Topic: Flash and Fade (Read 7756 times) previous topic - next topic
BulldogLowell
Sorry, I thought that's what we just wrote.
Are you talking about a new input?  Very confused here....
edgaryo
nooo , i was compare my sensor with a button :D , only that . :D
BulldogLowell
Quote
no , i want all in real time , no delay . I want when is active sensor , one led is make a flash , and another led to fade . That's all . The sensor is like a buton , if i push him ( but i not keep him down , just one clik ) one led is make a flash and the other is make fade .
this is what we wrote.  The processor will sense a change in the level
Code: [Select]
if ( analogRead(A0) < 630)
without any delays in the code.  We are not using delays here.
Perhaps you can put into this what you mean, even if it is not correct:
Code: [Select]
    Serial.println("close to sensor");
    if (readyToFlash)
      if (flashing = false) startTime = millis();
      Serial.println("FLASH");
      flashLedPinOnce();
    if (fadeOn == true) fadePinNine();
    Serial.println("far from sensor");
    allPinsOff();
    readyToFlash = true;
    fadeOn = true;
AWOL
Code: [Select]
Oops
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
BulldogLowell
Code: [Select]
Oops
thank you... good eye.  Perhaps that was his issue.  fixed here:
Code: [Select]
byte ledPin = 13; // This led is flash
int led = 9;           // this led is fadeing
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
unsigned long turnLedOffAfterTime = 100UL;
unsigned long startTime;
boolean readyToFlash = true;
boolean flashing = false;
boolean fadeOn;
  pinMode( ledPin, OUTPUT );
    if (readyToFlash)
      if (flashing == false) startTime = millis();
      flashLedPinOnce();
    allPinsOff();
    fadeOn = true;
void flashLedPinOnce()
  flashing = true;
  digitalWrite(ledPin, HIGH);
  if (millis() - startTime >= turnLedOffAfterTime)
    digitalWrite(ledPin, LOW);
    readyToFlash = false;
    flashing = false;
void fadePinNine()
  brightness = brightness + fadeAmount;
  analogWrite(led, brightness);
  if (brightness == 0 || brightness == 255) fadeAmount = (-fadeAmount);
  if (brightness == 0)  fadeOn = false;
void allPinsOff()
  digitalWrite(led, LOW);
edgaryo
this code is not working . Is not work the Flash :(
AWOL
Quote
this code
I can't see your code.
I can't see a description of what it is doing.
Sorry, can't help you.
