Topic: Driving a 4 wires 12 volt fan (Read 2946 times) previous topic - next topic
camillo777
Jul 02, 2014, 08:18 pm Last Edit: Jul 03, 2014, 10:05 am by camillo777 Reason: 1
Hi all,  I have a question; I have connected a fan with 4 wires to an Arduino Due.
Wiring on the fan should be like this:
Pin 1 - Ground - Black
Pin 2 - 12v - Yellow
Pin 3 - Sense - Green
Pin 4 - Control - Blue
I attached the yellow to the 5V of the board and the black to the GND of the board.
The fan starts and is ok.
What I need is to be able from the Arduino to switch on/off the fan based on temperature.
The only way I managed to do it is using the Blue wire and connecting to the Digital pins (like 22) or PWM pin (like 3) and giving HIGH to start and LOW to stop.
But doing like this even if I set the control to LOW, at every Arduino loop, even if I do not change any pin, I got the fan to move a little (like 3 times and then stops as it should)...
And I do not know why.
I tried to put the yellow directly to the digital or pwm pins but it will not start.
Thank you if You can help me more.
UPDATE1: I think I understood why the fan works only powered by the 5V pin; because every other pin on the Arduino Due can output 3.3V MAX; so 5V seems to power it up but 3.3V is too low. I still do not understand why setting the control to LOW every loop() start it gives a current peak to the fan that makes it turn 2 or 3 times.
This is the source code:
Code: [Select]
#include <DallasTemperature.h>
#include <OneWire.h>
#define TEMPERATURE_PIN 2
#define FAN_PIN 22
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(TEMPERATURE_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int myspeed = 0;
int countmsecs = 0;
void initFan(){
 pinMode(FAN_PIN, OUTPUT);   // sets the pin as output
 stopFan();
void startFan(){
 Serial.println("starting fan");
 digitalWrite(FAN_PIN, HIGH);
void stopFan(){
 Serial.println("stopping fan");
 digitalWrite(FAN_PIN, LOW);
 Serial.println("setup start");
 initFan();
 sensors.begin();
 Serial.println("setup end");
 countmsecs++;
 //Serial.println("loop start");
 if (countmsecs>5000){
   countmsecs = 0;
   //delay(5000);
   Serial.print("Requesting temperatures...");
   sensors.requestTemperatures(); // Send the command to get temperatures
   Serial.println("DONE");
   Serial.print("Temperature for Device 1 is: ");
   // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
   float temp = sensors.getTempCByIndex(0); // from 27.34 to 273
   Serial.println(temp);
   Serial.print("myspeed=");
   Serial.println(myspeed);
   if (temp>26){
     if (myspeed!=255){
       startFan();
       myspeed = 255;
   else{
     if (myspeed!=0){
       stopFan();
       myspeed = 0;
 delay(1);
 //Serial.println("loop end");
Best regards,
Camillo
AJITnayak
Can you share data sheet for temperature sensor and fan being used .
Delay time is too short.
you can try this , forget everything . you can do this keep setup as like in your program
Code: [Select]
startFan();
stopFan();
delay(3000);
whether u can control motor like this.
AMPS
camillo777
Fan is: ADDA AD0912UX-A7BGL
Temperature is: SHIELD DALLAS DS18B20
I tried Your script, but I do not know why, it seems on the stop, the fan turn 3 times and stops.
If I increase the timing it is ok:
Code: [Select]
startFan();
delay(10000);
stopFan();
delay(10000);
But now I have to add the test on the temperature.
Do You have other hints?
Thank you!
Camillo
AJITnayak
When you keep timing uniform . It stay for 10000ms on and off for 10000ms.
In my program on for 1000ms &off 3000ms that reason u find3 times since delay is too low.
From that we can understand that ur motor can be controller through blue wire itself,
Now can you share data sheet of temperature sensor u r using.
AMPS
camillo777
This is the temperature sensor I bought:
http://m.ebay.it/itm/330995666100?cmd=VIDESC&gxo=true
Thank you
Camillo
AJITnayak
#5
Jul 04, 2014, 08:29 am Last Edit: Jul 04, 2014, 08:34 am by AMPS-N Reason: 1
Can you share data sheet for the temperature sensor> i could not able to located datasheet in mentioned link
Code: [Select]
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print(" Requesting temperatures...");
  Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
    // You can have more than one IC on the same bus.
    // 0 refers to the first IC on the wire
use this code. Now just send me snap shot of output file.
Once u make ensure temprature sensor working.
Now tell me what are ranges of temperature u wanna control Motor action
AMPS
camillo777
Hi I have not found the data sheet but it is a simple DALLAS DS18B20 shield. The code is working, I already tested, the temperature decrease when I run the fan over the temperature probe.
I am just having that strange movement on the fan even if I put the control to zero. Maybe is the one wire library which reset the pins of the fan for a moment?
I tried like this:
Loop start:
Get temperature ;
If temperature more than 26.5 and fan not running: start fan;
ElseIf temperature less than 26 and fan is running: stop fan;
Wait 10 seconds ;
Loop end:
Obviously these temperatures are only for test, but to go from 26.5 to 26 and vice versa can take some minutes.
When fan is switched off I have every loop that strange little movement on the fan like as the control pin of the fan was reset to HIGH and then back to LOW.
any hint?
Thank you
Camillo
AJITnayak
Code: [Select]
if (temp>26){
      if (myspeed!=255){
        startFan();
        myspeed = 255;
    else{
      if (myspeed!=0){
        stopFan();
        myspeed = 0;
replace with
Code: [Select]
if((temp>=26)&&(myspeed!=255))
startFan();
        myspeed = 255;
}else
  stopFan();
        myspeed = 0;
In your codedelay(1) represent 1ms not 1 s.
to wait for 10s you should set time to delay(10000)
AMPS
camillo777
Yes I changed the code as You advised but every time the loop is called the fan have a slight movement:
Code: [Select]
#define FAN_PIN 22
int myspeed = 0;
void initFan(){
  stopFan();
void startFan(){
  myspeed=255;
void stopFan(){
  myspeed=0;
float getTemp(){
    return temp;
  initFan();
  sensors.begin();
  float temp = getTemp();
  if (temp>26.5 && myspeed==0){
    startFan();
  else if (temp<26 && myspeed==255){
    stopFan();
  delay(10000);
AJITnayak
Here condition should be
Code: [Select]
if (temp>26.5 &&( digitalread(FAN_PIN)==LOW)){
    startFan();
  else if (temp<26 &&( digitalread(FAN_PIN)==HIGH)){
    stopFan();
Becaus
AMPS
camillo777
Code: [Select]
    startFan();
    stopFan();
Becaus
I am sorry, why? how this can help?
Thank you!
