1. I'm not certain if version 0018 supports Tiny processors.
I use 18 with your 84 core, works fine
Good to know. Thanks.
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
That error may be because your avrdude.conf needs to be updated. It's a text file. See if there's a section for the '85 processor.
I'm using the Pololu USB Programmer. This is my programmers.txt files...
pololu.name=Pololu USB AVR Programmer
pololu.communication=serial
pololu.protocol=avrispv2
And my boards.txt...
# Example boards.txt from...
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254/94#94
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274754985/6#6
# http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274820597/49#49
attiny84at8.name=ATtiny84 @ 8 MHz
# The following do NOT work...
# attiny84at8.upload.using=avrispv2
# attiny84at8.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)...
# attiny84at8.upload.protocol=avrispv2
attiny84at8.upload.using=pololu
attiny84at8.upload.maximum_size=8192
attiny84at8.upload.speed=19200
# Default clock (slowly rising power; long delay to clock; 8 MHz internal)
# Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value
# Brown-out detection disabled; [BODLEVEL=111]
# Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
attiny84at8.bootloader.low_fuses=0xE2
attiny84at8.bootloader.high_fuses=0xD7
attiny84at8.bootloader.extended_fuses=0xFF
attiny84at8.bootloader.path=empty
attiny84at8.bootloader.file=empty84at8.hex
attiny84at8.bootloader.unlock_bits=0xFF
attiny84at8.bootloader.lock_bits=0xFF
attiny84at8.build.mcu=attiny84
attiny84at8.build.f_cpu=8000000L
attiny84at8.build.core=tiny
attiny84at1.name=ATtiny84 @ 1 MHz
# attiny84at1.upload.using=avrispv2
# attiny84at1.upload.using=Pololu USB AVR Programmer
# attiny84at1.upload.protocol=avrispv2
attiny84at1.upload.using=pololu
attiny84at1.upload.maximum_size=8192
attiny84at1.upload.speed=19200
# Default clock (slowly rising power; long delay to clock; 8 MHz internal; divide clock by 8)
# Divide clock by 8 internally; [CKDIV8=0]
attiny84at1.bootloader.low_fuses=0x62
attiny84at1.bootloader.high_fuses=0xD7
attiny84at1.bootloader.extended_fuses=0xFF
attiny84at1.bootloader.path=empty
attiny84at1.bootloader.file=empty84at1.hex
attiny84at1.bootloader.unlock_bits=0xFF
attiny84at1.bootloader.lock_bits=0xFF
attiny84at1.build.mcu=attiny84
attiny84at1.build.f_cpu=1000000L
attiny84at1.build.core=tiny
attiny85at8.name=ATtiny85 @ 8 MHz
# attiny85at8.upload.using=avrispv2
# attiny85at8.upload.using=Pololu USB AVR Programmer
# attiny85at8.upload.protocol=avrispv2
attiny85at8.upload.using=pololu
attiny85at8.upload.maximum_size=8192
attiny85at8.upload.speed=19200
attiny85at8.bootloader.low_fuses=0xE2
attiny85at8.bootloader.high_fuses=0xD7
attiny85at8.bootloader.extended_fuses=0xFF
attiny85at8.bootloader.path=empty
attiny85at8.bootloader.file=empty85at8.hex
attiny85at8.bootloader.unlock_bits=0xFF
attiny85at8.bootloader.lock_bits=0xFF
attiny85at8.build.mcu=attiny85
attiny85at8.build.f_cpu=8000000L
attiny85at8.build.core=tiny
attiny85at1.name=ATtiny85 @ 1 MHz
# attiny85at1.upload.using=avrispv2
# attiny85at1.upload.using=Pololu USB AVR Programmer
# attiny85at1.upload.protocol=avrispv2
attiny85at1.upload.using=pololu
attiny85at1.upload.maximum_size=8192
attiny85at1.upload.speed=19200
attiny85at1.bootloader.low_fuses=0x62
attiny85at1.bootloader.high_fuses=0xD7
attiny85at1.bootloader.extended_fuses=0xFF
attiny85at1.bootloader.path=empty
attiny85at1.bootloader.file=empty85at1.hex
attiny85at1.bootloader.unlock_bits=0xFF
attiny85at1.bootloader.lock_bits=0xFF
attiny85at1.build.mcu=attiny85
attiny85at1.build.f_cpu=1000000L
attiny85at1.build.core=tiny
