Topic: Relay is fails to switch from NC to NO (Read 1 time) previous topic - next topic
BijendraSingh
Hello.
I am trying to control DC motor using arduino digital pin output. For this purpose i used relay between Arduino and Motor.
i am using below relay
http://www.ebay.com/itm/12V-2-Channel-Relay-Module-Low-Level-Triger-Relay-shield-for-Arduino-Brand-New-/351105525132?pt=LH_DefaultDomain_0&hash=item51bf85258c
Connections are:
Relays IN1    -> arduino digital pin 10.
Relays  VCC  -> 12 VDC of  external adapter1.
Relays  GND  -> GND of external adapter1.
Relays  C      ->  12VDC of external adaper2.
Relays  NC  -> Not connected to any terminal.
Relays  NO   -> motor +ive terminal.
                        motor -ive terminal -> GND of external adapter2.
I am running below code on arduino and seeking that motor will run for 10 second and stop for next 10 second in a loop.
Code: [Select]
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  Serial.println("high");
  delay(10000);
  digitalWrite(10, LOW);
  Serial.println("LOW");
  delay(10000);
i got nearly 3.7VDC at Relays IN1 pin still motor is not running.
can some one suggest where i am making a mistake.???
Bijendra
dave-in-nj
#1
Jul 02, 2014, 12:36 pm Last Edit: Jul 02, 2014, 12:38 pm by dave-in-nj Reason: 1
is the ground on the device tied to the ground on your Arduino ?
Connections are:
Relays  GND  -> GND of external adapter1.  [font=Verdana]AND connected to arduino ground[/font]
BijendraSingh
No, i didn't connected Relay's GND to arduino GND.
i am going to join Relay's GND  with arduino GND.
Bijendra
BijendraSingh
Bijendra
MarkT
You need a circuit to carry a current - only connecting the relay module to
pin 10 means there's no circuit between the Arduino and module. a circuit
is a loop.
The only time a single wire is enough is when you using an antenna!
aras-4u
hello evryone , i have some probleme with my project
i use
i don't know how connecte the OUT and COM to my Arduino nano ald also the code for programming
thx for helping
couka
That's why RF still seems to be voodoo to me, even after understanding the basic principles behind it :D
lg, couka
youtube.com/DieBastler1234
Don't send me technical questions via PM. They will be deleted unanswered.
aarg
Or wiring automobile accessories. :)
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
outsider
Post a link to your relay board, there are many different kinds.
