Topic: Flash and Fade (Read 6901 times) previous topic - next topic
edgaryo
no , is not fade ... is stay only on or off
edgaryo
so... what we doing now :(  ?
billhowl
BulldogLowell
I think it is time to see your hardware configuration...
edgaryo
i have :
-Arduino UNO
-2 LEDs ( 5mm )
-Distance sensor : http://www.pololu.com/product/1132
BulldogLowell
#35
Jul 18, 2014, 02:56 pm Last Edit: Jul 19, 2014, 12:13 am by BulldogLowell Reason: 1
not familiar with that sensor...
So, put some debug in the code and look at the serial monitor to see what's happening when you get close/far from the sensor.
Code: [Select]
byte ledPin = 13; // This led is flash
int led = 9;           // this led is fadeing
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
unsigned long turnLedOffAfterTime = 100UL;
unsigned long startTime;
boolean readyToFlash = true;
boolean flashing = false;
boolean fadeOn;
 pinMode( ledPin, OUTPUT );
 if ( analogRead(A0) < 630)
   Serial.println("close to sensor");
   if (readyToFlash)
     if (flashing == false) startTime = millis();
     Serial.println("FLASH");
     flashLedPinOnce();
   if (fadeOn == true) fadePinNine();
   Serial.println("far from sensor");
   allPinsOff();
   fadeOn = true;
void flashLedPinOnce()
 flashing = true;
 digitalWrite(ledPin, HIGH);
 if (millis() - startTime >= turnLedOffAfterTime)
   digitalWrite(ledPin, LOW);
   readyToFlash = false;
   flashing = false;
void fadePinNine()
 brightness = brightness + fadeAmount;
 analogWrite(led, brightness);
 if (brightness == 0 || brightness == 255) fadeAmount = (-fadeAmount);
 if (brightness == 0)  fadeOn = false;
void allPinsOff()
 digitalWrite(led, LOW);
edgaryo
Now is WORKING ! But is work only if i stay with sensor activ . I want to activ sensor a 0,5 second and led 1 flash and led 2 to fade
BulldogLowell
So, you can change that all in the variables at the top of the sketch.
edgaryo
No i want to say , i want to i activ the sensor 0.5 sec ( exemple ) and i want led with fade to make his loop , i mean his cycle . Now is make his cycle if i stay with sensor activ how hold the cycle ... I want to give a impulse to the sensor and led with fade to make his cycle
BulldogLowell
Do you mean to take a sensor reading each half second only. Then light the LEDs according to the reading?
edgaryo
if I act for half a second sensor, light to fade makes the cycle after cycle stand off until the next actuation of the sensor
BulldogLowell
Sorry, please help me understand. I think you want the sensor to wait while the LEDs are busy and then wait a half second before you want to take the next sensor reading.
edgaryo
no ... ... If sensor active Led is fadeing one time ; if is not activ Led is off .
But if activate sensor 1 milisecond the Led is going to fadeing . Now you understand what i want ? :(
BulldogLowell
You want to delay the flashing unless the signal is detected for more than some period of time. One half second.
Yes?
edgaryo
no , i want all in real time , no delay . I want when is active sensor , one led is make a flash , and another led to fade . That's all :( . The sensor is like a buton , if i push him ( but i not keep him down , just one clik ) one led is make a flash and the other is make fade .
