Topic: Free virtual Uno simulation environment (Read 325233 times) previous topic - next topic
stanjsimmons
Jun 27, 2014, 08:27 pm Last Edit: Jun 28, 2014, 04:21 am by stanjsimmons Reason: 1
Hi Everyone:
I have now released version 1.0 of my UnoArduSim simulator for WIndows.
This simulator allows you to test and debug many Uno programs without needing any of the the actual hardware. You can connect virtual I/O devices to a virtual Uno on a virtual lab bench, load and modify your program, and run, run-to, halt, step into, step-over, and step-out-of while viewing all local and global variables/arrays/objects. Full details and download at  www.sites.google.com/site/unoardusim/
Enjoy!
JimboZA
#1
Jun 27, 2014, 08:34 pm Last Edit: Jun 27, 2014, 08:39 pm by JimboZA Reason: 1
Ooooo... downloading as we speak.
Thanks.
edit.... well blink works  :). That's really good stuff.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
CrossRoads
How does it handle complex external hardware? That's where all the fun happens.
stanjsimmons
#3
Jun 28, 2014, 04:19 am Last Edit: Jul 02, 2014, 06:07 pm by stanjsimmons Reason: 1
A good point -- UnoArduSim sure can't simulate any oddball faults/bugs inside your specific external hardware I/O device, but by attaching the corresponding UnoArduSim "fault-free" IO device you can tell you if your code is the problem. The  limited set of these virtual IO devices and supported libraries (which could be expanded in a following release) will hopefully be sufficient for most users, and if your particular device is not supported yet, you can try temporarily commenting-out/replacing the section of code that accesses it so that you can still test the other parts of your program.
emklaus
Excellent job!
Thanks so much for sharing it.
tkbyd
Regarding....
Quote
... I would encourage people using the simulator to teach Arduino use to encourage a good design/ development skill along the road to coping with the fact that the simulator probably WON'T simulate every possible bit of external kit:
"Stuff" boils down to inputs and outputs.
For a maybe-almost-too-simple example: Suppose I was using the simulator to develop software for a system to unlock my front door if I press the right buttons on a keypad.
In the final product, the Arduino will make an output high to make the door-lock-thingie unlock. FOR THE SIMULATION, I doubt that there is a door-lock-thingie "device" in the simulator. But there will be an LED. If I can "do" the LED in the simulation, I've solved the Arduino and software problems for doing the door lock in the real world. Yes... there are also some electronics issues... but I can make a great start on the overall road to success with the simulator.
Three cheers for this EXCELLENT initiative. I haven't played with it, but if it even ALMOST works, let's all get busy on... Facebook?... ick!... etc, and GET THE WORD OUT. If it even almost works, let's make getting it working even better worth the time of the people behind it.
And no, I'm not one of them (^_^)
tkbyd
#6
Dec 07, 2014, 10:47 am Last Edit: Jan 23, 2015, 02:09 pm by tkbyd
P.S.
Download problem solved! See post of 22 Jan 15
On 22 Jan 15 I cut down the following, but left parts to highlight the dead end which I suspect remains, and to make the following point, which was originally a PS...
Umm... Ah... there I go getting all excited, rushing in. (Again.) Before we all get behind THIS one, maybe we should explore the field a bit? I had no idea (duh) that this wasn't the first. Several listed, with brief notes, at...
http://blog.oscarliang.net/arduino-simulator-free-virtual-circuit-hardware/
... but I STILL think we should be promoting the good ones!
Modified comments on download from original post....
ARGH!! OH NO!!
Download link had a dead end route waiting for you 6 Dec 2014. Linked to how Google's shared docs system operates, I suspect. (I had "works". Changed that.)
The simulator's site doesn't have any comments up about the download issue. (Didn't early Dec 14, nor 22 Jan 15)
If you go where the sites.google.com link in the announcement at the top takes you, from there, eventually, you get to a page with a link for downloading the program. If you examine the source for the page with the link for downloading the program, you will find your GMail email address in it! (I hadn't entered it for ages... must have logged into it for something else days ago.) I would guess that if you use the link, you are, ** unwittingly **, going to be sending your GMail email address to whoever put up the link you've been persuaded to click. Thank you Google. I don't (knowingly) give out my GMail eddress... and won't be clicking on links like this one again, now that I have suspicions.
The simulator may be genuine... I imply nothing on that front. But I've learned something about how drive.google.com resource sharing works that I'm glad to know.
Note as you look at the sites.google.com page, that it is not a Queens University, Kingston, Ontario page. The Queens logo appears under the word "Affiliations".
plancaster
Hi Stan
I am a BSc Mech Eng Undergrad at Oxford Brookes.
My final year dissertation is on using and Arduino board to control a 12V 20A brushed motor.
Naturally that doesn't mean find an Arduino shield, plug it into the Arduino and then the job's done.
It means 'produce an investigation worth reading'.
Part of the dissertation has been the evaluation of Free/Open Source Arduino simulators.
I downloaded this today and it is very good, well done.
The Fritzing simulator has superior graphics, but it comes nowhere near yours on the practicality front.
Thanks for the effort.
best regards
Paul Lancaster
arduidiot
#8
Jan 20, 2015, 12:39 am Last Edit: Jan 20, 2015, 12:45 am by arduidiot
awesome im going to give it a shot ive been thinking a very similar thing!
Quote
i put a post in gigs and collaborations  for something im going to start working on in processing that will simulate
the target MCU'S output if a "hypothetical" pinout of basic digital components that can be determined using a database of truth tables for ICs that are designed as particular logic gates, but, as you said complexity is proportional to both fun of outcome AND mental strain achieving it, and there's a lot more fun than just ones and zeros to be had with other electrical components.
im a good observer. not the brightest but very curious.
that poor innocent dog died from AC. he died.
I do not refuse my dinner simply because I do not understand the process of digestion."
arduidiot
im afraid i too got an error for the dl page of the zip file.
timathis
Downloaded 1/19/2015 installed on win7 64 bit system.
Works excellently!!
Professor Simmons:
I am retired computers and electronics technologies instructor and would like to link students to your simulator for a new online course I am preparing on Arduino and circuit prototyping in the maker vent.
Would you have any objections to my putting a link to your program in the course along with credits to you?
I have been considering another professional program but your program fits my requirements very well.
Thanks
Tim
tkbyd
#11
Jan 20, 2015, 10:04 pm Last Edit: Jan 23, 2015, 02:14 pm by tkbyd
Update: Hurrah! Download problem solved! See post of 22 Jan 15
Rest is modified verion of original post...
Tried download again... still problems. (Original had details of what I'd tried... including...)
Tried to add yet another piece of software to my computer, as the download process seemed to "need" that. (The special "zip extractor", or whatever it was called)
Not necessary. (See post of 22 Jan 15)
How do I like to "publish" free things... or access them? Go to, say...
http://sheepdogguides.com/lut/lt1Nd.htm
Try the "download a .zip with the code and a compiled .exe file in it." See if it gives you any hassle? (And let me know, if it does!) (It will give you a little Windows program, illustrating topics in Lazarus programming. (Lazarus: An open-source, multi-platform language similar to Delphi.)
arduidiot
ok cool well im pretty certain i want to pursue making my own processing/VB/Arduino  virtual platform any how. i mean if anything should be free source it should be things that make life easier for those that are pushing their mental boundaries throughout the world ie designing and innovating anything (which is broad enough i think) so yep thats why i posted something in this vein in the gigs and collaborations section to try and get something like this cooking anyway.
thanks for posting the link ill take a look
arduidiot
ah this is my 32 bit ill try the 64 now. lol this 32 bit is in better nick because my dad never used it because the power adapter was blown and he assumed must be laptop.
arduidiot
Quote
i did find one (you'll need to google it i cant remember the link) that created the simulation on an engine that is apparently built based on Maxwell's Equations hence you get all the fruit of wireless involved in the read out i suppose only thing that made me click out ocf the page was pricing unfortunately
but if i were in a more established stage of my life and could afford it hey... im sure you understand how much cost and time cutting would be involved having it handy in  prototyping!
