Topic: Free virtual Uno simulation environment (Read 312877 times) previous topic - next topic
Ortwin
To download:
When on the download page (https://www.sites.google.com/site/unoardusim/home , choose "Simulator Download" from the left sidebar) you have to click the download arrow on the right and NOT the filename UnoArduSimV1.1.zip!
Ortwin
mnbf9rca
it looks very promising. Would be great to add some more complex features like support for multiple arduinos e.g. using I2C or RS485 as that's really where things get complex (at least for me).
jbil
Thanks for this great Arduino Uno simulation software. Very easy to use and enough powerfull.
Are interrupts implemented ?
I tried to use them without success.
Thanks for help.
JBIL
Ruudboks
Hi there, first of all; great program. Thumbs up!
I'm totally new at this and just practicing, so naturally i stumbled on something:
when i try to start an serial port with " Serial.begin(9600) " the program doesn't run.
When you write your program you'll see a black little screen with " BUILD-IN'S ",
if i look there there is an " //Serial: " that turns green (in the code)
but no " Serial. " , even if i type it in it stays black.
Does someone else have this problem, or see my misstep?
Ruud
gah24HrsOn
Nice work! Thank u Professor. Greetings from Brazil.
Cobbler
Hi Everyone:
I have now released version 1.0 of my UnoArduSim simulator for WIndows.
This simulator allows you to test and debug many Uno programs without needing any of the the actual hardware. You can connect virtual I/O devices to a virtual Uno on a virtual lab bench, load and modify your program, and run, run-to, halt, step into, step-over, and step-out-of while viewing all local and global variables/arrays/objects. Full details and download at  www.sites.google.com/site/unoardusim/
Enjoy!
Kudos on such a great program! I have used it for an hour and it works exactly as described!  Great for stubbing out a program!  Excellent work, this is the best simulator I have found so far. Thank you!
senjacob
Thank you Prof Simmons!
This is a great simulator and it is so light weight!!!
I'm from a software background. Just saw some projects done with Audrino and developed some interest on it.
So I decided to learn with a simulator. When I'm confident enough to do something real, I'll go ahead and purchase the items.
But it was hard to find a good free simulator for Audrino. This is the best I got so far.
Thank you so much. I really appreciate your effort for this wonderful simulator! :)
Wish you all the best and hope you will improve this a lot better and powerful than it already is.
rva1945
I can't make the motor to turn to both directions. I know it has something to do with Dir and Enc but tried some combinations to no avail.
rva1945
FIXED, I was not correctly setting the Dir PIN as OUTPUT!
SelfInstructor
#39
Apr 10, 2016, 08:36 pm Last Edit: Apr 10, 2016, 08:43 pm by SelfInstructor
Took me less than an hour to download and test out some code concepts.  What a great tool!
Sunny ways, Prof. Simmons, sunny ways.  Posted from the foot of Kingston Rd. in Toronto, so you are literally just up the street from me.   :)
larryd
Quote
Sounds like you are quite liberal (L)
No technical PMs.
The last thing you did is where you should start looking.
damain
All files at https://www.sites.google.com/site/unoardusim/services are infected with malware. DO NOT DOWNLOAD.
a55830
my windows 10 found malware in the latest UnoArduSimV1.4.3...
Graham-Leach
+Tk Boyd I have contacted you back and also looked at the Arduino thread you mention.  You look like an avid supporter of the software and I admire you for it.  I am not the author of the Uno Arduino Simulator.  Professor Stan Simmons of Queen's University, Canada is the author.  He may be reached at unoardusim@gmail.com´╗┐
Indelec
Would some assist in downloading the simulation software Prof Simmond V1.5 please.
I keep getting blocked by "Smart Screen Filter"
Kind regards.
Indelec
