Pages: 1 [2]   Go Down
Author Topic: Arduino Mega with ATmega2560  (Read 1433 times)
the atmega2560's are on ebay
i bought 2
but most of the lcd's and other boards
i bought dont work i am still in the process of
trying to learn how to program and modify the i/o ports
mark
USA
I have modified the standard bootloader to work on the 2560 mega.
http://www.cbxdragbike.com/arduino/bootloaderdocs/index.html
One important note, it only supports 128K bytes because the stk500 v1 protocol only supports 128k bytes.
Also, there is a bug in the gcc 4.3.2 compiler that really limits you to much beyond about 80K program space. This if fixed in gcc 4.4.0 and later.
I am working on an stk500 v2 bootloader for the 2560.
Mark
Funny you should bring this up I was just looking at one today.  You might want to check out eMartee at www.emartee.com.  They sell the board and have a post on how to get the bootloader, as a matter of fact they have everything on thier site.  I was logging in to ask if anyone had dealt with this company before I placed my order for one.
Netherlands
Hi, i have more than once bought things from emartee, at ebay. I am very pleased about this seller on ebay. http://myworld.ebay.nl/emartee2009?ssPageName=ADME:X:RTQ:NL:1181
Correct and fast shipping. I did not bought on their site yet.
Hi, Mark, have you got any result on stk500 v2 bootloader for the 2560?
Thanks a lot for your time.
USA
Yes it is all finished. I am working on documentation and waiting on Massimo before I can do some final testing. Then I will release it.
The new bootloader has a built in monitor that allows you to examine memory and and ports.
Mark
Minnesota USA
Made it mahself outta sand 'n wahr.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274821710
for now, you can't even use all the flash memory on the 1280 and none of the extra flash memory on the 2560.
That said, I too think it would be cool.
USA
That is correct, there is a bug in the avr 4.3.x compiler. It is supposedly fixed in 4.4.0 and later. I hope to have the new version of the compiler tested by the end of the week.
I have documented the bug in other threads.
Mark
Essex, UK
There seems to be a major bug in 4.5.0 and 4.5.1 to do with the initialization of global class variables that is not present in 4.3.x. It manifests itself most obviously in the failed initialization of multiple instances of HardwareSerial on the mega in even the smallest projects:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44617
I can confirm that the bug is present in 4.5.0/4.5.1 on Windows (mingw compiled gcc, avr-libc 1.7.0).
After refactoring the HardwareSerial instances to be dynamically initialized I found other cases in my project where this bug caused crashes. I would advise staying away from 4.5.0+ until this bug is fixed.
Home of the Nokia QVGA TFT LCD hacks: http://andybrown.me.uk
Hi;
is the bootloader downloadable from the cbxdragbike site (June 23rd post in this thread) the latest version for the Emartee Atmega2560 board?
Jan
DeKalb, IL USA
KB9SXU
I would assume the latest version of the bootloader should be the one in the latest version of the Arduino IDE.  Arduino as supported the Atmega2560 since the release of the UNO and MEGA2560... release 20 I think?  You can either load it directly from the latest version of the Arduino IDE or you can find the hex file in the same place as the other bootloaders within the Arduino IDE directory structure.
Jeff K - JKDevices.com - home of the MegaMini
I looked in:
C:\Program Files\arduino-0021\hardware\arduino\bootloaders\atmega
and the most recent/modern bootloader in the IDE seems to be atmega1280.
The procedure outlined in:
seems straightforward, I am assuming that after following the instructions, and wiring my target board according to the first example in the arduinoISP tutorial
http://arduino.cc/en/Tutorial/ArduinoISP
my atmega2560 board can be programmed using USB.
Jan
DeKalb, IL USA
KB9SXU
Just downloaded it to check where it was...
look in
arduino-0021\hardware\arduino\bootloaders\stk500v2
then it should be stk500boot_v2_mega2560.hex
I'm not sure if this is different or not, but it is definitely the "official" one
Thank you, that is definitely a newer file than the one I was contemplating burning!
Cheers,
Jan
Minnesota USA
A couple of weeks ago Mark suggested to me that the compiler issues with the 2560 are not as great as we had thought. the tests referred to above filled the lowest 64K of static memory (where your program and PROGMEM data go) with a huge amount of PROGMEM data. I checked out the issue with a program (a very atypical program that I generated using another program) that uses no PROGMEM data. It compiled loaded and ran OK. I have seen programs based on this work up to about 110K so far.
Most address information generated by the compiler is 16 bits and so is limited to addressing 64K. The compiler, however creates a 'trampoline' table in the lower 64K that is a list of long JMP instructions to addresses higher in the static RAM. I think the test that used a huge amount of PROGMEM data and failed put so much data in the low 64K that the trampoline table would not fit there. I know Mark's been working on this and is probably considerably more knowledgeable than I am about it.
Googling 'GCC AVR trampoline' is useful.
« Last Edit: November 10, 2010, 06:08:03 am by jrraines » Logged
Pages: 1 [2]   Go Up
