Pages: [1] 2   Go Down
Author Topic: Lilypad Arduino  (Read 579 times)
http://sc-fa.com
Welp, I got my wicked-cool Lilypads, but..  I'm having problems getting anything to load.
Because I bought a Modern Device barebones arduino, I'm trying to use one of these:
http://www.ftdichip.com/Products/EvaluationKits/TTL-232R.htm
pinout:
http://www.ftdichip.com/Images/ttl232rsch1.jpg
I have the lilypad powered by the lilypad power supply, and I'm only using the TX and RX pins on the programming cable.
Here's the result of trying to load up the Blink code with arduino "10.0", aka 0010 alpha.
Binary sketch size: 1110 bytes (of a 14336 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I even loaded up the new FTDI driver that ships with the 0010 alpha. Mac OS X, 10.4.10.
... but..  still I get the error.
« Last Edit: October 16, 2007, 12:44:56 pm by stevecooley » Logged
you need to use
+5V
ground
rx and tx
try swapping rx/tx also, in case its a labeling issue.
dont swap +5v and ground tho smiley-wink
http://sc-fa.com
Oh.  Ok.  I know the lilypad power supply is using a 1.5v cell, but I figured it was stepping up to something more, yeah? I'm not really very experienced with electronics, I just keep pretending I understand these things until I hit a brick wall...  which is frequently. smiley
The only thing that tripped me up with that is that I tried using the current from the USB cable, which should be 5v, and it didn't seem to even power up the board.  I thought maybe I got it wrong, but I checked my connections and it looked ok...  Hmm..  I'll have to cannibalize one of my other projects and grab the 5v power supply and see if it works better.
Thanks very much for your input, Limor!
http://sc-fa.com
you need to use
+5V
ground
rx and tx
...I'll grab my 5v power supply and see if it works better...
Ok, that didn't work.  I just used this 5v power supply:
http://www.sparkfun.com/commerce/product_info.php?products_id=8249
Still getting this error:
and I tried swapping tx/rx, same result happens.
Daniel
Guest
hi
an identical error is described by several users in this thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1187909552
Doe the LED blink on startup to indicate the bootloader is there and working? Is there even an LED on the Lilypad?
D
http://sc-fa.com
There is an LED on the board.  It does a triple flash on powerup, waits ~10 seconds, and repeats the triple flash.  (and repeats the 10 second wait, triple flash, etc...)
« Last Edit: October 17, 2007, 03:58:21 am by stevecooley » Logged
Forum Administrator
Cambridge, MA
Did you try the suggestions in the troubleshooting guide (http://www.arduino.cc/en/Guide/Troubleshooting#upload)?  Do you have any other Arduino boards?  Can you upload to them?
Also, try the final Arduino 0010 release: http://www.arduino.cc/en/Main/Software
http://sc-fa.com
Yes, yes, and yes.
Ok, thank you!  I will try that.
http://sc-fa.com
upgrading to 10.0 final did not help.  :'(  I get the same error message.
Forum Administrator
Cambridge, MA
Did you tie the grounds together (of the FTDI cable and LilyPad)?
USA
Freeduino rocks
triple blink... isn't it the old bootloader that does not support autoreset?  I don't know lilypad, does it use the new or the old bootloader?
http://sc-fa.com
LEDs triple blink, but do not seem to want to receive programming.
The board does not appear to be powering up at all in this case.
« Last Edit: October 17, 2007, 06:52:17 pm by stevecooley » Logged
USA
Freeduino rocks
Have you tried the 2nd configuration but switching TX/RX?
USA
Freeduino rocks
One basic question:
Are you pressing the reset switch to upload the sketch?
http://sc-fa.com
Yes. Just now, here's the resulting failure message:
Pages: [1] 2   Go Up
