Topic: Serial Monitor not working on Due? (Read 7673 times) previous topic - next topic
DROBNJAK
yeah, thx, I was 1.5.5, reinstalling 1.5.6-r2 right now.
DROBNJAK
#16
Jun 29, 2014, 09:19 am Last Edit: Jun 29, 2014, 09:23 am by DROBNJAK Reason: 1
This is how my Due drivers look like. Can somebody please compare with his and tell me if there is any difference?
http://i78.photobucket.com/albums/j111/COROVICD/DP08_Due-Driver_1_zps0dcd9b12.jpg
zaxarias
Nothing looks wrong , i would suggest you completely uninstall your DUE from device manager and then install drivers again..
Make sure you follow this guide step by step http://arduino.cc/en/guide/windows
Reinstall IDE 1.5.5..
z.p
DROBNJAK
There is possibility that cable is the problem. I got my cable from Adafruit and it works well on Leonardo (and on the other PC).
This cable is not just normal mini-USB Type B. Normal Type-B cables can't fit into Leonardo or Due?
zaxarias
No , DUE uses a micro Usb cable ..
z.p
DROBNJAK
Any fresh ideas? I am still stuck.
zaxarias
Tell us the things you have done so far on that second PC
z.p
DROBNJAK
Which one? One where S.M. doesn't work or one where S.M. works?
zaxarias
Have you tried anything(in general) to see if it works ?
z.p
DROBNJAK
- I removed Due from device manager and deleted all the related drivers. Than reinstalled 1.5.5-r2
- changed USB cable,
- tried pressing Reset just before uploading started.
- established that sketch works, by writing to SD Card, it only doesn't show anything on S.M.
- changed baud speed from 9600 to much lower,
- disconnected and disabled all the USB and serial port device, by both pulling cables out and disabling
The strangest thing is that it works on one PC and doesn't on another.
zaxarias
Did you try other versions of IDE except 1.5.6- r2 ?
Certainly there's something wrong with that PC ...
z.p
DROBNJAK
Yes, I tried 1.5.6-r2.
But I am sure that something is wrong with PC. Problem is how to eliminate what is wrong. I've done enough insalling and reinstalling to know that that doesn't change anything.
Question is where else to look?
zaxarias
What's your operating system ?
z.p
DROBNJAK
Windows 7, 64-bit.
I just found this, from some driver related file:
However the included ArduinoDue.inf in the drivers folder is showing:
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_2341&PID_003E&MI_00
[DeviceList.NTamd64]
Can fidling with this help? I am sure there is some switch somewhere in installation or libraries that needs to be changed.
Kassiopeia
do you have an Arduino DUE or an DigiX?
Just found that thread:  http://digistump.com/board/index.php/topic,1462.0.html
