Topic: Barometric Presure sensor BMP180 (Read 36064 times) previous topic - next topic
michinyon
Quote
Also, the code i tested it with had altitude input, for a more exact pressure output.
This statement makes no sense.   This device measures pressure.
Knowing any other outside information ( other than the temperature,  which it measures itself ),   cannot make the pressure output "more exact".
Outside information can be used to make the altitude calculation "more exact".
michinyon
I think I had that sort of problem with the casting as well.  Not sure now,  it was a couple of years ago.  It took a while to get it to work,   I went through all those shift manipulations looking very closely at the bosch description.   It appears that some of the library code that people published for this device,   they never even tried running it.
I also recall seeing somewhere,  an alternative processing scheme that someone devised,  which used float instead of int ( or maybe the other way around ),   to get an output with less bit errors in it.   It looked very interesting but I did not implement it.
askjacob
#17
Jul 25, 2014, 02:25 am Last Edit: Jul 25, 2014, 03:02 am by askjacob Reason: 1
The Adafruit library allows you to put in a base altitude for more accurate altitude above sea level readings as that library also provides an altitude calculation. It has zero effect on the accuracy of anything else.
It also is no good for compensating any weather effects, so is more for experimentation - it is better to use a sample "ground level at now" and then measure differences rather than ever try to somehow measure an absolute above sea level with just a pressure sensor alone.
Normally if "altitude matters" you want to measure how high something went, or how high above the ground you are in the real time space, not how high above some arbitrary (sea level) number you are. You can always factor in the arbitrary number at another non-realtime time later if need be - well, according to my two cents anyway.
_Leo_
Arduino Pro Mini 5v 16MHz 328  (Maybe the 328 is key here? Unsure why it would be a major difference other than ram space although I find more and more quirks with the arduino compiler as I go...)
Bosch BMP180 sensor on breakout with 3v3 supply (ebay special)
Various other i2c devices not currently in use in test code (now in use in full code, and happily co-existing), other than the oLED used as the debug display (rather than serial terminal)
So essentially the same setup as I'm using except that mine are Pro Mini 3.3v boards.
Now, since I want to understand this to the fullest I'd like you to post your sensor variables for me please  :)
  ac1 =  ;
  ac2 = ;
  ac3 = ;
  ac4 = ;
  ac5 = ;
  ac6 = ;
  b1  = ;
  b2  = ;
  mb  = ;
  mc  = ;
  md  = ;
I'm going to try to replicate it.
By the way - I popped over to your website to see if there was any updated code, and instead was enthalled by the rocketry and altimeter stuff - amazing stuff :)
Thanks very much mate :)
Now imagine if I had the problem with my altimeter (I'm using the Bosch sensor in one of them) I'd be in serious trouble. Rockets aren't very forgiving. Either everything works out 100% or your doomed.
Leo
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
_Leo_
I tried to replicate the problem but can't.
Example:
Code: [Select]
Oversampling setting (oss) = 0
Sensor calibration data:
AC1 = 408
AC2 = -72
AC3 = -14383
AC4 = 32741
AC5 = 32757
AC6 = 23153
B1 = 6190
B2 = 4
MB = -32768
MC = -8711
MD = 2868
Calculate true temperature:
UT = 27898 (raw temperature from sensor)
x1 = 4743
x2 = -2343
b5 = 2400
T = 150.00
T = 15.00
Temperature: 15.00 C, 59.00 F
Calculate true pressure:
UP = 23843 (raw pressure from sensor)
b6 = -1600
x1 = 1
x2 = 56
x3 = 57
b3 = 422
x1 = 2809
x2 = 59
x3 = 717
b4 = 33457
b7 = 1171050000
p = 70003
x1 = 74529
x1 = 3454
x2 = -7859
Pressure: 699.64 mbar, 20.66 inHg
Could you post your calibration data, UT and UP.
Leo
askjacob
#20
Jul 26, 2014, 04:03 am Last Edit: Jul 26, 2014, 01:19 pm by askjacob Reason: 1
 ac1 =  8240;
 ac2 = -1128;
 ac3 = -1433;
 ac4 = 33630;
 ac5 = 25458 ;
 ac6 = 18542 ;
 b1  = 6515;
 b2  = 42 ;
 mb  =-32768 ;
 mc  = -11786;
 md  = 2541;
UP= 85170
UT=26199
OK, my values ADDED IN ABOVE. Just to eliminate the chance of i2c corruption, I did a few cold boots and verified these remained unchanged (other of course, than UP and UT). I think these numbers are pretty wild - probably why they are on ebay rather than digikey, making them edge cases for the formula hence why they push the envelope and finding where the gap is.
Incidentally, digging in the Adafruit libaray C file I find this:
Code: [Select]
b3 = (((((int32_t) _bmp085_coeffs.ac1) * 4 + x3) << _bmp085Mode) + 2) >> 2;
Where they cast it as int32_t. Looks like there is something to it. Anyway, let's keep peeling the layers off this onion..
Cheers
Jacob
ehrja
Well I also check the .cpp's adafruit library file and they cast others variables as int32_t or uint32_t in that function ( readPressure)
If I force all as you suggest for b3 the result is similar to the one in the local weather station, similar to the result if i use adafruit example.
If I only change the one for b3 I have a low pressure value, don't remember now but it was like 2XX mbar
I try it on Leonardo and Nano (5v) and it looks the same.
Code: [Select]
AC1 = 9060
AC2 = -1244
AC3 = -14867
AC4 = 33491
AC5 = 25092
AC6 = 15143
B1 = 6515
B2 = 52
MB = -32768
MC = -11786
MD = 2764
Temperature: 27.70 C, 81.86 F
Pressure: 1013.84 mbar, 29.94 inHg
Pressure: 1013.87 mbar, 29.94 inHg
Pressure: 1013.81 mbar, 29.94 inHg
Pressure: 1013.83 mbar, 29.94 inHg
Hola buenos días!
_Leo_
I need your UT and UP readings...
Leo
askjacob
#23
Jul 26, 2014, 01:08 pm Last Edit: Jul 26, 2014, 01:20 pm by askjacob Reason: 1
I added them in in an edit in reply #20. Getting all the values out is a pain, as I only have a 128x64 display, so I have to do a few custom screens/loads with just a basic framework rather than my usual application.
Back then:
UP: 85170
UT: 26199
Now:
UP: 85048
UT: 26341
Cheers
Jacob
_Leo_
Jacob,
I didn't mean you but rather the poster above my requested post  :)
Leo
ehrja
here:
Code: [Select]
AC1 = 9060
AC2 = -1244
AC3 = -14867
AC4 = 33491
AC5 = 25092
AC6 = 15143
B1 = 6515
B2 = 52
MB = -32768
MC = -11786
MD = 2764
Temperature: 34.00 C, 93.20 F
Pressure: 1014.22 mbar, 29.95 inHg
UT: 42153
UP: 337220
Pressure: 1014.27 mbar, 29.95 inHg
UT: 42152
UP: 337218
Pressure: 1014.31 mbar, 29.95 inHg
UT: 42153
UP: 337211
UT: 42152
UP: 337203
Pressure: 1014.26 mbar, 29.95 inHg
UT: 42150
UP: 337189
Temperature: 34.10 C, 93.38 F
UT: 42147
UP: 337184
UT: 42148
UP: 337182
regards
Hola buenos días!
michinyon
Quote
MB = -32768
This number instantly catches the eye as looking suspicious
askjacob
Sure does - especially across 2 devices showing the same issue. I have 4 more sensors here now I can try out and see what the result is.
Strange enough though, once I modified the b3= line, it behaves itself properly - or - well enough. Again, it is more likely why these are on ebay far cheaper on a breakout board than from a reputable supplier in x5000 piece prices... they are probably from the reject bin as even with maxxed out compensation values they could not get them to true spec...
Cheers
Jacob
askjacob
#28
Jul 27, 2014, 02:47 am Last Edit: Jul 27, 2014, 03:05 am by askjacob Reason: 1
Cheers
Jacob
MB = -32768
Looking back - it seems this one is the same across all devices - even _Leo_'s one is the same value - unless he is using ehrja's data. Maybe it is not really a often tweaked value?
Hmm maybe that one is not the smoking gun here! I will hook up some of my other sensors and see.
OK I tried 2 more sensors, same result. Without the modified line, I get almost 500 mbar above the correct reading. They all read within about .2 mbar of each other though which is not bad considering the price...
Oh, and they all read MB = -32768
michinyon
well it is 0x8000 hex  and the biggest -ve number you can have in 16 bit twos-complement numbers.
