Topic: Flash and Fade (Read 7396 times) previous topic - next topic
BulldogLowell
at this point, he may be better to go back to pseudo code:
it looks like you may want to fade up/down when your analog pin returns greater than 630, yes?
it looks also like you want to turn on a 2nd LED all the time but then only for a finite interval of time once the analog pin returns  less than 630, yes?
it also looks like you want all of the LEDs off when the analog pin returns full voltage, or 1023, yes?
edgaryo
yes the value of sensor is > 630 then all leds is off
when sensor value is < 630 , first led is flash , and another led is fadeing . But ONE TIME . After the loop is repet
edgaryo
#17
Jul 17, 2014, 11:51 pm Last Edit: Jul 17, 2014, 11:54 pm by edgaryo Reason: 1
And the first led is important to stay on 100 ms ( only flash , like a camera flash )
BulldogLowell
OK, then look at this:
Code: [Select]
byte ledPin = 13; // This led is flash
int led = 9;           // this led is fadeing
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
int turnLedOffAfterTime = 100;
  pinMode( ledPin, OUTPUT );
  if ( analogRead( A0 ) < 630)
    flashLedPinOnce();
    fadePinNine();
    allPinsOff();
void flashLedPinOnce()
void fadePinNine()
void allPinsOff()
we are going to build off of this.  Does it look OK?  Do we need to add a condition regarding the high pin reading of A0?
edgaryo
Code: [Select]
    flashLedPinOnce();
    fadePinNine();
    allPinsOff();
void fadePinNine()
void allPinsOff()
is very ok ! This is all wath i need :D .
BulldogLowell
OK, we will fade the pin in this example...
look at what we did here. and try it.  It should fade your led (but not flash ledPin yet) and stop when your value of A0 gets higher than your magic number 630.
Code: [Select]
  if ( analogRead(A0) < 630)
    flashLedPinOnce();
    fadePinNine();
    allPinsOff();
void fadePinNine()
  brightness = brightness + fadeAmount;
  analogWrite(led, brightness);
  if (brightness == 0 || brightness == 255);
  fadeAmount = -fadeAmount ;
void allPinsOff()
  digitalWrite(led, LOW);
edgaryo
is fadeing but is in a loop , and is not stop . . .  i need to stop , to fade one time . Then i active another date sensor , led is fade another time . . .  is like flash , but is not flashing is fade . . .   Just one time, and is repet after i active the sensor , not how long is active sensor .
BulldogLowell
#22
Jul 18, 2014, 12:39 am Last Edit: Jul 18, 2014, 12:41 am by BulldogLowell Reason: 1
OOPS, had to edit...
OK,
Look at this and look at the Flash only, is this what you want?
look at what we did, we added a timer to the flash...
Code: [Select]
unsigned long turnLedOffAfterTime = 100UL;
unsigned long startTime;
boolean readyToFlash = true;
    if (readyToFlash)
      startTime = millis();
      flashLedPinOnce();
    fadePinNine();
    allPinsOff();
  digitalWrite(ledPin, HIGH);
  if (millis() - startTime >= turnLedOffAfterTime)
    digitalWrite(ledPin, LOW);
    readyToFlash = false;
void fadePinNine()
void allPinsOff()
we can make the fade once too... check this first!
edgaryo
now the flas is not work wery good , because the led is not flash with all his intensity  ( just some time is flash with all intensity ).
BulldogLowell
yeah, sorry.
Try this for flashing:
Code: [Select]
boolean flashing = false;
    if (readyToFlash)
      if (flashing = false) startTime = millis();
      flashLedPinOnce();
    fadePinNine();
    allPinsOff();
  flashing = true;
    flashing = false;
void fadePinNine()
void allPinsOff()
edgaryo
no , is not working , is have only 30 % from his intensity
BulldogLowell
Quote
Are you talking flash led or fade led?
forget about the fade for now, but i fixed that line too.
does the led blink only once when the sensor is below 630?
Code: [Select]
    if (readyToFlash)
      flashLedPinOnce();
    fadePinNine();
    allPinsOff();
  flashing = true;
    flashing = false;
void fadePinNine()
  if (brightness == 0 || brightness == 255) fadeAmount = (-fadeAmount);
void allPinsOff()
edgaryo
yes i say about the FLASHING LED :( ... if you want i can make you a video to see :| ....
edgaryo
is work but intensity is the problem :(
BulldogLowell
#29
Jul 18, 2014, 01:08 am Last Edit: Jul 18, 2014, 01:22 am by BulldogLowell Reason: 1
well... we will look when we are done with fade.
See if this fades your LED right, once up and down...
Code: [Select]
boolean fadeOn;
   if (readyToFlash)
     flashLedPinOnce();
   if (fadeOn == true) fadePinNine();
   allPinsOff();
   fadeOn = true;
 flashing = true;
   flashing = false;
void fadePinNine()
 if (brightness == 0)  fadeOn = false;
void allPinsOff()
