Topic: Robot Camera  With  2.8" TFT (Read 59865 times) previous topic - next topic
Alexander_Kevin
Apr 20, 2010, 12:55 pm Last Edit: Apr 20, 2010, 04:57 pm by Alexander_Kevin Reason: 1
We make this Robot Camera Kits  With 2.8" 65K touch TFT Display (Arduino Compatible)
It includes camera, screen and control board. Control board is placed on the back of the screen. Camera sensor generates image data which is then processed real-timely by control board and displayed on the screen.
The Screen is 2.8 " and 65K color, supporting touch TFT function.
Camera is 30W Pixel OV7670 camera, which can supuly distinct image for normal use.
Control board is integrated with Atmega 32. So it is compatible with Arduino, which makes it possible to communicate with Arduino easily.
Many interfaces on the control board are still reliable, including 4-channel ADC, 1 channel USART, ISP port and 2 channel PWM, which makes function development much easier. :)
5V power is supplied to the control board via USB port, without any special requirement for power module.
OV7670 screen's power supply is 2.8 ~ 3.0V, which is TTL level for most of MCU.
TD/SD card can be connected to SPI port, which makes image storage possible.
Camera interface is plug-in mode. It is very easy to connect or disconnect with control board. Control board and camera can be used separately. :)
Our module is more powerful, it can achieve:
- TFT take a photograph real time when you need
- show the picture at the same time
- storage the picture you take automaticly
- read data from SD card;
- read data from TF card;
- send data to LCD screen for display;
- read touchscreen input;
- control touchscreen input by a button
- get time from RTC.
- and some other more update
We will release new version soon ,which is more powerful than this version......
More information will update soon............... ;) ;) ;) ;)
amacmullen14
Any chance of doing image analyzing, like blob tracking or color tracking, with this thing and an arduino?
leesen0218
I am new guy to this forum.
Wow.......cool :D
But I just wonder that how can it use with Arduino and how it work ?
I am requesting more information.thanks.
Regards
Alexander_Kevin
To sciguy
   It can do some image analyzing like blob tracking or color tracking when you use with Arduino[ch12289]Arduino sensor brick[ch12289]Robot special sensor . :)
   Regards
Alexander_Kevin
To Jackson :
  Thanks for care.
  You can use it with Arduino by USB interface through Mini USB or Sonsor shield shield.
  You can also connect it to your computer directly by USB cable.
Regards
mowcius
Looks like the same LCD as this:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1256896315
It also looks like it has the touch screen part on it so can all of the pins be accessed through the pin headers?
You did say ATMega 32... Isn't that a bit lacking on space? :p
Any updates? Ideas of price?
Mowcius
Alexander_Kevin
To mowcius :
We will release new version soon ,which is more powerful than this version......information update.......
leesen0218
I'm looking forward to the new version of this module
and I'm looking for the same kind of module to use with my
robot, which compatible with my arduino.
How to achieve that put the picture into the storage
of arduino small space?
expect your reply.Thanks
-JACKSON
pluggy
#8
Apr 20, 2010, 06:56 pm Last Edit: Apr 20, 2010, 07:06 pm by stephen_t Reason: 1
I'm wondering how you are going to make any headway into a VGA camera's image which is about 1MB native and about 20-30k as a jpeg with an 8 bit processor with 2kB of ram.  The arduino will probably take 10 minutes to establish if a frame has any blue in it......
It's pretty obvious that many people here have a very limited perception of how seriously low powered an Atmega microcontroller actually is.
Hint : your computer has a million times more memory and storage than a Duemilanove. (literally)
http://pluggy.is-a-geek.com/index.html
mowcius
I think this display and touch screen have a lot of potential but I would have thought that you want a mega-type chip at least (1280?). Yes, the ATMega chips are not very powerful but a lot has been done with them. I do however doubt how fast this camera, screen module thingy will be.
If it is cheap then I might pick one up though.
I would be interested to know more about the display as it is obviously cheap and relatively simple to interface with. Is there any more information available about the screen itself and how it is interfaced with?
Mowcius
pluggy
#10
Apr 20, 2010, 09:17 pm Last Edit: Apr 20, 2010, 09:18 pm by stephen_t Reason: 1
I could think of a good few uses for it, but it would need to be hooked up to something with a bit more go than an Atmega.  Something like this could do it justice :
http://www.newit.co.uk/shop/proddetail.php?prod=GuruPlug-Server
32 bit ARM processor and half a gig of RAM ;)
Alexander_Kevin
It already has the function of storing image data to SD/TF card which is connected to it. :)
Quote
-JACKSON
Alexander_Kevin
Well, soon i will upload a piece of video demo in Youtube. It will tell that it is true.
Make impossibility possible. That's the art of technology. ;)
Quote
Alexander_Kevin
[size=14][size=16]Here you can see the video demo: http://www.youtube.com/watch?v=kcQdJMSPJIU[/size][/size] :)
pluggy
Quote
I never had any doubts that it could display the camera picture on the screen, but how exactly does this involve an Arduino ?
