Topic: void loop() not looping? (Read 2467 times) previous topic - next topic
stealthtransam
when i put an If statment inside of a loop() function it does not continue looping.  Once the if statment is true the board remains in that state and doesn't change anymore.  attached is my code.  Any suggustions or is this a bug in the board?
int ledPin = 13;                 // LED connected to digital pin 13
int buttonPin = 7;              // pushbutton connect to digital pin 7
int val = 0;                    // Set initial state to LED off
 pinMode(ledPin, OUTPUT);      // sets the digital pin 13 as output
 pinMode(buttonPin, INPUT);    // sets the gitial pin 7 as an input
 val = digitalRead(buttonPin); //read the input of pin 7
 if(val == 1)
   digitalWrite(ledPin, val);   // sets the LED of pin 13
mellis
You don't have any code that would turn off the LED.  You don't actually need an if-statement at all, just do:
Code: [Select]
stealthtransam
#2
Jul 15, 2006, 07:56 am Last Edit: Jul 15, 2006, 08:01 am by stealthtransam Reason: 1
acutually the code i posted is not the code i had in question.  I aplogise.  I'll put the right code up here with my question once i get get home and copy and paste it again.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
