Topic: Measure High current (Read 3480 times) previous topic - next topic
AJITnayak
Dear all,
I am trying to build application to measure current 15A-20A @1000v. I have build circuit with hall sensor and interface with arduino UNO using mux circuit.
Now i am trying to build circuit on shunt basis .if anyone here can put suggestion to take care during building circuit will be appreciable.
AMPS
jackrae
#1
Jun 21, 2014, 08:38 am Last Edit: Jun 22, 2014, 09:58 am by jackrae Reason: 1
There are extreme dangers associated with what you intend since your measurement circuit is always attached electrically to the 1000v supply and the only advice I could give is AVOID doing so.  It matters little whether your supply is AC or DC, the potential is equally as dangerous.
Assuming one side of your 1000v supply is "grounded", the shunt should be on the grounded side of the supply to minimise the potential that your measurement system could rise to.  But if the supply polarity should be accidentally reversed, even momentarily then your measuring device voltage becomes lethal.   Similarly if the ground connection of your supply should become open circuit due to a wiring or operating fault, the measurement connection potential could rise to a lethal value.
If your 1000v supply is "floating' ie not connected to ground, (a common practice on DC systems) then both positive and negative terminals should run at about 500v with reference to ground, so again lethal.  If a ground fault develops the measuring side could be at either 0V or 1000v, it all depends on which pole develops the ground fault.
If you are already happy using hall sensors then stick with them.  There are no prizes for winning the Darwinian medal of natural selection.  ( The process whereby those who endeavour to kill themselves by doing idiotic things manage to do so before they get a chance to breed the next generation of like minded individuals)
MarkT
#2
Jun 21, 2014, 11:01 am Last Edit: Jun 21, 2014, 11:03 am by MarkT Reason: 1
High voltage and shunt sensing do not go together.  Isolated hall sensor or a
current-transformer (CT) is needed, but CT's only work for AC.
The only way to do high tension shunt sensing is to have an entire isolated circuit
floating with the shunt (incluing its own isolated power supply) which then transmits the
value via optic fibre, opto isolator or wirelessly.
[ BTW high current at 1000V will kill, no second chances. ]
AJITnayak
Is it possible to measure current using shunt resistor . Like used in clamp meter .
Its equivalent of string monitor in solar.
AMPS
Paul__B
Well, clearly a clamp meter is not a current shunt.
You originally specified you were using a Hall sensor.  That is the correct way to do it (and is precisely how a DC clamp meter works in any case), there is no need to do it any other way.
Pelleplutt
Do you have to measure at the high end (1000 volts)
Is it possible to measure at low end (0 volt)
I think it's same current going around the circuit.
Pelle
Docedison
#6
Jun 21, 2014, 09:57 pm Last Edit: Jun 21, 2014, 10:04 pm by Docedison Reason: 1
Measuring the drop across a series resistor in the ground leg of a power supply is perfectly do-able but not really advisable unless you have a means of sensing the voltage at the high side of the sense resistor to detect an open condition or all the electronics are TOTALLY isolated from everything AND I DO MEAN EVERYTHING else connected to that node....
IMO a lot of extra crap to emulate the inherent isolation provided by a hall effect device.... Safety is NEVER, NEVER a place to try to save a dollar or "Simplify" a design.
You have been advised of how to do the task 'correctly' the obvious way, Twice...
What is the underlying issue that keeps you asking about how to do something inherently VERY Dangerous.
Were your engineering skills at the same level as your 'apparent' coding skills you would know this and not ask a useless question.
1A @ 1KV is 1 KW... this is a NON TRIVIAL current and voltage and 'accidents or parts/construction failures are generally LETHAL to both the equipment and the operator.
The answer to your question about ground sensing of DC current is perfectly valid... However after 40+ years of engineering experience, Something I would NOT attempt to do... simply because the safety devices added to limit the available fault voltage are subject to failure from the conditions imposed by the measurement techniques... OR.. Are of a nature as to degrade the available accuracy... NOT under ANY circumstances a 'wise' choice
Doc
--> WA7EMS <--
larryd
You will kill yourself or someone else.
Leave this to the experts!
No technical PMs.
The last thing you did is where you should start looking.
TomGeorge
Hi, can you tell us what the project is going to be used on please.
There may be an easier way to do it, and I'm worried that 20A x 1000V = 20kW!
Tom...... :)
Everything runs on smoke, let the smoke out, it stops running....
tbillion
is there a dc clamp meter that just "plugs" into arduino.. if so can someone point the way .. id like to look at it i may need a few. im trying to measure 200A@12VDC ... just not with a shunt. (becasue i dont know how to safly hook a shunt to an arduino yet... lol)
Paul_KD7HB
You REALLY should start another thread with this question.
Paul
tauro0221
Check the specification for the Allegro  ACS758 hall effect current sensor. It's has an isolation of 3000 volts.
Attached it is a link showing one of the many modules available. This is an example.. Do a google to find which module one suit your project.
https://www.tindie.com/products/BBTech/allegro-acs758-current-sensor-module-50a100a150a200a/
krupski
Dear all,
Forgive me for saying this... I say it because I feel your life is more important that the possibility of insulting you....
If you have to ask this question, you are not qualified to build such a circuit. That kind of voltage, as well as the current behind it, would be instantly lethal should you make a mistake or touch the wrong thing.
Chances are, you would be dead before you even felt the pain, but dead is dead. PLEASE be careful and seek the assistance of a qualified high voltage engineer.
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
krupski
A clamp on ammeter does not use a shunt resistor. Another example of why you should NOT DO THIS.
krupski
Doc
I think MarkT said it most accurately: "BTW high current at 1000V will kill, no second chances".
