Topic: LCD shield and/or LCD serial backpack (Read 55975 times) previous topic - next topic
tkbyd
A shield is great for some things... particuarly "plugging in" lots of connections to something external. However, to add an LCD panel to my Arduino, I only need to tap the serial line and 5v and 0v if I spend $8 for a complete kit of parts (except the panel itself) for the great little LCD panel controller from ModernDevice.com (no "S" in that). It is an implementation of Peter Anderson's #117.
"Except the panel..." The kit lets you interface a wide range of panels to the Arduino. Hence the need to purchase it "separately". ModernDevice offer a selection. Some only $12, if memory serves.
It should even be possible to drive the thing from something other than the serial out pin, but that would entail a little more software work. If you are willing to use the serial pin (and that won't stop you uploading programs to the Arduino) then all you need is.....
setup()
serial.start(9600);
loop()
serial.Print("Hello world");
Why reinvent an already available wheel? There are so many other worthy projects waiting out there!!
(My only association with ModernDevice: Happy customer.)
mem
#46
Feb 14, 2008, 11:37 am Last Edit: Feb 14, 2008, 11:42 am by mem Reason: 1
If  TTL serial is the only interface required then the board kit in your  link is a dollar cheaper (on the moderndevice.com page its shown as $9 plus shipping). But for some applications (like mine), the hardware serial port is not available (its used for data logging to a PC) and the baud rate (even at 19200) is too slow to use a software uart. For those of us that have real time applications that need something like an i2c interface, a serial only board won't cut it.
But even if my application didn't require the higher prformance, the board being discussed in this  thred has greater appeal for me because for the cost of an extra dollar its much more flexible than a serial only board.
Cheater
#47
Feb 14, 2008, 11:54 pm Last Edit: Feb 14, 2008, 11:56 pm by Cheater Reason: 1
Reasons?
I can list them:
  • Mine is faster and can do more. (ATmega168 vs PIC with 4k flash)
  • Mine is completely open, both hardware and software. The 117 is code protected and no source is provided.
  • Mine has four different interfaces (SPI, I2C, TTL Serial and RS232) compared to only TTL Serial on the 117.
  • Mine is cheaper. $10 for premade and $8 for a kit (SMD components however).
  • Mine is significantly smaller. Under a third of the size of the ModernDevice board.
  • And probably a few other reasons I've forgotten. :)
I actually wanted to buy a serial LCD controller but I couldnt find any which were half decent.
They were all closed source and only had TTL Serial and maybe RS232 interfaces.
Also I have a source which sells LCD panels at $7.90 for 16x2 with backlight in single quantities or $5.90 in bulk.
$12 can buy two. ;)
[EDIT] Oh and if these LCD controllers are popular then I will be going on to tackle things like graphical LCDs and other trickier hardware. [/EDIT]
chrisco
I thin the other reason is that it is a lot of fun :)
The 16x2 LCD board is great and I would also be interested in the Graphics board. I am thinking of using this with "sensor shields", e.g. I want to monitor the depth of a water tank using a pressure sensor.Chris
Cheater
Oh of course. :D
John_Ryan
Reasons?
I can list them:
$12 can buy two. ;)
I'm convinced. I'm currently enjoying my relationship with I2C so I'm keen to see what else I can add to the chain.
So, for 2 units ($20) including 2 16x2 LCD panel's ($12), it's $32 + shipping. Sounds a bit light.
When will they be available off-the-shelf?
xSmurf
Just a question: You do not provide a ground signal to your SPI, SER and I2C connectors. I would have expected these to have a ground since they are not differential. Am I missing something?
Told you Cheats...
"Pilots believe in a clean living... they never drink wisky from a dirty glass."
Cheater
Told you Cheats...
Why cant the SPI use the same GND as the power? :-?
There is a GND pin right next to VCC.
xSmurf
#53
Feb 16, 2008, 05:40 am Last Edit: Feb 16, 2008, 05:42 am by xSmurf Reason: 1
Oh they can, that's not the issue. Afaik, the issue is that it's not clear to the user that these lines must be tied together; especially since gnd is already filled.
EDIT: Funny enough, someone just posted this :P
As a rule of thumb, you always need to connect the ground between two devices which talk to each other.
blalor
Nick, I'm definitely interested in your OpenLCD project.   I started playing around with a 16x2 display last night, starting with the 8 bit interface and then going to 4, and then this morning I was thinking that it should be simple (and cheap) to delegate control to another Arduino chip.  Lo and behold, I stumble upon this thread!  ;D  So, please keep us posted on your progress!  I'd love to see some code in the SF SVN repository... (hint, hint! ;))
blalor
Ok, so now that I'm thinking about it, is the ATmega168 going to be running the Arduino bootloader (and thus be reprogrammable by other Arduino users) or will it have its own "OS"?
Cheater
It will be a Arduino but the reprogramming feature will be optional.
Basically the EEPROM will store a whole pile of settings.
One of the settings will be if you want the bootloader turned on or not. :)
I should get the PCBs early next week hopefully.
Cheater
Update: The PCBs are on their way and will arrive on Monday.
Now to chase up the components.....
blalor
Sweet!  The more I build up my current project (an intervalometer for my camera), the more I realize I need some way to offload the LCD connections somewhere else.  I'm using every single pin and I still want to do things like toggle the backlight and add another button or two.  Ugh.  And I'm already using 4 bit mode, which is noticeably slower than 8 bit!
aballen
Cheater will this support the KS0108 graphical LCDs?
