Topic: AT+CLCC No Carrier Error (Read 4099 times) previous topic - next topic
karthikhsshiv
During calling sequence i m getting NO CARRIER ERROR for AT+CLCC command.
I am using QuectelM95 with arduino Uno, with TxD RxD and Gnd.
The code is as below:
Quote
String GSM_string = "\r\n\n\nTest Protocol: GSM-easy!\r\n------------------------\r\n";
void setup(){
void loop(){
  WaitAndRead(1000);
      GSM_string += "Query register state of GSM network (20 seconds later!):\r\n";
      Serial.print("AT\r");                                           // Query register state of GSM network
      WaitAndRead(100);
      GSM_string += "Disable Echo:\r\n";
      Serial.print("ATE0\r");                                           // Query register state of GSM network
      WaitAndRead(100);
  GSM_string += "CPIN:\r\n";
  Serial.print("AT+CPIN?\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "Auto baud rate:\r\n";
  Serial.print("AT+IPR=9600\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "Disable URC:\r\n";
  Serial.print("AT+QIURC=0\r");                                           // Query register state of GSM network
  WaitAndRead(200);
  GSM_string += "Network registration:\r\n";
  Serial.print("AT+CREG?\r");                                           // Query register state of GSM network
  WaitAndRead(300);
  GSM_string += "Call sequence:\r\n";
  Serial.print("AT+COLP=\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "ATD command:\r\n";
  Serial.print("ATD+918971627172\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "CLCC:\r\n";
  Serial.print("AT+CLCC\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "VTS:\r\n";
  Serial.print("AT+VTS=1\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  GSM_string += "ATH:\r\n";
  Serial.print("ATH\r");                                           // Query register state of GSM network
  WaitAndRead(100);
  Serial.print(GSM_string);
  Serial.println("\n--- E N D ---");
  while(1);
void WaitAndRead(int timeout)
  for (int i = 0; i < timeout; i++)
    delay(10);
    while (Serial.available() > 0)
      char inChar = Serial.read();
      GSM_string += inChar;
  GSM_string += "----------\r\n";
And the response from serial monitor is as below (Response of M95 for the commands):
Quote
AT
ATE0
AT+CPIN?
AT+IPR=9600
AT+QIURC=0
AT+CREG?
AT+COLP=1
ATD+918971627172
AT+CLCC
AT+VTS=1
ATH
Test Protocol: GSM!
OK
Disable Echo:
OK
CPIN:
+CPIN: READY
OK
Auto baud rate:
OK
Disable URC:
OK
+CREG: 0,1
OK
Call sequence:
OK
ATD command:
CLCC:
NO CARRIER
VTS:
+CME ERROR: unknown
ATH:
OK
--- E N D ---
