Topic: Does Arduino have a future? (Read 63764 times) previous topic - next topic
Or raspberry pi model S. S looks like a 5.
I believe it has to do with how the "product" has been developed. The software will never be industry strength (high quality) due to how it is handled by the "company". It is a lot of modified application notes and student projects.
Dear kowalski
Saying that arduino is a bunch of modified application notes etc is the usual boring rhetoric.. It's no longer like that.
Our code works in production in thousands of real projects used by real companies.
A lot of "professional" code can be declared so simply because it is closed source so nobody knows what the hell is in there but there is a LOT of crap believe me.
BTW if you see any low quality code in Arduino please lend to the community your excellent skills and submit a pull request :)
Dec 22, 2015, 12:26 am Last Edit: Dec 22, 2015, 12:29 am by kowalski
@Massimo Banzi
I approach contributing to Arduino in a very different way. For little over three years I have developed an object-oriented framework, Cosa, that replaces the Arduino core. I have used my experience from teaching object-oriented design and operating systems, and many years of large scale embedded systems development to provide examples on how to get to the next level.
Cosa is a framework where the classes are designed to work together and with advanced variant handling. There are interfaces for both libraries and device driver developers. It is high performance with X5-X10 compared to the basic Arduino/Wiring functions. And provides many of the mechanisms that are missing in the Arduino core.
The Arduino IDE and core are very much entry level and very good at that. There is a need for support for larger projects, development processes and more advanced software concepts - the next level. It is not possible to retro fit a better architecture (unfortunately).
Please feel free to contribute to Cosa :)
Merry Christmas and Happy New Year!
Very pleased to see Arduino SRL (.org) and Arduino LLC (.cc) starting to make amends.
Website, Forum, Product Catalogs, GitHub repos and IDE merges will be good.
Will be interesting to see how they handle board manufacturing and new partner alliances (STM).
Quiero una vida simple en Mexico...nada mas.
I'm glad they are now working together. I hope the arduino srl will not use any low-quality regulator that goes into thermal shutdown when 12V is connected for more than a few minutes. Almost ruined a whole project. A dozen devices behaved strangely.
Oct 19, 2016, 07:57 pm Last Edit: Oct 19, 2016, 08:05 pm by technix
We might as well stop using linear regulator entirely. Switch-mode controllers with built-in switches and synchronous rectifier are fairly cheap now, and can increase both board efficiency and maximum current available at the same time.
I have cooked up a design that is largely identical to Uno but had three changes, one of them being replacing both AMS1117-5.0 and LP2980-3.3 linear regulators with TPS562200. That chip comes in the same SOT-23-5 package as LP2980-3.3, but it can push out 2A maximum, use small magnetics at the size of 5650 or smaller, and have a minimum power efficiency of 75% at zero load. If you are interested I can publish it under 3-clause BSD license. The same power delivery system is also used on my Uno-compatible STM32F103CB/STM32L152CC development board.
On my STM32F103CB board, with the CPU running idle at 72MHz, one power LED and a blinking indicator LED on, and a significant portion of onboard peripherals enabled, the board draws no more than 50mA when powered by only USB. And when powered by +12V barrel jack no component on the board get warm. So if we move the board to switch-mode converters we can cut a big chunk out of the energy consumption, and eliminate warm components almost entirely.
Oct 26, 2016, 09:18 pm Last Edit: Oct 26, 2016, 09:20 pm by ODwyerPW
ARM (a.k.a Sofbank) announced new Cortex-M family members based on a 32-bit implementation of the ARMv8-M architecture.
Cortex-M23 which inhabits the M0, M+ space with good efficiency improvements
Cortex-M33 which seems a good upgrade to both M3 and M4 processors.
No details on clock speeds.
Atmel (a.k.a. MicroChips) and STMElectronics have both signed on as partners for the processors.
It will be interesting to see if Atmel releases MicroControllers suitable for new Arduinos. (e.g. maybe a SAMD23, SAM33X or SAM4X variant). With Arduino.org using a Cortex-M4 based STM32F469 microcontroller from STMElectronics, who knows which direction the folks will go for future boards. (we've had some toe dipping with Intel and TI by the Arduino folks... Now we have STM)
Announcements hinted at high performance variants to come (think Cortex-M73 or whatever they decide to name it) that will reside in the current Cortex-M7 space.
Arduino.org was at the "ARM TechCon" tradeshow...  It was sort-of amusing to see "a parent" of Arduino present for the first time at a show where multiple other vendors have been showing "Arduino form-factor" boards for years...
ARM's announcement:  https://community.arm.com/groups/processors/blog/2016/10/25/cortex-m23-and-cortex-m33-security-foundation-for-billions-of-devices
They seem to be selling it primarily from an "enhanced security" point of view.
I guess it won't be clear how it stands in the power-use range until there are actual implementations (it's interesting that there are already "respected" vendors offering CM4 chips for their "low power" range, rather than going to M0/M0+.)
It'll be nice to have "divide" and some of the other instructions back...
I saw another indication of the cooperation between the two Arduino entities today. I went to arduino.org to see if I could purchase the Star Otto yet.  When I select purchase and went to the Arduino store, I saw that I was now in arduino.cc land.. their store. Interesting.
Aug 29, 2017, 12:07 am Last Edit: Aug 29, 2017, 06:49 am by ODwyerPW
Resurrecting this thread in light of the Arduino AG acquisition that was finalized today. Get to work guys.
Response to this Blog announcement.
I feel that AVR is falling behind ARM...
And now that the esp has come around it seems even further behind
Well, that's a certainty.  AVR is essentially  a "legacy" architecture, while ARM is still evolving.  In theory, it doesn't matter as long as the AVR is "enough" for a particular application.
I guess the big "danger" is that "CircuitPython" will get fast enough and cheap enough to implement the things people want to do, while being much "friendlier" than Arduino.  So far, I haven't decided whether I'm UN-impressed by Python on a 256k 48MHz ARM with an extra 2Mb flash being "almost enough" for people to use, or stunned that those boards are the same price as the 32k AVR Arduinos.
(It wasn't that long ago that there were a bunch of Embedded Java computers that were going to take over the areas where Arduinos and WeMos board now prevail.  You haven't hear much recently about SunSpots, Jini, or Javelin Stamps, have you?)
Since the OP was written in 2014, and worried that Tre would replace AVR Arduini, the Tre has disappeared and AVR Arduini continue, despite several attempts to wreck the Arduino company.
CircuitPython™ is a bit of a joke I think, MicroPython already seems to be killed with multiple incompatible forks.
Far from not having a future, I am wondering what it would take to kill AVR Arduino! Even if Microchip dropped the ATMega (which is very unlikely), there are clone AVR devices. If Arduino AG folded, there are probably enough interested parties who would pick up development of the IDE etc.
It looks like the Arduino Uno will literally be with us forever now.
Please ask questions in the forum so everyone can benefit. PM me for paid work.
Arduino may have many faults, but it is very versatile. The Arduino TRE will always be an arduino board, with all Arduino's pros and cons, and with the Arduino IDE. Arduino should update many things in the boards, but given that it was born to teach, it is very good.
This is what I think.
