Topic: Use RECHARGEABLE batteries for Arduino Diecimilla? (Read 611 times) previous topic - next topic
TheMillenium
How can I power the arduino with rechargeable batteries?
Can I just use this:
http://www.sparkfun.com/commerce/product_info.php?products_id=552
I have 4 rechargeable batteries à 1.2V, so i get a voltage of 4.8V. Does it work or does the arduino need 5 or 6V?
Grumpy_Mike
You need about 6.5 to 7V to power the board through the regulators. If you power this directly then you might get away with 4.8V but as soon as they start to droop you can expect trouble.
TheMillenium
So I could take two battery holders (->link^^) and put them together, which would provide max. 9.6V. Probably it will be about 9V to 9.2V after some time? Is this higher voltage bearable for the arduino?
Or shall I get a 4 AA and a 2 AA battery holder and put them together, to get 6x1.2V= max. 7.2V?
It gets kinda big, but the standby time will be huge, won't it?
I have 2500mAh Ni-MH Rechargeables. So 6*2500= 15000mAh.  ;D
So disadvantage is the size, but the advantage is the huge capacity?
bHogan
You could also use this . . .
http://www.sparkfun.com/commerce/product_info.php?products_id=8249
and connect directly to the 5V pin. I've used it with good results.
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
Grumpy_Mike
Yep any of those look good. I especially like the little step up from Sparkfun.
The closer to 7V you get it the less power you waste. The input voltage can be at least up to 15V so don't worry about 9V being too high.
TheMillenium
If you took a look at my "buying list" for now I do not want to buy from sparkfun too. Probably in one month or two I will buy a couple of other items. But I do not want to pay additional shipping charges there too. :-/
Can I do it the way I have proposed? 4 AA + 2AA battery holder? (Or 2x 3AA battery holder?) Will that work?
bens
As long as your input voltage is within the Arduino spec for input voltage, you'll be fine.
