Topic: How to power 16 channel relay (Read 7666 times) previous topic - next topic
scubieman
I want to buy a 16 channel relay. According to specs it says it needs 12v for the relay to energize. I noticed the arduino uno I am using has max output of 5v. How do I power this so the relays work?
Here is the link..... http://www.amazon.com/SainSmart-16-CH-16-Channel-Relay-Module/dp/B0057OC66U/ref=sr_1_1?ie=UTF8&qid=1403101563&sr=8-1&keywords=16+channel+relay
MarkT
That's not the datasheet...
It looks like it has 16 opto isolators so it takes 16 signals plus ground from the
microcontroller and a 12V supply (several amps probably) to power the relays.
http://www.sainsmart.com/arduino-compatibles-1/relay/16-channel-relay/16-channel-12v-relay-module-for-pic-arm-avr-dsp-arduino-msp430-ttl-logic.html
johnwasser
Looking up the relay model number: "SRD-12VDC-SL-C" it turns out the the 'L' in 'SL' means the coil draws 0.36 W.  If that 'L' were a 'D' it would mean 0.45 W.
0.36 W at 12 V is 0.030 A (30 mA). 30 * 16 = 480 mA so your 12 V supply should provide at least 500 mA just for the relays.
The LEDs are powered by a 5V regulator running off the 12V supply so you probably need to add at least another 160 mA for those.
12 V 750 mA would probably be sufficient but  12 V 1 A would have more margin.
jackrae
The unit signal inputs drive directly from the arduino 5 volt signals (your linked web blurb says so).  Power for the relays and onboard components comes from your external 12 volt supply unit.
scubieman
so where do I get the 12v from? If I power board using a 12v 1  amp power supply will that work?
johnwasser
Yes.
willytwo
I just bought the 16 channel relay board too.
I see there are 5v and ground pins next to the 16 channel pins.
I'm assuming that I should plug the 5v and ground from my Arduino into these terminals as well.
Am I correct?
Or are they power out to the Arduino board?
It sucks that there is no documentation for this board.
willytwo
Am I correct?
woodygb
#8
Dec 19, 2014, 07:42 pm Last Edit: Dec 19, 2014, 07:44 pm by woodygb
Am I correct?
Scroll down to where it says....
Click to Download the Manual
michinyon
It appears from the schematic that the device creates its own 5V supply from the 12V supply.
If this is so, it's not obvious why you would be connecting the 5V connection to the Arduino.
Maybe you can use it to power the Arduino.
And as for "click to download the manual",   if you actually do this,  there is no manual.
Some sort of PCB track image,   and a schematic,  which is rather confusing.   The  control inputs seem to be active low,   which is not what you would expect from the description.
cppdanny
You could resolve the problem by buying a 5v version of the board like
i did. The 1/2/4/6/8 Channel 5V Relay Board Module Optocoupler LED for Arduino PiC ARM AVR
There is also a 16 channel selectable there too. The link follows.
http://www.ebay.com/itm/1-2-4-6-8-Channel-5V-Relay-Board-Module-Optocoupler-LED-for-Arduino-PiC-ARM-AVR/172433598201?_trksid=p5713.c100041.m2061&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D20140109102600%26meid%3Dbf31768fe3f144469dc93004ea41281a%26pid%3D100041%26rk%3D2%26rkt%3D35%26sd%3D191990594110
756E6C
#11
Mar 01, 2017, 08:56 am Last Edit: Mar 01, 2017, 09:02 am by 756E6C
I would first try connecting only 5V and 1 IN pin to Arduino and see if that works, you may only need GND if you want to power Arduino from the relay board.
NOTE: You need to pull the OUTPUT pin LOW to energize the relay.
