Topic: ATTiny85 port (work in progress) (Read 29227 times) previous topic - next topic
Cintax
#90
Sep 28, 2010, 06:23 am Last Edit: Sep 28, 2010, 06:24 am by cintax Reason: 1
Is there a code repository for this project where updated versions of the modified files are available for download?
The files I Have, I got from:
http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585
Chinese Jack
Does anyone has an explanation on why the Adruino (not ATTiny85)+softserial+RF doesn't work from my pervious question ? Thanks.
harry
I'm trying to get a tiny45 and NSSerial working, i'm getting an error relating to timer0, i assume its because the tiny45 either doesnt have a timer0 or its called something else (it seems to be looking for TIMSK0).
Quote
C:\Program Files (x86)\arduino-0019\libraries\NewSoftSerial\NewSoftSerial.cpp: In static member function 'static void NewSoftSerial::enable_timer0(bool)':
C:\Program Files (x86)\arduino-0019\libraries\NewSoftSerial\NewSoftSerial.cpp:520: error: 'TIMSK0' was not declared in this scope
C:\Program Files (x86)\arduino-0019\libraries\NewSoftSerial\NewSoftSerial.cpp:526: error: 'TIMSK0' was not declared in this scope
I'm going to compare datasheets now and see what i can find.
harry
Turns out it was easier than i thought.
Because the ATtiny45 only has one timer the register is called TIMSK not TIMSK0. Therefore, if you edit the end of NewSoftSerial.cpp to look like this:
Quote
#if defined(__AVR_ATtiny45__)
   sbi(TIMSK, TOIE0);
#else
   sbi(TIMSK0, TOIE0);
#endif
   cbi(TIMSK, TOIE0);
#else
   cbi(TIMSK0, TOIE0);
#endif
and recompile it will work. I think you'll probably have to have the 45/85 running at atleast 8MHz though.
Graynomad
@Chinese Jack
Quote
the problems disappear if I user either of following solutions:
1. Removing RF models, so the Pin2 is directly connect with Pin3
2. use standard hardware serial Pins (Pin 0 and Pin 1)
Can you verify that SS is actually talking at the correct bit rate?
Rob Gray aka the GRAYnomad www.robgray.com
John Abshier
I am trying to changes the fuses to run at 8MHz.  I am using an Arduino as an ISP (http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585).  Here is my boards.txt
Code: [Select]
attiny45.name=ATtiny45
attiny45.upload.using=arduino:arduinoisp
attiny45.upload.maximum_size=4096
attiny45.build.mcu=attiny45
attiny45.build.f_cpu=1000000L
attiny45.build.core=attiny45_85
attiny85s.name=ATtiny85
attiny85s.upload.using=arduino:arduinoisp
attiny85s.upload.maximum_size=8192
attiny85s.build.mcu=attiny85
attiny85s.build.f_cpu=1000000L
attiny85s.build.core=attiny45_85
attiny85.name=ATtiny85-8MHz
attiny85.upload.using=arduino:arduinoisp
attiny85.upload.maximum_size=8192
attiny85.bootloader.low_fuses=0xE2
attiny85.bootloader.high_fuses=0xDF
attiny85.bootloader.path= attiny85
attiny85.bootloader.file=fake.hex
attiny85.bootloader.unlock_bits=0x3F
attiny85.bootloader.lock_bits=0x0F
attiny85.build.mcu=attiny85
attiny85.build.f_cpu=8000000L
attiny85.build.core=attiny45_85
When I try to burn the bootloader to set the fuses I get the following errors
Code: [Select]
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avr_read(): error reading address 0x0000
   read operation not supported for memory "lock"
avrdude: failed to read all of lock memory, rc=-2
John Abshier
Coding Badly
@Andy Brown:
Quote
Firstly, the default port of the core code continues to use timer 0 for millis() and micros() timing. The ATtiny has only two timers and they are not equally capable. Timer 0 can do full PWM in the same way as we're used to with the ATmega series. Timer 1 cannot and is the less useful of the two.
In what way is PWM limited when performed from Timer 1?
Coding Badly
@John Abshier:
Quote
Code: [Select]
I've run into the same problem.  Did you figure out how to get it to work?
John Abshier
I didn't get it to work.  I borrowed a friends programmer and burnt the fuses with that.
John Abshier
Coding Badly
#99
Oct 25, 2010, 08:45 pm Last Edit: Oct 25, 2010, 08:46 pm by bcook Reason: 1
As luck would have it, very early this morning I figured out why the "read operation not supported for memory "lock"" error occurs.  There is a section missing from the avrdude.conf file that ships with Arduino.
Code: [Select]
# ATtiny85
part
    id            = "t85";
    desc          = "ATtiny85";
[lots of stuff here not included in this post]
    memory "lock"
        size            = 1;
        write           = "1 0 1 0  1 1 0 0  1 1 1 x  x x x x",
                          "x x x x  x x x x  1 1 i i  i i i i";
[glow]         read            = "0 1 0 1  1 0 0 0  0 0 0 0  0 0 0 0",
                          "0 0 0 0  0 0 0 0  o o o o  o o o o";[/glow]
       min_write_delay = 9000;
       max_write_delay = 9000;
I copied the section for the ATtiny84.  I have no idea if it is accurate but it seems to work.  I don't have time to verify the change against the latest version of AVRDUDE.
rj44319
#100
Nov 04, 2010, 03:35 am Last Edit: Nov 04, 2010, 05:34 am by rj44319 Reason: 1
I have been looking at this post and i whent to this web page:
I followed the instructons to the "T" and when i program the chip it gives me this error  :(...
Code: [Select]
java.lang.NullPointerException
     at processing.app.debug.AvrdudeUploader.getProgrammerCommands(AvrdudeUploader.java:97)
     at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:58)
     at processing.app.Sketch.upload(Sketch.java:1498)
     at processing.app.Sketch.exportApplet(Sketch.java:1465)
     at processing.app.Sketch.exportApplet(Sketch.java:1420)
     at processing.app.Editor$46.run(Editor.java:2219)
     at java.lang.Thread.run(Thread.java:619)
What is this all about?? :-[
Any ideas???
Coding Badly
Which IDE version are you using?
Post your boards.txt file.  Please use code tags.
rj44319
#102
Nov 04, 2010, 05:33 am Last Edit: Nov 04, 2010, 05:39 am by rj44319 Reason: 1
Arduino v18 IDE
this is the board file in hardware sketch file
Code: [Select]
attiny45.build.f_cpu=800000L
attiny85.build.f_cpu=800000L
I am using the attiny 85v -10PU-ND just for refrence..
I am using the Arduino Duemilanove (w/ 328) for the ISP
I have a ISP (usb tiny ISP) and if i could figure out how to use that with this I think id be better off.)
Coding Badly
Two suggestions...
1. I'm not certain if version 0018 supports Tiny processors.  I know version 0019 does.  If it won't cause problems for you, I suggest installing 0019.
2. Try including the bootloader options in boards.txt...
attiny85.bootloader.low_fuses=0x62
attiny85.bootloader.high_fuses=0xD7
attiny85.bootloader.extended_fuses=0xFF
# attiny85.bootloader.path=empty
# attiny85.bootloader.file=empty85at1.hex
attiny85.bootloader.unlock_bits=0xFF
attiny85.bootloader.lock_bits=0xFF
rj44319
By not changing anything i am getting to this point...
Code: [Select]
Binary sketch size: 666 bytes (of a 8192 byte maximum)
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
        Double check connections and try again, or use -F to override
        this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I think this is that reset issue with having to cut that trace to allow it to upload.....
i would like to modify the download setting to the USBtinyISP, any idea how?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
