Topic: LCD Backlight (Read 590 times) previous topic - next topic
Pauly
I have got an 16X2 LCD HD44780 form Spark Fun working that shows a temperature reading.  I am using the LCD 4 bit library and it works fine.  My question is , how do I turn on backlighting?  I believe this is available on pins 15 & 16 from the LCD.
Thanks
Grumpy_Mike
Look at the data sheet but normally you just apply power to the pins.
MikMo
Just don't forget to check the documentation for the display to see if a current limiting resistor is needed.
I almost fried a display by not putting a currentlimiting resistor in line with the power to the backlight.
Oracle
If it's an LED backlight, it almost certainly needs an external current limiting resistor.  There's a chance it has one built in, but I wouldn't risk burning out the backlight by just applying power without confirming it.
LCD's also use EL-backlights, which are more difficult to power (they need high voltage, high frequency AC at very tiny current), but I doubt a nice modern purchase from Sparkfun would use that.
Pauly
Hi - Thanks for the advice.  Here are some of the specs from the datasheet.
Can I just connect a resistor and an on off type button between pin 15 and pin 1?
1. 5X8 dots with cursor
2. Built-in controller (KS0066U or Equivalent)
3. +5V power supply(Also available for +3.0V)
4. 1/16 duty
5. BKL to be driven by pin1,pin2,or pin15,pin16,or A,K
6. N.V.optional
Pin #  Symbol    Function
1.        VSS       GND
2.        VDD       +5V
15.        A        +4.2V for LED
16.        K        Power supply for BKL(0V)
Grumpy_Mike
No,
It is pin 15 to Pin 2 through a resistor.
You will also need to connect pin 16 to pin 1
Oracle
15.        A        +4.2V for LED
Just to clarify, A stands for Anode which you connect to positive, K stands for Cathode (yeah, it's confusing), which you connect to ground.
