Topic: Need sometime a reboot for receiving call/sms (Read 1 time) previous topic - next topic
PierluigiRovere
Jul 04, 2014, 09:37 am Last Edit: Jul 04, 2014, 09:42 am by PierluigiRovere Reason: 1
Hi all!
I searched in this forum a problem like this, but i didn't found nothing.
I made a sketch for commanding 3 relays with a call or and sms.
I'm using Arduino UNO rev.3  with an original GSM Shield (with a Vodafone SIM that works correctly).
I don't understand why sometime i need to restart Arduino after the power on, because the "gsmSMS.available()" and "gsmCall.getvoiceCallStatus()" doesn't work (or 2 or 3 consecutive restart).
When i finally receive the first sms, Arduino starts to work correctly until the next Sketch upload or power OFF.
Code: [Select]
#include <GSM.h>
GSM gsmAccess;
GSMVoiceCall gsmCall;
//GSMScanner gsmNetwork;
GSM_SMS  gsmSMS;
const int intDefaultGSMDelay = 2000; // prima di ricontrollare un nuovo stato, devo attendere almeno un secondo
boolean blnGSMConnection = false;
char* lstAllowedPhone[3]={"123456","123456"};   //Contiene la linsta dei numeri abilitati ai comandi
char* lstAllowedPhonePlusNumber[2]={"+39123456,"+39123456"}; //Stessa lista di prima, ma con il carattere + iniziale
const int intPinGate = 8;
const int intPinSmallGate = 9;
const int intPinDoor = 10;
const int intPinGSMCom = 13;
const int intOpenSmallGate = 1;
const int intOpenGate = 2;
const int intOpenDoor = 3;
const int intDelayRelayCmd = 1500;
//-----------------------------------------------------------------------------------------------------CONFIGURAZIONE----------------------------------------------------------------------
 //Serial.begin(9600);
 pinMode(intPinGate,OUTPUT);
 pinMode(intPinSmallGate,OUTPUT);
 pinMode(intPinDoor,OUTPUT);
 pinMode(intPinGSMCom,OUTPUT);
 digitalWrite(intPinGSMCom,LOW);  //Led di stato a Zero
 IniRelays();
 while(!blnGSMConnection)
   Serial.println(gsmAccess.getStatus());
   if (gsmAccess.begin("")==GSM_READY)  //gsmAccess.begin("",true,false), Inizializzazione Scheda SIM : PIN, Restart, Async
     blnGSMConnection = true;
 gsmCall.hangCall();
 digitalWrite(intPinGSMCom,HIGH); //Set Up OK
//--------------------------------------------------------------------------------------------------------LOOP------------------------------------------------------------------------------------------
 OpenOutPut(intCheckIncomingAction());
 //gsmNetwork.getSignalStrength()); //Leggo la qualità del segnale [0-31]
//--------------------------------------------------------------------------------------------------------INVIO COMANDO----------------------------------------------------------------------------------------------
void OpenOutPut(int intType)
 switch (intType)
   case intOpenSmallGate:
     SendCommand(intPinSmallGate);
   case intOpenGate:
     SendCommand(intPinGate);
   case intOpenDoor:
     SendCommand(intPinDoor);
//-------------------------------------------------------------------------------------------------------------GESTIONE RELE (PUSH BUTTON)---------------------------------------------------------------------------------------
void SendCommand(int intDevice)
 digitalWrite(intDevice,LOW);
 delay(intDelayRelayCmd);
 digitalWrite(intDevice,HIGH);
//-------------------------------------------------------------------------------------------------------------INIZIALIZZAZIONE RELE (OFF)---------------------------------------------------------------------------------------
void IniRelays()
 digitalWrite(intPinSmallGate,HIGH);
 digitalWrite(intPinGate,HIGH);
 digitalWrite(intPinDoor,HIGH);
//----------------------------------------------------------------------------------------------------------------SCANSIONE CHIAMATA/SMS----------------------------------------------------------------------------
int intCheckIncomingAction()
 int intResult = 0;
 boolean blnNumAllowed = false;
 char InComingNumtel[20]; //Contiene il numero del telefono chiamante o il mittente dell'sms
 if (gsmSMS.available())
   gsmSMS.remoteNumber(InComingNumtel, 20);
   blnNumAllowed = blnCheckNumer(InComingNumtel);
    if (blnNumAllowed)
      boolean blnFind = false;
      char chrSMSText;
      char strSMSText[255];
      int intIndex=0;
      while (chrSMSText = gsmSMS.read()) //devo compormi il messaggio, leggendo carattere per carattere
        strSMSText[intIndex] = chrSMSText;
       intIndex = intIndex +1;
      strlwr(strSMSText); // trasfromo la stringa in minuscolo
      if (strcmp(strSMSText,"cancelletto") == 0 || strcmp(strSMSText,"portina") == 0)
        intResult = intOpenSmallGate;
        if (strcmp(strSMSText,"cancello") == 0)
          intResult = intOpenGate;
          if (strcmp(strSMSText,"porta") == 0 || strcmp(strSMSText,"portone") == 0)
          intResult = intOpenDoor;
       memset(strSMSText,0,sizeof(strSMSText)); //pulisco Array
    gsmSMS.flush(); //cancello l'sms
   switch (gsmCall.getvoiceCallStatus())
     case IDLE_CALL: // Nothing is happening
     case RECEIVINGCALL: // Yes! Someone is calling us
         gsmCall.retrieveCallingNumber(InComingNumtel, 20);  //Recupero il numero chiamante
         if (blnNumAllowed)
         gsmCall.hangCall();  //Per rispondere alla chiamamta : gsmCall.answerCall()
     case TALKING:  // In this case the call would be established
 delay(intDefaultGSMDelay);
 return intResult;
//-----------------------------------------------------------------------------------------AUTORIZZAZIONE UTENTE-----------------------------------------------------------------------------------
boolean blnCheckNumer(char* chNumber)
   for (int intIndex = 0; intIndex < sizeof(lstAllowedPhone)-1; intIndex++)
       if (strcmp(chNumber,lstAllowedPhone[intIndex]) == 0 || strcmp(chNumber,lstAllowedPhonePlusNumber[intIndex]) == 0)
         blnFind = true;
   return blnFind;
note: if i enable the gsm debug it works correctly.  O_O'
this is the LOG:
00
AT%13%
0 9>AT%13%%13%%10%OK%13%%10%
AT+CGREG?%13%
9 40>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
40 71>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
71 102>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
102 5>AT+CGREG?%13%%13%%10%+CGREG: 0,1%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
5 22>AT+IFC=1,1%13%%13%%10%OK%13%%10%
AT+CMGF=1%13%
22 40>%19%%17%AT+CMGF=1%13%%13%%10%OK%13%%10%
AT+CLIP=1%13%
40 56>AT+CLIP=1%13%%13%%10%OK%13%%10%
ATE0%13%
56 67>ATE0%13%%13%%10%OK%13%%10%
AT+COLP=1%13%
67 73>%13%%10%OK%13%%10%
ATH%13%
73 79>%13%%10%OK%13%%10%
AT+CMGL="REC UNREAD",1%13%
79 85>%13%%10%OK%13%%10%
85 91>%13%%10%OK%13%%10%
91 97>%13%%10%OK%13%%10%
97 103>%13%%10%OK%13%%10%
103 109>%13%%10%OK%13%%10%
109 4>%13%%10%OK%13%%10%%13%%10%+CMTI: "SM",1%13%%10%
4 89>%13%%10%+CMGL: 1,"REC UNREAD","+393402631404","","2014/07/04 09:41:04+08"%13%%10%cancello%13%%10%%13%%10%OK%13%%10%
AT+CMGD=1%13%
89 95>%13%%10%OK%13%%10%
95 101>%13%%10%OK%13%%10%
101 107>%13%%10%OK%13%%10%
107 113>%13%%10%OK%13%%10%
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
