Topic: Atmega328 powered by a 3.7 volt battery? (Read 16611 times) previous topic - next topic
SpiffyChee
Can an Atmega328 +oscillator run off of 3.7 volts without a regulator to be used for 7 channel pulse width modulation with mosfets to drive the leds?
I'm desiring to power it with an 18650 battery. (which charges to 4.2 volts and drains to 2.75 volts)
http://www.dealextreme.com/details.dx/sku.5790
Coding Badly
I believe 3.7 volts is below the threshold for 16 MHz.  Many folks have claimed that running a processor at 16 MHz / 3 volts works but it is outside of the Atmel specifications.
Do you need the processor to run at 16 MHz?
SpiffyChee
How do I know if I need it to run at 16Mhz? I'm going to be writing code similar to this: http://fritzing.org/projects/arduino-knight-rider-with-8-blue-12v-led-modules/
Do I even need an oscillator? I just know I'm going to make a persistence of vision display (POV).
will I need 16Mhz for this?
CrossRoads
A 3.3V/8MHz Promini running on a 3.7V LiPo battery will control those LEDs just fine for you.
Coding Badly
I just know I'm going to make a persistence of vision display (POV).  will I need 16Mhz for this?
I doubt it.  A 328 running at 8 MHz should do fine.  In which case, you will be able to run directly from the battery.
No.  But the answer to the next question has to be "yes"...
Do you have a way to change the fuses?
SpiffyChee
#5
Jan 21, 2011, 08:27 am Last Edit: Jan 21, 2011, 08:31 am by SpiffyChee Reason: 1
I honestly have no idea what you are telling me? Could you restate it? I'm new to all this. I feel like your information is valuable and I don't want to miss it.
Do I need to use anything more than just the naked atmega328 chip?
I'd really like to use just the chip from my arduino uno rather than the pro mini. is this possible?
wortelsoft
The bare chip needs to be loaded with a 8MHz boot loader and you will need a programmer for that.
The fuses can be changed with the programmer. You can see the fuses as the settings in the bios of a computer.
The fuse settings set things like if you use a crystal or not if the internal clock needs to be divided or not.
CrossRoads
Sure - research fuses, internal oscillator, 8 MHz.
I've never done it, but I have read instances where others have, so it is possible.
Here's bunch of info on,
http://wolfpaulus.com/journal/embedded/arduino3
likely more than you will be able to use.
Do yourself  a big favor & get a 2nd arduino - then you can keep your deumilanove intact for programming & development, and download into something like  promini for embedding into your project.
SpiffyChee
#8
Jan 21, 2011, 09:21 am Last Edit: Jan 21, 2011, 09:35 am by SpiffyChee Reason: 1
Mann.. there HAS to be an easier way? So I cant just use the external oscillator and the chip with an unregulated battery source??
those batteries charge to 4.2 volts and drain to 2.75
I'm so confused. I just know i need the smallest and lightest weight battery possible and this is discouraging :/
Coding Badly
A word of caution on those batteries... they may require a cut-off circuit to ensure they don't "run dead".  It's my understanding that lithium batteries are damaged when they are run below a certain charge.  I can't tell from the description if those batteries have an internal cut-off.  From the comments, it appears most people use them in an existing device that presumably has a cut-off.
Yes.  You can either take a chance and run at 16 MHz (which is very likely to work) or obtain an 8 MHz crystal (or resonator).  But you may have to change the fuse settings to adjust or disable the brown-out detector.  Or, if you go with AA cells, just add a third battery.
Standard AA alkaline batteries typically have more total energy (2700-2900 mAh per cell according to Wikipedia).  The draw-back to alkaline cells is the voltage drop (1.5 full to 0.9 dead).  The benefit is the ability to run-dead and lots of energy per cell.  I have a few gadgets running directly from two AA cells and I'm very pleased with the results.
smeezekitty
My arduino works down to 2.5v before randomly resetting.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
