Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Bootloader compatibility  ATmega 1280 and 1284P  (Read 2737 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks Mark!  I'll give it another try tonight!
-Glen
Logged
Dresden / Germany
Offline Offline
Sr. Member
Entwicklungsklaus
View Profile
WWW
WOW! Mark!!! Thats very impressing!!! That is a very very good news....
ever wished to get rid of 3 mcu restriction....
THANK YOU VERY VERY MUCH!!!!
Greetings ChrisS
Logged
Sturmfabrik - mediale Dienstleistungen
www.sturmfabrik.de
0
Offline Offline
Newbie
Arduino rocks
View Profile
With the help of Mark's code I was able to get a working Bootloader and compile code with the Arduino IDE for the mega1284p controller board.  Sse here: http://BahBots.com
Some docs on how to set this up can be found here: http://bahbots.com/forum/viewforum.php?f=5&sid=3a17efb84c6070178e7546fb4fe36f27
I was also able to do wireless programming using xBee wireless modules.
-Glen
Logged
Dresden / Germany
Offline Offline
Sr. Member
Entwicklungsklaus
View Profile
WWW
Hi, thank you!
Do you use a 20Mhz Crystal or a real 18.432MHZ?
Code:
arduino_bahbots1284p.build.f_cpu=18432000L
Would you please test upload via ide on 20Mhz pleeeeeeeaaaassseeee!!!!!
Can't get it run... on 16Mhz everything works fine....
If you got it working on 20Mhz, please add some sentences here again....
Greetings ChrisS
Logged
www.sturmfabrik.de
0
Offline Offline
Newbie
Arduino rocks
View Profile
ChrisS,
I use a 18.432MHz crystal on my board.  I like this frequency because its the fasted speed the AVR supports that is also uart baud friendly.  I can also get exact 1 or 10ms interrupts from an 8bit timer.
If you need a boot loader for a mega1284P at 20MHz take a look here:
http://avr-developers.com/corefiles/index.html
Mark has done a lot of work to make Arduino run on other boards and has also written bootloaders for many of them including mine (http://bahbots.com).
Good luck!
-Glen
« Last Edit: November 03, 2010, 07:06:04 pm by glena » Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
