Topic: Looking for atmega328 eagle file with arduino pins (Read 8647 times) previous topic - next topic
liuzengqiang
I thought I had it but all I had were arduino usb board lay out. Could someone point me to an atmega 328 eagle file lay out? Just the 28-pin chip with both atmega and arduino pin markings. Thanks.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
etaifour
etaifour
I'm actually considering using a DIL for this, so I can only assume that I should be looking for ic-library in Eagle, but which DIL28 should I go for?
0.3, 0.4, or 0.6 mm?
PaulS
The eagle files for all of the Arduinos are available from the appropriate links on the hardware page.
http://arduino.cc/en/Main/Hardware
Just remove what you don't need.
