Topic: Sending a signal through a cable (Read 2256 times) previous topic - next topic
Endevor
If I wanted to send a signal straight from an Arduino through a cable roughly, 5-6ft long to some LED drivers, should I do anything to the signal on the Arduino end to ensure the signal gets that far or should it be fine? I'm designing a PCB and curious if I should put something there before ordering them and realizing they're not going to work.
Peter_n
That is less than 2 meters, that is a short distance. The cable you are going to use can make a big difference (a difference of maybe 10 times).
What kind of signal, just on/off, or pwm, or I2C ?
Endevor
I'm hoping to send some PWN signals, a mix of hardware and software PWN. 8 signals total.
LMI1
Yes, 5-6feet is not so long. A lot depends on the transfer speed you use. If you just wait everything to settle up or get stable, you can use very long cables. Don't forget the earth wire/wires. With high speed and long cables you get transmission lines.
mart256
The less resistance the wire has, the merrier. To decrease resistance use copper wire with bigger area. I'd do some test before running the final design, never used PWM on wire longer than 30 cm.
Endevor
I guess it would probably not be a good idea to try and shoot a PWM signal 5ft. I'll have to find another way to get the signal from point A to point B.
CrossRoads
500 Hz PWM? That is slow. That would be fine. Are you send shiftOut( ) or SPI signals too?
MichaelMeissner
#7
Jul 19, 2014, 07:59 am Last Edit: Jul 19, 2014, 08:02 am by MichaelMeissner Reason: 1
One way to solve the problem for longer distances is put a microprocessor on the other end, and hook both up with RS485.  Then on the first processor, it just sends down requests (turn on PWM to this frequency, turn it off, turn on led, etc.).
I would use a microprocessor with serial support on each end, and not something like ATtiny85's.  That way, the RS485 handles error correction, etc. and you are not sending PWM signals down the line continuously.  You don't necessarily want an Arduino development system on each end.
Endevor
I have to be honest in saying, I'm not fully sure. I haven't done a whole lot on the coding side, I just know that at some point, I need a PWM signal for 8 LED drivers. I figured a wired connection would be the easiest to set up, and eventually move on to more innovative methods, but in the past, at least with PWM signals, I've gotten spotty results (Some work, some don't, some flicker, etc), but I think it was due to poor soldering and poor board design.
Eventually, that's actually what I want to do. Eventually I want several "sub"controllers in charge of remedial tasks while the main controller fine tunes and acts as the user interface. I was trying to start simple first, at least get something that works before moving on to more complicated additions, though the more I think about it, going ahead and adding the second controller would probably make it easier... Eventually I want to make it all bluetooth, but that's another hurtle for another time.
MichaelMeissner
Another thought if you were willing to live with i2c distances (something like 2m, but I don't actually recall), Adafruit sells a 16 channel i2c PWM controller that would off-load doing the PWM processing: https://www.adafruit.com/products/815
steinie44
Use RG-59 video/cctv cable. You can get well over 10'
Endevor
That actually looks perfect. That chip can sit right next to the drivers if need be, and I can send the 2 data pins required to control it through a cable, maybe just a simple USB cable to include 5V and GND. the longest distance I think I need is 6ft, and even then, that's plenty long enough to get from the bottom to the top of most standard aquariums if not all. that will also allow the control of up to 16 drivers instead of the original 8 in case I ever want to extremely overkill my lighting control.
Thanks!
MichaelMeissner
I would think using cat 5/6 ethernet cables would be better than using usb cables, since these cables are made for going distances and have 4 pair of stranded wires inside.  You can either cut up an existing 6foot/2m cable to solder individual wires or you can get breakout boards for cat 5 or 6, such as [ur]https://www.sparkfun.com/products/716[/url] + https://www.sparkfun.com/products/643.
charliesixpack
If you are driving led's you do not have to worry about line length.  You can figure about 20 mA per led and a 13 milliohms per meter for 16 gauge copper wire.  So if you have 100 led's at the end of a 2 meter wire you are only dropping 50 mV.  You certainly do not need coax.  Speed and bandwidth are not an issue since the eye cannot detect anything faster than around 10 Hz anyway.
