Topic: ATTiny85 port (work in progress) (Read 29623 times) previous topic - next topic
Osgeld
Quote
1. I'm not certain if version 0018 supports Tiny processors.
I use 18 with your 84 core, works fine
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
rj44319
I got it to work with the v19 arduino IDE.
This is he board file in the shekch area....
Code: [Select]
attiny45.name=ATtiny45
attiny45.upload.using=arduino:arduinoisp
attiny45.upload.maximum_size=4096
attiny45.build.mcu=attiny45
attiny45.build.f_cpu=1000000L
attiny45.build.core=attiny45_85
attiny85.name=ATtiny85
attiny85.upload.using=arduino:arduinoisp
attiny85.upload.maximum_size=8192
attiny85.build.mcu=attiny85
attiny85.build.f_cpu=1000000L
attiny85.build.core=attiny45_85
I am still trying the USbtinyISP
Coding Badly
#107
Nov 04, 2010, 11:51 pm Last Edit: Nov 04, 2010, 11:53 pm by bcook Reason: 1
Quote
Quote
Good to know.  Thanks.
Quote
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
That error may be because your avrdude.conf needs to be updated.  It's a text file.  See if there's a section for the '85 processor.
I'm using the Pololu USB Programmer.  This is my programmers.txt files...
Code: [Select]
pololu.name=Pololu USB AVR Programmer
pololu.communication=serial
pololu.protocol=avrispv2
And my boards.txt...
Code: [Select]
# Example boards.txt from...
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254/94#94
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274754985/6#6
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274820597/49#49
attiny84at8.name=ATtiny84 @ 8 MHz
# The following do NOT work...
# attiny84at8.upload.using=avrispv2
# attiny84at8.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)...
# attiny84at8.upload.protocol=avrispv2
attiny84at8.upload.using=pololu
attiny84at8.upload.maximum_size=8192
attiny84at8.upload.speed=19200
# Default clock (slowly rising power; long delay to clock; 8 MHz internal)
# Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value
# Brown-out detection disabled; [BODLEVEL=111]
# Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
attiny84at8.bootloader.low_fuses=0xE2
attiny84at8.bootloader.high_fuses=0xD7
attiny84at8.bootloader.extended_fuses=0xFF
attiny84at8.bootloader.path=empty
attiny84at8.bootloader.file=empty84at8.hex
attiny84at8.bootloader.unlock_bits=0xFF
attiny84at8.bootloader.lock_bits=0xFF
attiny84at8.build.mcu=attiny84
attiny84at8.build.f_cpu=8000000L
attiny84at8.build.core=tiny
attiny84at1.name=ATtiny84 @ 1 MHz
# attiny84at1.upload.using=avrispv2
# attiny84at1.upload.using=Pololu USB AVR Programmer
# attiny84at1.upload.protocol=avrispv2
attiny84at1.upload.using=pololu
attiny84at1.upload.maximum_size=8192
attiny84at1.upload.speed=19200
# Default clock (slowly rising power; long delay to clock; 8 MHz internal; divide clock by 8)
# Divide clock by 8 internally; [CKDIV8=0]
attiny84at1.bootloader.low_fuses=0x62
attiny84at1.bootloader.high_fuses=0xD7
attiny84at1.bootloader.extended_fuses=0xFF
attiny84at1.bootloader.path=empty
attiny84at1.bootloader.file=empty84at1.hex
attiny84at1.bootloader.unlock_bits=0xFF
attiny84at1.bootloader.lock_bits=0xFF
attiny84at1.build.mcu=attiny84
attiny84at1.build.f_cpu=1000000L
attiny84at1.build.core=tiny
attiny85at8.name=ATtiny85 @ 8 MHz
# attiny85at8.upload.using=avrispv2
# attiny85at8.upload.using=Pololu USB AVR Programmer
# attiny85at8.upload.protocol=avrispv2
attiny85at8.upload.using=pololu
attiny85at8.upload.maximum_size=8192
attiny85at8.upload.speed=19200
attiny85at8.bootloader.low_fuses=0xE2
attiny85at8.bootloader.high_fuses=0xD7
attiny85at8.bootloader.extended_fuses=0xFF
attiny85at8.bootloader.path=empty
attiny85at8.bootloader.file=empty85at8.hex
attiny85at8.bootloader.unlock_bits=0xFF
attiny85at8.bootloader.lock_bits=0xFF
attiny85at8.build.mcu=attiny85
attiny85at8.build.f_cpu=8000000L
attiny85at8.build.core=tiny
attiny85at1.name=ATtiny85 @ 1 MHz
# attiny85at1.upload.using=avrispv2
# attiny85at1.upload.using=Pololu USB AVR Programmer
# attiny85at1.upload.protocol=avrispv2
attiny85at1.upload.using=pololu
attiny85at1.upload.maximum_size=8192
attiny85at1.upload.speed=19200
attiny85at1.bootloader.low_fuses=0x62
attiny85at1.bootloader.high_fuses=0xD7
attiny85at1.bootloader.extended_fuses=0xFF
attiny85at1.bootloader.path=empty
attiny85at1.bootloader.file=empty85at1.hex
attiny85at1.bootloader.unlock_bits=0xFF
attiny85at1.bootloader.lock_bits=0xFF
attiny85at1.build.mcu=attiny85
attiny85at1.build.f_cpu=1000000L
attiny85at1.build.core=tiny
adamdb
I'm not clear on something.  Are there any actual changes to the software serial code, or does it just work because the timing in the millis() and micros() functions has been fixed up for the tiny 85?
Coding Badly
Quote
That makes two of us.   :)
Quote
Are you asking about NewSoftSerial?
Quote
I don't think either was changed in the published '85 core.  But I don't think they needed to be changed.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
