Topic: Turn Arduino into an ISP programmer (Read 23458 times) previous topic - next topic
Tchnclfl
I've noticed that in the new Arduino 0018, there is now an option to burn a bootloader using Arduino as ISP.
Does this use the same method as this thread describes, but all combined into the IDE?
I also noticed the Sketch you have to upload to the Arduino you will be using as the ISP.
If this is so, how do you select which bootloader will be burned?  Is it based on which board you have selected in the Tools->Boards menu (like burning bootloaders with other methods)?
Thanks!
wayoda
Tchnclfl
Oh, cool!  Didn't realize there was a Playground page for it yet!
If you don't mind my asking, what about it didn't work?
wayoda
Avrdude complained the chip I was about to program had the wrong  signature.
But as I said, didn't investigate any further (lack of time and I already have hardware programmer).
Eberhard
Tchnclfl
Alrighty.  I'm getting ready to try and reflash my RBBB ATmega328.
There's nothing wrong with it (other than it's the old bootloader), but I thought I'd try out ArduinoISP.
I'll post here what happens.
retrolefty
Quote
I think it's a two step process. First you have to select the actual board type that you are going to load the bootloader burner sketch into. Once that sketch is loaded and running on the board you then have to wire the board to the chip or board you are going to burn a new bootloader into and then you have to select the board type that corresponds to the chip you are burning the bootloader into.
That make sense?
Lefty
Tchnclfl
Yeah that's what it says on the ArduinoISP page.
Tchnclfl
Hey, it worked!
I wired it up like it said in the example, and the bootloader burned fine, and my RBBB is now running the Blink sketch I just uploaded!
Great to know it works!
retrolefty
Quote
Yes, gives one a secure feeling knowing they can recover from a bricked bootloader. However I still wonder why bootloaders get corrupted in the first place when the lock bits are suppose to protect that part of the flash memory. I posted a question on this board a while back asking for theories on how bootloaders get screwed up, however not much feedback from the 'experts' here so it's all still a mystery.  ;)
Lefty
Tchnclfl
I suppose it's one of those things no one really gets, like parallel resistance in a circuit (or does someone understand how that works? I sure as heck don't) ;D.
I bought some 'mega644s off of eBay (20 bucks for 6 of 'em), and I'm planning on making some StripboardDuino644s :), but first I needed to know that I could burn the Sanguino bootloader.
Osgeld
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Tchnclfl
Well, I found them for under 4 bucks each, and they have 32 total I/Os :P.
retrolefty
Quote
what is the advantage of a 644
More memory of all types, 40 pin allows for more I/O pins, two hardware serial ports, more user interrupt pins. Maybe more, I forget, but it's a great chip that fits nicely between the 328 and the 1280 chips. However you do have to modify the Arduino IDE as it does not support the 644 as shipped.  :(
Lefty
retrolefty
Quote
That's not too hard to master. Study ohm's law and kircoff's (sp?) laws and you will be solving those problems in a flash.  ;)
Lefty
Tchnclfl
Actually, only the 644P has two Serial ports, the plain 644 only has one :(.
I know the formulas for parallel resistance, but does anyone get why it works like it does?  How could there be a resistance of 100 Ohms, when the only path for the electricity to travel is through parallel 200 Ohm resistors? :P
