Topic: No peek() with ATmega644? (Read 2826 times) previous topic - next topic
JanD
Hello,
I got the compiler error for a sketch that peek() in class hardware serial was not defined. I looked into the core files of for the ATmega644 (non-P) from the Sanguino.cc webside and: There was no peek(). Is there a way to implement this? Or is there another way?
Jan
westfw
The versions of the Arduino libraries that was modified to support the 644 pre-dates the addition of Serial.peek()
It should be pretty easy to add, but I think the whole HardwareSerial support has been re-written at least once since then, so it won't quite be trivial.
Coding Badly
This core may be more up-to-date...
http://www.avr-developers.com/corefiles/index.html
JanD
I haven't thought of using these core files (why; i don't know) but I used them instead.
So no the error with peek() is gone. The code uploades. But I can't see anything on the LCD connected?!
What's happening now?
Jan
JanD
Would it perhaps help if I copied the peek() function from the core files from avr-deverlopers into the sanguino core files?
I will try that tomorrow.
Jan
westfw
Code: [Select]
yes, it looks like that should work  (it depends on how close the sanguino core is to the arduino core.  It looks like sanguino has been updated to about v0018, which is AFTER the serial code re-write that I was worried about.)
msproul
The latest version of the arduino core files should compile and work on the 644. Thus you would then have the peek function.
I have done a lot of work to make the core files processor independent. For more information on this refer to
Mark
