Topic: COM17 won't work - changing COM port number (Read 1 time) previous topic - next topic
pesononline
Hi all, I just crawled out of a pitfall that others might fall into. I've been using all sorts of usb-to-serial converters in different usb ports and when I plugged in my (USB) Arduino it showed up as com17. I could select it from the Arduino IDE but when I tried to upload my program I got an error saying something along the lines of "/dev/com17 does not exist". (On Windows XP!)
The solution is to give it another port number. I didn't know you could do that, but it's simple:
Select My Computer, right-click, select Properties
On the Hardware tab select Device Manager
Open the Ports (COM & LPT) group and select the USB Serial port where the Arduino is
Right-click on that and select Properties
On the Port Settings tab clicke the Advanced button
At the top of the page there's a drop-down menu labeled COM Port Number.
Select a lower port number there, even one that says "in use" - but select one that is not actually in use, of course. My guess is that anything below COM16 will work.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
