com/lost/arduino012_butterfly.zip
I haven't looked at this project for a while... so no promises that things still work.  :)
Good luck.
sathopper
Thanks.
I have a butterfly laying around on my desk for quite a while maybe now  I can do some funny stuff with it.  :)
