Topic: Can any of you help me pick a robot kit please? (Read 10144 times) previous topic - next topic
newbcake
I own a couple Arduino boards, (4 to be exact), and am looking to get into robotics.
These are the kits I am looking at (and notice NONE of them come with an Arduino board):
http://www.pololu.com/product/2509
http://www.parallax.com/product/130-35000
http://www.makershed.com/Make_it_Robotics_Start_Kit_p/mkrad07.htm
I also know of the Magician Chassis, but my problem with it is that I can't figure out a shield to go with it and have it be friendly.
The end goal is for it to be a learning experience, so I really have no intents on what to build.
Maybe some robot that can follow a sound, a line on the floor, a light, etc.
zoomkat
Simple DIY robot tutorial.
http://www.foxytronics.com/learn/robots/how-to-make-your-first-arduino-robot
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Pota_Mota
#2
Jul 04, 2014, 10:19 am Last Edit: Jul 04, 2014, 11:05 am by Pota_Mota Reason: 1
There are some nice Italian robots that are called: ardubipe, spiderin and ardufilippo that probably are provided of a Shield and an Arduino but i am not shure!
This are the links to see them:
https://www.futurashop.it/index.php?route=product/product&filter_name=arduspiderin&product_id=4473.
https://www.futurashop.it/index.php?route=product/product&filter_name=arduspiderin&product_id=4591.
https://www.futurashop.it/index.php?route=product/product&filter_name=ardubipe&product_id=4539.
But, their cost is too high so I would say to you to build an own made robot (building the pieces that you need)
steinie44
If you want to run it on carpet, forget the 2 wheel types. Get a 4 wheel or tracked bot.
Cactusface
#4
Jul 11, 2014, 04:36 pm Last Edit: Jul 11, 2014, 04:51 pm by Cactusface Reason: 1
Hi newbcake ,
                             I've made a few robots, but the only one I brought as a kit is the Pololu Zumo (Chassis only), a bit small but that's the point of it.  My first one was very simple using micro-switches as sensors, then one on a round perspex chassis, a Pololu Tracked RP5, etc. control has included L293 drivers, servos and ultra-sonic's for distance and obstacle finding..
Build it yourself and save a packet, especially if like me you don't have it in the first place...  The Tamiya dual motor gearbox is a good start. I don't find 2 wheel robots a problem at all, in fact tracked bots have problems turning on carpets. Visit http://www.banggood.com/Wholesale-Smart-Robot-And-Accessories-c-2745.html   for a very cheap £6 kit.
It all good fun, but a few other more useful things are my seed propagator controller and fish tank controller..
If you care to take a look here: www.melsaunders.co.uk  you can see some of my stuff, and my other interest!!   I will help you (or anyone else) anyway I can......
Regards
Mel.
Open your mind! But not too far, your brains might fall out.
Also like Photography, model building and my 300+ Cacti and Succs.
oric_dan
Hobby King also has a bunch of nice robot kits.
http://www.hobbyking.com/hobbyking/store/__702__689__robotics_diy-robotics_kits.html
Despite what steinie mentioned, I've found that 4WD bots tend to have trouble turning on carpet, as the tires tend to bind, and you need to set the motor speed [ie, PWM duty] way up, or else the bot will stall. This is especially a problem with 4WD robots that have higher speed motor gearing and off-road [knobbly] tires.
Also, a big problem with many tracked platforms is the treads tend to come off when turning on carpet.
Also, if the tires are too smooth on 2WD robots, sometimes there is a problem with getting over transitions like the floor strips at doorways, and the metal strips used to hold down the edges of carpets.
I like the design of this robot for a starter kit, but haven't tried it myself, so cannot say about carpet vs hard floors vs transitions. But you get a lot for cheap.
http://www.hobbyking.com/hobbyking/store/__37892__Arduino_2WD_Ultrasonic_Smart_Car_Kit.html
One problem with standard Arduino boards is it's a huge PITN to interface them to r/c servos, but you notice the board that comes with the kit mentioned is specially designed for plugging in servo 3-pin connectors.
steinie44
Problem with the two wheel ones is something has to hold up the end. That is usually a caster. The caster is very small and won't go over carpet or bumps.
oric_dan
Yeah, best to look for a 2WD platform that uses a rotatable wheel rather than a caster. I did look at the pictures of the HK 2WD platform but couldn't tell whether the idler was wheel or caster.
zoomkat
Robots can have only two wheels, like the bot below, where the bot body is suspended from the axle centerline. I tinkered with the idea of a two wheel bot (bottom), but the jar lid wheels needed to be larger to keep the center of gravity low.
http://inventorartist.com/rolly-bot/
steinie44
I'm building the Rolly+Bot now. Only a bit larger, so I can strap a 7.2V 3A RC car battery across the bottom.
oric_dan
On doing a little more checking, I found the Hobby King prices are good [ie, low], but their shipping costs from CN to the US tend to be on the high side. However, the robot kits they sell are also available from many other vendors. Some have free shipping from CN, but the unit prices are also a little more. Eg,
http://www.dx.com/s/robot+kits
I also see the smart car has the wheel caster, rather than the ball caster.
http://www.dx.com/p/r0008-multi-function-ultrasonic-robot-car-kits-for-arduino-multicolored-the-third-generation-328158#.U8FzXZRdWGM
Ulysse
#11
Aug 12, 2014, 07:47 pm Last Edit: Aug 12, 2014, 07:49 pm by Ulysse Reason: 1
Well, the Arduino Robot is definitely a good choice since you have everything you need to build your robot including the microcontroller. You can concentrate on programming.
http://www.ca.diigiit.com/robots-kits/mobile-robot/arduino-robot-us-plug
If you don't want to pay for it, it looks like they have a competition where you can win it!
GunnerCAF
I can tell you a little about the third kit on your list from Make. The kit is like an erector kit and made of metal. There is a motor add-on kit that comes with a second set of wheels that make it possible to make 4 wheel robots.  This is all good.
The board that comes with the kit is junk if you want to learn about arduino and robots. The board has a microprocessor on it plus it requires an arduino. It's difficult to modify the examples if you want to build modifications or do your robot. It's only good if you don't wish to learn Arduino and you only want to follow the book and buy the add-on kits.
If you get rid of the board and use your own motor controller, I think it's a nice kit.
Dave
EL-Costello
This one is not released to the public yet, but if you can wait for about two month, you'll get something extraordinary.
  http://forum.arduino.cc/index.php?topic=259006.0
http://www.youtube.com/watch?v=DmtkGnRQJz8
kevin789900
Great feedback on this thread.  Anyone try a kit/chassis like this?  http://amzn.com/B00KNS1AF8
