I have a website set up with placeholders for temperature and humidity in the HTML. I am trying to output the DHT11 temperature and humidity data to the webpage but having looked around on the internet can't figure out how to do it.
There are lots of tutorials on how to gather the DHT11 and display on a webpage generated using the Ethernet shiedl (ie HTML within the Arduino sketch using client.println(".....")), but I can't find anything anywhere saying how I can show the data on a completely external webpage.
I suspect I need to do something with "GET" or "POST" (not sure which), but I'm new to this so not actually sure what that means or how to go about this.
In other words, I can see that the below sketch will client.println or serial.println the values, but how do I pick these up in my html code?
ie,
<p>"DHT temperature reading goes here"<\p>
Any help appreciated.
Sketch I'm trying to adapt below:
/* YourDuino Ethernet Temperature/humidity Web Server
Reads a DHT11 Sensor
Outputs a web page with Temperature and Humidity
terry@yourduino.com
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* DHT11 Sensor connected to Pin 2
Based on code by David A. Mellis & Tom Igoe
/*-----( Import needed libraries )-----*/
#include <SPI.h>
#include <Ethernet.h>
#include <dht11.h>
#include <Wire.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define DHT11PIN 2 // The Temperature/Humidity sensor
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/*-----( Declare objects )-----*/
IPAddress ip(192,168,1, 120);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
dht11 DHT11; //The Sensor Object
/*-----( Declare Variables )-----*/
void setup() /****** SETUP: RUNS ONCE ******/
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
}//--(end setup )---
void loop() /*----( LOOP: RUNS OVER AND OVER AGAIN )----*/
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
client.print("Hi Mary Alice!");
client.println("
/*----(Get sensor reading, calculate and print results )-----------------*/
int chk = DHT11.read(DHT11PIN);
Serial.print("Read sensor: ");
switch (chk)
case 0:
Serial.println("OK");
break;
case -1:
Serial.println("Checksum error");
break;
case -2:
Serial.println("Time out error");
break;
default:
Serial.println("Unknown error");
break;
client.print("Temperature (C): ");
client.println((float)DHT11.temperature, 1);
client.println("
client.print("Temperature (F): ");
client.println(Fahrenheit(DHT11.temperature), 1);
client.println("
client.print("Humidity (%): ");
client.println((float)DHT11.humidity, 0);
client.println("
client.print("Temperature (K): ");
client.println(Kelvin(DHT11.temperature), 1);
client.println("
client.print("Dew Point (C): ");
client.println(dewPoint(DHT11.temperature, DHT11.humidity));
client.println("
client.print("Dew PointFast (C): ");
client.println(dewPointFast(DHT11.temperature, DHT11.humidity));
client.println("
/*--------( End Sensor Read )--------------------------------*/
client.println("</html>");
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
} // END Loop
/*-----( Declare User-written Functions )-----*/
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
double A0= 373.15/(273.15 + celsius);
double SUM = -7.90298 * (A0-1);
SUM += 5.02808 * log10(A0);
SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
SUM += log10(1013.246);
double VP = pow(10, SUM-3) * humidity;
double T = log(VP/0.61078); // temp var
return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity/100);
double Td = (b * temp) / (a - temp);
return Td;
/* ( THE END ) */
