Topic: Barometric Presure sensor BMP180 (Read 35947 times) previous topic - next topic
ehrja
I'm Using the BMP180 sensor
The ting is that I plugged it into an arduino leonardo using 5 v, then reading the datasheet I realized that it has to be 3.3v so I change it, fortunately the sketch wasn't loaded and the arduino totally ignore the sensor so it will not work any way because the arduino did not start it.
then I load the example of the sparkfun library of the BMP180 sensor and the serial give me data:
So it is working normally
Code: [Select]
provided altitude: 1655 meters, 5430 feet
temperature: 36.95 deg C, 98.51 deg F
absolute pressure: 1007.49 mb, 29.75 inHg
relative (sea-level) pressure: 1230.48 mb, 36.34 inHg
computed altitude: 1655 meters, 5430 feet
temperature: 36.96 deg C, 98.52 deg F
absolute pressure: 1007.47 mb, 29.75 inHg
relative (sea-level) pressure: 1230.45 mb, 36.34 inHg
absolute pressure: 1007.46 mb, 29.75 inHg
temperature: 36.92 deg C, 98.46 deg F
absolute pressure: 1007.42 mb, 29.75 inHg
relative (sea-level) pressure: 1230.40 mb, 36.34 inHg
The temperature was ok hire is hoot right now.  but the elevation of my city is 10 - 30 meters over sea  level.
I don't know if I'm misunderstanding the provided altitude (1655 m) or if the sensor was damaged by the 5v in "Standby mode" or is because of the 5 v of the  arduino  IIC pins.
Can help me to understand what is going on?
Hola buenos días!
robtillaart
There is always a sketch loaded (maybe except for the very first time). So your sensor could be damaged.
You could write a bare bones sketch that reads the raw values from the sensor.
And see if it reacts on on pressure changes.
If it always gives same value the sensor is broken.
If it is not broken, the formulas used might be incorrect. But that is hard to see without code.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
michinyon
what is the code of your sketch ?
"provided altitude"  is something that your code has in it,  it is not coming from the device.
ehrja
#3
Jul 20, 2014, 09:50 am Last Edit: Jul 20, 2014, 10:27 am by ehrja Reason: 1
This is other tread where I ask for advice since I got the same problem using a code posted by @_Leo_ hire: http://forum.arduino.cc/index.php?topic=202816.msg1621373#msg1621373
the @sparkfun code and the one posted by @_Leo_ gave me different data as you can see if you check my first post in each treat, I post  the corresponding results of different codes in each treat, well... I din't notice that the inHg was really different for each code results, just notice that the data was to much to be true acording to the location data that i get from different media. except for the temperature that was ok for me.
some of you tell me that the sensor may be broken beacuse the reading is around 1500 hPa,  but the pressure value varies if I put it on an improvised vacuum pump.
I was tinking about the fact that I'm using an arduino Leonardo wich has 5v logic level.
I'm using that cheap sensor form ebay by the way
Hola buenos días!
Christo
The absolute pressure reading seems OK to me (if this is actually the sensor pressure reading), normal atmospheric pressure at sea level is 1013.25 millibar or about 29.9 inch Hg.  The sea-level pressure seems high, which could explain the wrong calculated elevation.
ehrja
I'm in near the sea, my city is just above the sea level that is way i think it is quite wrong
Hola buenos días!
jremington
If you want help, post the exact code that you are using.
ehrja
originaly posted by _Leo_
the code that i'm using
Code: [Select]
  Bosch Pressure Sensor BMP085 / BMP180 readout routine
  for the Arduino platform.
  Compiled by Leo Nutz
  www.ALTDuino.de
#include <Wire.h>
#define ADDRESS_SENSOR 0x77                 // Sensor address
int16_t  ac1, ac2, ac3, b1, b2, mb, mc, md; // Store sensor PROM values from BMP180
uint16_t ac4, ac5, ac6;                     // Store sensor PROM values from BMP180
// Ultra Low Power       OSS = 0, OSD =  5ms
// Standard              OSS = 1, OSD =  8ms
// High                  OSS = 2, OSD = 14ms
// Ultra High Resolution OSS = 3, OSD = 26ms
const uint8_t oss = 3;                      // Set oversampling setting
const uint8_t osd = 26;                     // with corresponding oversampling delay
float T, P;                                 // Set global variables for temperature and pressure
  Serial.begin(9600);                       // Set up serial port
  while(!Serial){;}                         // waith until leonardo serial port ready
  delay(5000);
  Wire.begin();                             // Activate I2C
    init_SENSOR();                            // Initialize baro sensor variables
  delay(100);
  int32_t b5;
  b5 = temperature();                       // Read and calculate temperature (T)
  Serial.print("Temperature: ");
  Serial.print(T, 2);
  Serial.print(" C, ");
  Serial.print(1.8 * T + 32.0, 2);
  Serial.println(" F");
  P = pressure(b5);                         // Read and calculate pressure (P)
  Serial.print("Pressure: ");
  Serial.print(P, 2);
  Serial.print(" mbar, ");
  Serial.print(P * 0.0295299830714, 2);
  Serial.println(" inHg");
  Serial.println("");
  delay(500);                               // Delay between each readout
  Initialize sensor variables
void init_SENSOR()
  ac1 = read_2_bytes(0xAA);
  ac2 = read_2_bytes(0xAC);
  ac3 = read_2_bytes(0xAE);
  ac4 = read_2_bytes(0xB0);
  ac5 = read_2_bytes(0xB2);
  ac6 = read_2_bytes(0xB4);
  b1  = read_2_bytes(0xB6);
  b2  = read_2_bytes(0xB8);
  mb  = read_2_bytes(0xBA);
  mc  = read_2_bytes(0xBC);
  md  = read_2_bytes(0xBE);
  Serial.println("");
  Serial.println("Sensor calibration data:");
  Serial.print(F("AC1 = ")); Serial.println(ac1);
  Serial.print(F("AC2 = ")); Serial.println(ac2);
  Serial.print(F("AC3 = ")); Serial.println(ac3);
  Serial.print(F("AC4 = ")); Serial.println(ac4);
  Serial.print(F("AC5 = ")); Serial.println(ac5);
  Serial.print(F("AC6 = ")); Serial.println(ac6);
  Serial.print(F("B1 = "));  Serial.println(b1);
  Serial.print(F("B2 = "));  Serial.println(b2);
  Serial.print(F("MB = "));  Serial.println(mb);
  Serial.print(F("MC = "));  Serial.println(mc);
  Serial.print(F("MD = "));  Serial.println(md);
  Serial.println("");
  Calcualte pressure readings
float pressure(int32_t b5)
  int32_t x1, x2, x3, b3, b6, p, UP;
  uint32_t b4, b7;
  UP = read_pressure();                         // Read raw pressure
  b6 = b5 - 4000;
  x1 = (b2 * (b6 * b6 >> 12)) >> 11;
  x2 = ac2 * b6 >> 11;
  x3 = x1 + x2;
  b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2;
  x1 = ac3 * b6 >> 13;
  x2 = (b1 * (b6 * b6 >> 12)) >> 16;
  x3 = ((x1 + x2) + 2) >> 2;
  b4 = (ac4 * (uint32_t)(x3 + 32768)) >> 15;
  b7 = ((uint32_t)UP - b3) * (50000 >> oss);
  if(b7 < 0x80000000) { p = (b7 << 1) / b4; } else { p = (b7 / b4) << 1; } // or p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
  x1 = (p >> 8) * (p >> 8);
  x1 = (x1 * 3038) >> 16;
  x2 = (-7357 * p) >> 16;
  return (p + ((x1 + x2 + 3791) >> 4)) / 100.0f; // Return pressure in mbar
  Read uncompensated temperature
int32_t temperature()
  int32_t x1, x2, b5, UT;
  Wire.beginTransmission(ADDRESS_SENSOR); // Start transmission to device
  Wire.write(0xf4);                       // Sends register address
  Wire.write(0x2e);                       // Write data
  Wire.endTransmission();                 // End transmission
  delay(5);                               // Datasheet suggests 4.5 ms
  UT = read_2_bytes(0xf6);                // Read uncompensated TEMPERATURE value
  // Calculate true temperature
  x1 = (UT - (int32_t)ac6) * (int32_t)ac5 >> 15;
  x2 = ((int32_t)mc << 11) / (x1 + (int32_t)md);
  b5 = x1 + x2;
  T  = (b5 + 8) >> 4;
  T = T / 10.0;                           // Temperature in celsius
  return b5;
  Read uncompensated pressure value
int32_t read_pressure()
  int32_t value;
  Wire.write(0xf4);                         // Sends register address to read from
  Wire.write(0x34 + (oss << 6));            // Write data
  Wire.endTransmission();                   // SEd transmission
  delay(osd);                               // Oversampling setting delay
  Wire.write(0xf6);                         // Register to read
  Wire.requestFrom(ADDRESS_SENSOR, 3);      // Request three bytes
  if(Wire.available() >= 3)
    value = (((int32_t)Wire.read() << 16) | ((int32_t)Wire.read() << 8) | ((int32_t)Wire.read())) >> (8 - oss);
  return value;                             // Return value
  Read 1 byte from the BMP sensor
uint8_t read_1_byte(uint8_t code)
  uint8_t value;
  Wire.write(code);                               // Sends register address to read from
  Wire.requestFrom(ADDRESS_SENSOR, 1);            // Request data for 1 byte to be read
  if(Wire.available() >= 1)
    value = Wire.read();                          // Get 1 byte of data
  Read 2 bytes from the BMP sensor
uint16_t read_2_bytes(uint8_t code)
  uint16_t value;
  Wire.requestFrom(ADDRESS_SENSOR, 2);            // Request 2 bytes from device
  if(Wire.available() >= 2)
    value = (Wire.read() << 8) | Wire.read();     // Get 2 bytes of data
Hola buenos días!
michinyon
If that is the code you are using,   then what it all the stuff about the "provided" pressure and altitude,  you had earlier ?
If you took any altitude-sensing device to Denver or Johannesburg,  and misled it into believing that it was at sealevel,    then when you actually went to somewhere at sealevel,   you would get a bogus answer.
The device is going to measure the actual pressure that it detects,  which is converts to an altitude using a "standard" formula for the relationship between pressure and altitude.
The problem is,  the atmospheric pressure varies because of the weather and other things,   and there are various ways to "adjust" for this.   Sometimes the adjustment scheme is more confusing than it really needs to be.
askjacob
#9
Jul 24, 2014, 06:29 pm Last Edit: Jul 24, 2014, 06:32 pm by askjacob Reason: 1
No fear, I was stuck with it too. It is not any issue you were worried about. It was a type casting problem.
Here in the example code, this was the issue:
ORIGINAL FUNCTION (replace this one)
Code: [Select]
 uint32_t b4, b7;
 b6 = b5 - 4000;
 x3 = x1 + x2;
FIXED FUNCTION
Code: [Select]
 uint32_t b4, b7;
 b6 = b5 - 4000;
 x3 = x1 + x2;
 b3 = (((uint32_t)(ac1 * 4 + x3) << oss) + 2) >> 2;
See the difference?
The rest of the code was fine, leave it alone for now!
That fixed it. A lot of head scratching for me as maths is not my forte and this stuff is pretty convoluted.
I hope this sorts it out for you.
My only guess as to why it may work for some people is that for some versions of arduino casting was handled differently.
Cheers
Jacob
_Leo_
Jacob,
thanks for that. It is a surprise to me that it would be the source of the problem for some!
I don't know how many different Arduino compiler versions I've run the code on. And from the hardware side UNO's and Pro minis.... The results always corresponded with the data sheet.
Would this have to do with the Leonardo? What is your setup?
It also shows me from now on to tell people with such or similar problems to use the data sheet variables to confirm the calculations.
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
ehrja
thanks askjacob and _Leo_
Well I also had wrong readings with the sparkfun library, but now I'm trying the adafruit library and it seems to work ok:
Code: [Select]
Temperature = 35.60 *C
Pressure = 101231 Pa
Altitude = 8.00 meters
Pressure at sealevel (calculated) = 101232 Pa
Real altitude = 22.55 meters
I'll try to make changes to the code posted by _Leo_ and also try it on Leonardo and a nano v3.0 and post the results.
Hola buenos días!
askjacob
#12
Jul 24, 2014, 11:34 pm Last Edit: Jul 24, 2014, 11:36 pm by askjacob Reason: 1
Hi Leo,
I wanted to use your code rather than the Adafruit library for 2 reasons really:
1: I have very little codespace left
2: Just "throwing another library at a problem" leaves little to learning
And did I get some learning done last night :)
Considering C and all it's variants are new to me (why did my university insist on Pascal?) - at least the strong background on type casting helped :) - I have been working hard on both the hardware and software aspects on my current project - hence using the arduino platform to speed things up rather than my usual route of rolling my own. Makes it easier knowing it is less likely to be a hardware issue...
Anyway, back on topic, the environment I have in place is:
Arduino Pro Mini 5v 16MHz 328  (Maybe the 328 is key here? Unsure why it would be a major difference other than ram space although I find more and more quirks with the arduino compiler as I go...)
Bosch BMP180 sensor on breakout with 3v3 supply (ebay special)
Various other i2c devices not currently in use in test code (now in use in full code, and happily co-existing), other than the oLED used as the debug display (rather than serial terminal)
I was getting 1480 - 1508 mbar readings (was actually 1008 compared to my weather station) until I fixed the casting. Once casting fixed - bingo - spot on.
By the way - I popped over to your website to see if there was any updated code, and instead was enthalled by the rocketry and altimeter stuff - amazing stuff :)
Cheers from Aus,
Jacob
magnetman
I have the same sensor and i used a bi-directional logic level converter for it to work. Also, the code i tested it with had altitude input, for a more exact pressure output.
I think you used same code when you got those high readings. Now I don't know if you can use it on 5 v logic level and get valid readings..
askjacob
#14
Jul 25, 2014, 12:49 am Last Edit: Jul 25, 2014, 12:52 am by askjacob Reason: 1
The code you tested it with would be the Adafruit Unified library. Dig inside the codebase, and you will find the exact same compenstation logic - taken from the same datasheet sample.
Once you dig in there - Adafruit also cast everything correctly, INCLUDING this example.
As mentioned, the issue appears to be how the compiler/environment handles default casting, if you leave it to the compiler to handle it (bad) you will get an unpredictable result based on how the author of your environment feels on the day. Isn't it better to strictly cast it anyway (good) to ensure you get it in the format you desire regardless? There is no overhead, and at best someone reading your code will also understand what is going on.
I should have mentioned all my i2c is at 3v3, although it is often mentioned that the BMP180 technically 5v tolerant on SDA and SCL - although the datasheet never points it out as the I2C specs are external to the device itself and another kettle of fish - it is about an ability to "drive" a voltage above a threshold cleanly without reflection/ringing (hence the termination resistors) and starts to enter the realm of throw stuff at it and see black magic once lines get long and more devices get added :)
Can we please STOP trying to tell me what it isn't in this case? it is not hardware or voltage. I am not a newbie to electronics or to code, just to the arduino environment (and c - c++) - which I am hopping into just because of the flood of cheap dev boards from china...Cheaper than I can get bare ATMegas for these days... I am happy to be wrong, but not happy to have the conversation derailed.
Regards
Jacob
