Loading...
Pages: [1]   Go Down
Author Topic: 10 Amp motor speed and direction regulation  (Read 860 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi, i want to control my RC car with arduino, so I need to control motor's speed and direction. Because motor draws about 10 Amps, I cannot use H-Bridge. Is there any easy way to do this?
Logged
0
Offline Offline
Jr. Member
View Profile
H-bridges made of discrete components can handle a lot of current.
Your RC car should have an H-bridge in it already.  Cannibalize that.
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
H-bridges at that current level are available, just a little pricey and possible larger then will fit in your car. If you don't need reverse for the car then speed control can be simple and inexpensive using a logic level mosfet transistor of suitable voltage and current rating and driving it with a arduino pwm output pin. It's not known to us how your car presently controls it's motor speed and if it could be modified for Arduino control or not.
Lefty
« Last Edit: December 27, 2010, 05:33:03 pm by retrolefty » Logged
0
Offline Offline
Jr. Member
View Profile
Even if you do need reverse, its just three more FETs to get an H-bridge.  10-20A FETs can be found for 0.50-1.00$
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
10A+ DPDT relays will reverse direction (occasionally and not quickly; probably fine for fwd/reverse.)  It's probably a toss-up whether that would work out cheaper than a "real" H-bridge...
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
You could control forward and reverse that way, but without adding an extra relay, you couldn't control on/off! So, it would be better to use a couple of SPDT relays instead of a single DPDT...
You wouldn't have PWM control, but you might be able to put on the low side a power FET or transistor, and PWM that, and switch direction with the relays; the whole thing could probably be done under $15.00 USD...
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have completed that using tamyia TEU-101BK controller, which is just 4 MOSFETs and it even supports PWM. It is a little bit expensive (30$), but I have it from RC car I am hacking, so why not?
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Well, ok - but why did you post here to begin with if you are just using the controller it came with (as mspguy noted)?
« Last Edit: December 28, 2010, 05:43:30 pm by keeper63@cox.net » Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
I meant that a DPDT relay would add "reverse" to a conventional single-direction speed controller...
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Ah - gotcha...
 smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
