Topic: 168 + parallel port + uisp + avrdude + boot loader (Read 1 time) previous topic - next topic
zitron
May 20, 2007, 01:25 pm Last Edit: May 20, 2007, 01:34 pm by zitron Reason: 1
Finally working! So far...
So, you are like me, bought a 168, have a parallel port programmer (too cheap to buy a real one), and want to use it on your original adruino board, but can't get a bootloader on it properly, check these links:
-> de-solder the LED on pin 13? worked for me
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169816562
-> set the extended fuse to 0x0, not 0xf8 nor 0x7
http://tinker.it/now/2007/02/24/the-tale-of-avrdude-atmega168-and-extended-bits-fuses/
-> how to change fuses in avrdude
http://www.site.uottawa.ca/~jdesa066/avr_getting_started5.html
I burnt the boot loader with uisp with the batch file: (edited from the original atmega8 one in the bootloader folder)
#!/bin/sh
@REM parametre >>-dprog stk500 -dserial=$PORT << default
cd ..
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0x3F
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --erase --upload if=bootloader\ATMegaBOOT_168.hex -v
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0xCF
Then I changed the fuses with avrdude, sine uisp cannot change the extended fuse. The fuses are:
lfuse reads as C7
hfuse reads as DF
efuse reads as 0        <- if you set this to 0x7 the bootloader will be stuck in a loop, you progam won't run!
I did need to connect a 10k resistor from RX to ground, but it worked from some people, so try it!
Hope this will help someone!
-Z-
zitron
Sorry when I said "I did need to connect a 10k resistor..." I meant that I didn't need a resistor.
