Topic: Shield pin usage list (Read 43413 times) previous topic - next topic
Jonathan Oxer
That's right, I'd forgotten I was going to do that. I'll do a bit of a cleanup and put it on GitHub.
I wouldn't take it as an example of a great way to do it though!
Jon
mowcius
Well it seems to work ok :D
I've used one of my protoshields now ;) Well, almost. I have it reserved for something...
jmrobert
I love the site, but PLEASE get the tabular form up.
Also, since I view this from a developers side,
IF a shield uses I2C, please list the ADDRESS or ADDRESS Range usable.
Also how might one develop a spi shield and give a few choices for CS/SS pins?  Everyone can't be on 10 or whatever the default CS is.
What if a user wants to use >1 spi device?
Thanks.
Jonathan Oxer
For things like that I list it in the "notes" section that appears directly below the shield diagram, but only if I know what it is. I've spent many, many hours going through circuit diagrams and documentation for shields trying to find info like that but I can't do it all myself! If you have information about any particular shields please click the link at the bottom of the page to send me a correction.
That's entirely up to you. The easiest is probably to run something like a 2x3 male header, with all pins on one side connected to the chip CS and the other three pins connected to three digital lines. Then users can put a little 2-way jumper header in place to select which digital line to use.
Jon
Security Sensor Shield: www.freetronics.com/secsense
NRG_WILL
Ok, you guys are the pin experts... I have found 100 different takes on this... so what is the answer:
I have an Arduino Mega 2560 and and EthernetSD- V5 it looks like from your "Shield" website.
Does one have to run jumpers and bend out the pins for 10,11,12 and 13 and jump them to 50,51,52 and 53??? :'(
please help the noob!  ::)
remspoor
Version 5 is compatible with the Arduino Mega 2560. The PCB has an ICSP connector at the bottom to reach the right pins i believe.
This is from the shield page (i couldn't post a link, 1st post?)
- 8< ----
It is compatible with the Arduino Duemilanove and Mega (using the Ethernet library coming in Arduino 0019)
- 8< ----
I'm using these 2 boards myself without modifying anything
Sooo.... _NO_ pin bending needed ;-)
Rinus
