Topic: Dual axis tracker design (Read 5586 times) previous topic - next topic
AJITnayak
Jul 14, 2014, 12:34 pm Last Edit: Jul 14, 2014, 12:50 pm by AMPS-N Reason: 1
Dear all,
I am trying to design dual axis tracker using arduino due/mega. Here i am attaching  output table got from arduino mega for
http://www.pveducation.org/pvcdrom/properties-of-sunlight/elevation-angle
http://www.pveducation.org/pvcdrom/properties-of-sunlight/declination-angle
http://www.pveducation.org/pvcdrom/properties-of-sunlight/solar-time
above formula i used to get Mc zenith and Mc azimuth on  arduino megA controller.
The zenith and azimuth i got from below calculator
http://www.nrel.gov/midc/solpos/spa.html
For dual axis tracker i am using
2 linear actuator(24v,3A,400~600mm stroke length & 10000N load capacity) for N-S & E-W angle tracking.
Inclinometer1 (0~90deg,0~5v analog) for N-S direction
Inclinometer2 (0~360deg,0~5v analog) for E-W direction
2 limit switches /reed switches for stopping motor when desired position reached.
Now my question here
1) how to use zenith and azimuth angle in dual axis tracker??
2) if i use zenith and azimuth angle as for example in table attached around 12:30 it goes to 330 degree is it right or wrong.
3)Any change in the equation to be made to determine sun position.
4) if any help me with pseudo code like how can make it work will be appreciable.
Code: [Select]
Move_azimuth()
if((Azimuth_calc-Azimuth_inc)>=1.0 ))
     Motor_action=REV;
     }else
          Motor_Action=FW;
if(Limit_Switch==1&& Azimuth_calc==360)
  Motor_action=Stop;
Move_zenith()
if((zenith_calc-zenith_inc)>=1.0 ))
     Motor_action=REV;
     }else
          Motor_Action=FW;
if(Limit_Switch==1&& zenith_calc==360)
  Motor_action=Stop;
AMPS
PeterH
1) I assume you mean a dual axis solar tracker, since this is what you keep asking about. If you don't know what zenith and azimuth angles are, Google them. Then it should be obvious how they apply to a solar tracker.
2) Since nobody but you knows what angle you are referring to or whether that is the correct value for the time and location of the test, only you can answer that question. Fundamentally, you need to know what the desired behaviour is before you can test it, and if you don't understand what behaviour you want then stop and work that out before you go any further.
3) If the equation produces the correct answer, then it is good enough. If it doesn't, it isn't.
4) At the moment I don't understand whether the code you have is complete and whether it works correctly. If you are asking for advice about solving a problem with your project you need to be clear what problem you're asking for advice about. If you just want somebody to work along with you and help you design and implement your solution you should be asking for help in the Gigs and Collaborations section of the forum. Note that most people would expect to be paid for working for you.
AJITnayak
Now currently i came to stage where i found zenith and azimuth angle. I calculated those angle and compare with calculated upto  50 years from now, based on above links. i got offset 0.1 degree~0.5 degree some time.
My problem is i dont know how to use this angle to determine sun position.
check this animation
http://astro.unl.edu/classaction/animations/coordsmotion/altazimuth.html
I am confused with how this angle being taken in calculation. because various people different angle for calculation.
SO my question is how could i take these angle adjust my tracker position???
AMPS
PeterH
I suspect you have misunderstood what azimuth and zenith angles are. They give you a direction relative to your location. If you calculate them for the position of the sun, they give you the direction to the sun. Having calculated them for the sun's position you don't "determine sun position" from them - they are the answer, expressed as an azimuth and zenith angle.
AJITnayak
#4
Jul 14, 2014, 02:07 pm Last Edit: Jul 14, 2014, 02:09 pm by AMPS-N Reason: 1
If that case ,
how can determine the sun position. In below code
http://kokoraskostas.blogspot.gr/p/include-timer.html
why he adjusting  tracker position to zenith and azimuth angle. Can you elobrate so i can understand proper manner .
is there any relation that gives sun postion depend on zenith and azimuth,
If i am wrong, Once we know Direction of sun how can we find sun position.
Quote
AMPS
Robin2
Why do you need zenith and azimuth to track the sun?  Four light dependent resistors (LDRs) and 20 or so lines of code should do it without any complicated maths.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
PeterH
You still don't seem to understand what azimuth and zenith angles are. If you calculate the position of the sun in terms of azimuth and zenith angles, that tells you where the sun is relative to you i.e. which direction, and how far above the horizon. You don't "find" the position of the sun from that - it is the position of the sun, expressed as azimuth and zenith angles. It is the answer to the question of which direction do you need to point your solar collector, or whatever it is that you want to track the sun.
Your remaining problem then is to convert from azimuth/zenith coordinates to actuator positions. How you do that depends on the design of the actuators and whatever mechanism you use to read their position, but it would be straight forward trigonometry.
jremington
#7
Jul 14, 2014, 05:10 pm Last Edit: Jul 14, 2014, 05:28 pm by jremington Reason: 1
The "zenith position" of the sun is where it is in the sky at the high point, at about local noon, so that doesn't do you any good for a solar tracker.
What you want are the altitude and azimuth coordinates (in the local horizontal coordinate system) of the sun at any time during the day. They are described here: https://en.wikipedia.org/wiki/Horizontal_coordinate_system
Given those coordinates, it is a matter of very simple geometry to set up a device that points a panel in the proper direction.
Edit: sometimes the altitude angle is referred to as the elevation, as done by the NOAA solar position calculator.
PeterH
The term 'zenith angle' is also used to refer to the angle between the zenith (i.e. local vertical) and the position of interest. In other words it is the complement of the altitude angle aka elevation.
AJITnayak
My location is INDIA ,
12.9667° N, 77.5667° E
Code: [Select]
I cant understand this statement
Below link gives elevation angle.
http://en.wikipedia.org/wiki/Solar_zenith_angle
http://www.susdesign.com/popups/sunangle/altitude.php
Actually i am getting output from Nrel C code.
Julian Day:    2452930.312847
//L:             2.401826e+01   earth heliocentric longitude [degrees]
//B:             -1.011219e-04 degrees earth heliocentric latitude [degrees]
//R:             0.996542 AU earth radius vector [Astronomical Units, AU]
//H:             11.105902 degrees observer hour angle
//Delta Psi:     -3.998404e-03 degrees
//Delta Epsilon: 1.666568e-03 degrees
//Epsilon:       23.440465 degrees
//Zenith:        50.111622 degrees
//Azimuth:       194.340241 degrees
//Incidence:     25.187000 degrees
//Sunrise:       06:12:43 Local Time
//Sunset:        17:20:19 Local Time
AMPS
AJITnayak
after all.
I understood that altitude/ elevation gives exact position of the sun. Which i converted to my inclinometer angle
The altitude angle is calculated as follows:
Altitude =asin( [cos (L) * cos (D) * cos (H)] + [sin (L) * sin (D)])
Converted angle is
sun_pos=90-altitude; in degree.
where:
Al = Solar altitude angle
L = Latitude (negative for Southern Hemisphere)
D = Declination (negative for Southern Hemisphere)
H = Hour angle
If i am correct these relation works. let me know if i am wrong here,
2) Now we know zenith, azimuth which represent direction of sun & altitude represent sun position .
My question
1) which are angle need to be consider for the sun position for dual axis tracker
2) When to actuate the motor/actuator???
3)@ which situation limit switch are triggered  for dual axis tracker.
Here i have also attached output file.
AMPS
dave-in-nj
If you are looking to control your mirror for a heliostat or solar tracker, you can use this site
http://www.cerebralmeltdown.com/arduino-sun-tracking-heliostat-program-documentation/
if you are looking for something else, then this site walks you thorough the steps and offers some answers about why it was done a certain way.
AJITnayak
My question Here is Which are the angle need to consider & why.
How could track sun based on These angle.
As links attached above says i.e zenith & azimuth angle use to measure direction of sun & altitude to postion.Which are angle need to consider & why???
In all arduino based tracker they used LDR and moving along zenith and azimuth . Since i am using inclinometer  , how considered angle
AMPS
PeterH
You need to know your current position and the current time. You need to calculate the direction of the sun at that position and time, for example as an azimuth angle and zenith/elevation angle. You need to position your actuators to point your device in that direction. You need to repeat this periodically so that the device tracks the sun as it moves. I'm sorry if it sounds patronising to explain something so basic after you've spent this much time working on a solar tracker, but from the way you keep asking about it I'm not at all sure you have grasped the concept.
AJITnayak
if i am not wrong . I cant also express what i have understood due improper sentence
Please answer with yes or no. If not why??
These points are expected or not
1) zenith and azimuth gives sun direction right ya wrong??
2) altitude give sun elevation angle right ya wrong??
3)for dual axis tracker i need to consider azimuth along x dir that circular and altitude angle y direction for vertical motion.
The respective angle for day is attached in below . it relevant to one day. ?? Please let me know whether i calculated right or wrong.
formula taken from herehttp://www.susdesign.com/popups/sunangle/altitude.php
Quote
current time : is calculate from RTC
current position?: still not confirmed
i considered azimuth and altitude angles to determine position.
since actuator as no feedback , i am using inclinometer to adjust angle from reference 0~360 degree  and 0~90 degree.
AMPS
