Hy Guys,
The info:
7" Display purchased: 5 Inches HDMI Capacitive Touch Screen (Driver free) for Pi, BB Black, PC, Mac Book - Free shipping - DealExtreme
Info from Dx (diagram): http://m2.img.dxcdn.com/CDDriver/153336.docx
The display controler is SSD1963QL9.
Here I find the pdf with the controller info: http://www.techtoys.com.hk/Components/SSD1963QL9/SSD1963_1.1.pdf
I use an Arduino Due with ide 1.56 r2
The program:
"As a good seller" Dx doesn't gives more info from the display unit. When I recive it I just see a plastic bag and the display... no wires, no cd or link with libraries and test programs...
So, thanks to another very good posts that I read. I found the UTFT and Utouch libraries to try something.
Actually I'm trying this:
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield : <display model>,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield : <display model>,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(SSD1963_800,38,39,40,41);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(BigFont);
myGLCD.print("Text rotation", 0, 0);
myGLCD.setColor(0, 0, 255);
myGLCD.print("0 degrees", 0, 16, 0);
myGLCD.print("90 degrees", 319, 0, 90);
myGLCD.print("180 degrees", 319, 239, 180);
myGLCD.print("270 degrees", 0, 239, 270);
myGLCD.setFont(SevenSegNumFont);
myGLCD.setColor(0, 255, 0);
myGLCD.print("45", 90, 100, 45);
myGLCD.print("90", 200, 50, 90);
myGLCD.print("180", 300, 200, 180);
while (true) {};
It compiles and charge the code without problems... But...
The config:
I see how to configure the pins for Arduino due thanks to the Utft and Utocuh libraries.
| PIN | LABEL | PIN | PIN
| NUM | TFT | ARD | FUNCTION
| 1 | 3v3 | >> | 3v3 power
| 2 | GND | >> | Ground
| 3 | D0 | 22 |
| 4 | D1 | 23 |
| 5 | D2 | 24 |
| 6 | D3 | 25 |
| 7 | D4 | 26 |
| 8 | D5 | 27 |
| 9 | D6 | 28 |
| 10 | D7 | 29 |
| 11 | D8 | 30 |
| 12 | D9 | 31 |
| 13 | D10 | 32 |
| 14 | D11 | 33 |
| 15 | D12 | 34 |
| 16 | D13 | 35 |
| 17 | D14 | 36 |
| 18 | D15 | 37 |
| 19 | CS | 40 |
| 20 | RS | 38 |
| 21 | WR | 39 |
| 22 | RD | no use |
| 23 | RST | 41 | general reset
| 24 | TE | | Don't know
| 25 | TD0 | 3 | SPI_MOSI
| 26 | INT | 2 | TP_IRQ/IRQ
| 27 | TD1 | 4 | SPI_MISO
| 28 | PWM | | just to regulate backlight
| 29 | TSCK | 6 | SPI_SCK
| 30 | PCS | | Don't know
| 31 | TCS | 5 | T_CS
| 32 | SDCS | | Don't know I think is relationated to sd card...
| 5V | 5V | 5V | Backlight +
| 0V | 0V | 0V | Backlight GND
The problem:
I can't see nothing in my display just a white color, and dark blue when 1 min passed.
Can anybody lose time to help? Thanks in advance.
