Topic: Barometric Presure sensor BMP180 (Read 35388 times) previous topic - next topic
askjacob
:) last thing you want is a "Don't worry I fixed it" post with no follow up. The scourge of the internet search...
_Leo_
#46
Jul 29, 2014, 09:24 am Last Edit: Jul 29, 2014, 10:47 am by _Leo_ Reason: 1
OK, the problem I got myself into is that I neglected to consider that we might all be using different OSS settings.
e.g. I'm using setting "3", the data sheet example uses setting "0". That is why I couldn't understand why I wasn't getting anything useful from your examples.
I've updated the code and would ask that you use this for further analysis:
Code: [Select]
 Bosch Pressure Sensor BMP085 / BMP180 readout routine
 for the Arduino platform.
 Version 1.1
 7/2014
 Compiled by Leo Nutz
 www.ALTDuino.de
#include <Wire.h>
#define ADDRESS_SENSOR 0x77                 // Sensor address
int16_t  ac1, ac2, ac3, b1, b2, mb, mc, md; // Store sensor PROM values from BMP180
uint16_t ac4, ac5, ac6;                     // Store sensor PROM values from BMP180
// Ultra Low Power       OSS = 0, OSD =  5ms
// Standard              OSS = 1, OSD =  8ms
// High                  OSS = 2, OSD = 14ms
// Ultra High Resolution OSS = 3, OSD = 26ms
const uint8_t oss = 3;                      // Set oversampling setting
     uint8_t osd;                          // Corresponding oversampling delay
float T, P;                                 // Set global variables for temperature and pressure
 Wire.begin();                             // Activate I2C
 Serial.begin(9600);                       // Set up serial port
 Serial.println("");
 Serial.print("Oversampling setting (oss) = "); Serial.println(oss);
      if(oss == 0 ) osd =  5;
 else if(oss == 1 ) osd =  8;
 else if(oss == 2 ) osd = 14;
 else if(oss == 3 ) osd = 26;
 else { Serial.print("Incorrect OSS value defined!"); while(1){} }
 init_SENSOR();                            // Initialize baro sensor variables
 delay(100);
 int32_t b5;
 b5 = temperature();                       // Read and calculate temperature (T)
 Serial.print("Temperature: ");
 Serial.print(T, 2);
 Serial.print(" C, ");
 Serial.print(1.8 * T + 32.0, 2);
 Serial.println(" F");
 P = pressure(b5);                         // Read and calculate pressure (P)
 Serial.print("Pressure: ");
 Serial.print(P, 2);
 Serial.print(" mbar, ");
 Serial.print(P * 0.0295299830714, 2);
 Serial.println(" inHg");
 if(P < 300 || P > 1100) Serial.println("Pressure sensor reading out of range!!!!"); // Pressure range according to the data sheet
 float alt = (pow(1013.25 / P, 0.190223f) - 1.0f) * 44330.08f;                       // Use static SI standard temperature (15°C)
 Serial.print("Altitude: "); Serial.print(alt); Serial.print(" m, "); Serial.print(alt * 3.28084); Serial.println(" ft");
 Serial.println("-----------------------------------------");
 delay(500);                               // Delay between each readout
 Initialize sensor variables
void init_SENSOR()
 ac1 = read_2_bytes(0xAA);
 ac2 = read_2_bytes(0xAC);
 ac3 = read_2_bytes(0xAE);
 ac4 = read_2_bytes(0xB0);
 ac5 = read_2_bytes(0xB2);
 ac6 = read_2_bytes(0xB4);
 b1  = read_2_bytes(0xB6);
 b2  = read_2_bytes(0xB8);
 mb  = read_2_bytes(0xBA);
 mc  = read_2_bytes(0xBC);
 md  = read_2_bytes(0xBE);
 Serial.println("");
 Serial.println("Sensor calibration data:");
 Serial.print(F("ac1 = ")); Serial.print(ac1); Serial.println(F(";"));
 Serial.print(F("ac2 = ")); Serial.print(ac2); Serial.println(F(";"));
 Serial.print(F("ac3 = ")); Serial.print(ac3); Serial.println(F(";"));
 Serial.print(F("ac4 = ")); Serial.print(ac4); Serial.println(F(";"));
 Serial.print(F("ac5 = ")); Serial.print(ac5); Serial.println(F(";"));
 Serial.print(F("ac6 = ")); Serial.print(ac6); Serial.println(F(";"));
 Serial.print(F(" b1 = ")); Serial.print(b1);  Serial.println(F(";"));
 Serial.print(F(" b2 = ")); Serial.print(b2);  Serial.println(F(";"));
 Serial.print(F(" mb = ")); Serial.print(mb);  Serial.println(F(";"));
 Serial.print(F(" mc = ")); Serial.print(mc);  Serial.println(F(";"));
 Serial.print(F(" md = ")); Serial.print(md);  Serial.println(F(";"));
 Serial.println("----------------");
 Calcualte pressure readings
float pressure(int32_t b5)
 int32_t x1, x2, x3, b3, b6, p, UP;
 uint32_t b4, b7;
 UP = read_pressure();                         // Read raw pressure
 Serial.print(F("UP = ")); Serial.print(UP); Serial.println(F(";"));
 b6 = b5 - 4000;
 x1 = (b2 * (b6 * b6 >> 12)) >> 11;
 x2 = ac2 * b6 >> 11;
 x3 = x1 + x2;
 b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2;
 x1 = ac3 * b6 >> 13;
 x2 = (b1 * (b6 * b6 >> 12)) >> 16;
 x3 = ((x1 + x2) + 2) >> 2;
 b4 = (ac4 * (uint32_t)(x3 + 32768)) >> 15;
 b7 = ((uint32_t)UP - b3) * (50000 >> oss);
 if(b7 < 0x80000000) { p = (b7 << 1) / b4; } else { p = (b7 / b4) << 1; } // or p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
 x1 = (p >> 8) * (p >> 8);
 x1 = (x1 * 3038) >> 16;
 x2 = (-7357 * p) >> 16;
 return (p + ((x1 + x2 + 3791) >> 4)) / 100.0f; // Return pressure in mbar
 Read uncompensated temperature
int32_t temperature()
 int32_t x1, x2, b5, UT;
 Wire.beginTransmission(ADDRESS_SENSOR); // Start transmission to device
 Wire.write(0xf4);                       // Sends register address
 Wire.write(0x2e);                       // Write data
 Wire.endTransmission();                 // End transmission
 delay(5);                               // Datasheet suggests 4.5 ms
 UT = read_2_bytes(0xf6);                // Read uncompensated TEMPERATURE value
 Serial.print(F("UT = ")); Serial.print(UT); Serial.println(F(";"));
 // Calculate true temperature
 x1 = (UT - (int32_t)ac6) * (int32_t)ac5 >> 15;
 x2 = ((int32_t)mc << 11) / (x1 + (int32_t)md);
 b5 = x1 + x2;
 T  = (b5 + 8) >> 4;
 T = T / 10.0;                           // Temperature in celsius
 return b5;
 Read uncompensated pressure value
int32_t read_pressure()
 int32_t value;
 Wire.write(0xf4);                         // Sends register address to read from
 Wire.write(0x34 + (oss << 6));            // Write data
 Wire.endTransmission();                   // SEd transmission
 delay(osd);                               // Oversampling setting delay
 Wire.write(0xf6);                         // Register to read
 Wire.requestFrom(ADDRESS_SENSOR, 3);      // Request three bytes
 if(Wire.available() >= 3)
   value = (((int32_t)Wire.read() << 16) | ((int32_t)Wire.read() << 8) | ((int32_t)Wire.read())) >> (8 - oss);
 return value;                             // Return value
 Read 1 byte from the BMP sensor
uint8_t read_1_byte(uint8_t code)
 uint8_t value;
 Wire.write(code);                               // Sends register address to read from
 Wire.requestFrom(ADDRESS_SENSOR, 1);            // Request data for 1 byte to be read
 if(Wire.available() >= 1)
   value = Wire.read();                          // Get 1 byte of data
 Read 2 bytes from the BMP sensor
uint16_t read_2_bytes(uint8_t code)
 uint16_t value;
 Wire.requestFrom(ADDRESS_SENSOR, 2);            // Request 2 bytes from device
 if(Wire.available() >= 2)
   value = (Wire.read() << 8) | Wire.read();     // Get 2 bytes of data
Here is an example of my test using a UNO R3 and BMP180:
Oversampling setting (oss) = 3
ac1 = 6759;
ac2 = -1131;
ac3 = -14633;
ac4 = 33667;
ac5 = 24876;
ac6 = 20348;
b1 = 6515;
b2 = 42;
mb = -32768;
mc = -11786;
md = 2895;
UT = 28666;
Temperature: 23.10 C, 73.58 F
UP = 317365;
Pressure: 971.93 mbar, 28.70 inHg
Altitude: 352.49 m, 1156.45 ft
I practically get the same readings using oss 0 thru 3.
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
ehrja
Out of range!:
Code: [Select]
ac1 = 9060;
ac2 = -1244;
ac3 = -14867;
ac4 = 33491;
ac5 = 25092;
ac6 = 15143;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2764;
UT = 24706;
Temperature: 30.80 C, 87.44 F
UP = 339901;
Pressure: 1512.55 mbar, 44.67 inHg
Altitude: -3252.86 m, -10672.13 ft
  :smiley-roll-sweat:
Hola buenos días!
_Leo_
Please also try oss = 0, 1 and 2 by changing this line:
Leo
ehrja
case 3:
Code: [Select]
ac1 = 9060;
ac2 = -1244;
ac3 = -14867;
ac4 = 33491;
ac5 = 25092;
ac6 = 15143;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2764;
UT = 24691;
Temperature: 30.70 C, 87.26 F
UP = 339951;
Pressure: 1512.45 mbar, 44.66 inHg
Altitude: -3252.35 m, -10670.43 ft
case 2:
Code: [Select]
Oversampling setting (oss) = 2
ac1 = 9060;
ac2 = -1244;
ac3 = -14867;
ac4 = 33491;
ac5 = 25092;
ac6 = 15143;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2764;
UT = 24738;
Temperature: 31.00 C, 87.80 F
UP = 169871;
Pressure: 1512.73 mbar, 44.67 inHg
Altitude: -3253.79 m, -10675.18 ft
case 1:
Code: [Select]
Oversampling setting (oss) = 1
ac1 = 9060;
ac2 = -1244;
ac3 = -14867;
ac4 = 33491;
ac5 = 25092;
ac6 = 15143;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2764;
UT = 24690;
UP = 84990;
Pressure: 1512.43 mbar, 44.66 inHg
Altitude: -3252.24 m, -10670.09 ft
case 0:
Code: [Select]
Oversampling setting (oss) = 0
ac1 = 9060;
ac2 = -1244;
ac3 = -14867;
ac4 = 33491;
ac5 = 25092;
ac6 = 15143;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2764;
UT = 24696;
UP = 42494;
Pressure: 1512.57 mbar, 44.67 inHg
Altitude: -3252.97 m, -10672.46 ft
Hola buenos días!
_Leo_
OK, all show the same results.
Please try this by replacing
Code: [Select]
b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2; // as per data sheet
with
Code: [Select]
// b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2; // as per data sheet
int32_t b3_tmp = ac1; // Split up the equation...
b3_tmp = (b3_tmp * 4 + x3) << oss;
b3     = (b3_tmp + 2) / 4;
and run all 4 oss values.
Leo
ehrja
OK
case 0:
Code: [Select]
UT = 24677;
Temperature: 30.60 C, 87.08 F
UP = 42502;
Pressure: 1014.90 mbar, 29.97 inHg
Altitude: -13.72 m, -45.01 ft
case 1:
Code: [Select]
UT = 24740;
UP = 84929;
Pressure: 1014.88 mbar, 29.97 inHg
Altitude: -13.55 m, -44.47 ft
case 2:
Code: [Select]
UT = 24760;
Temperature: 31.10 C, 87.98 F
UP = 169818;
Pressure: 1014.92 mbar, 29.97 inHg
Altitude: -13.89 m, -45.56 ft
case 3:
Code: [Select]
UT = 24776;
Temperature: 31.20 C, 88.16 F
UP = 339559;
Pressure: 1014.91 mbar, 29.97 inHg
Altitude: -13.80 m, -45.29 ft
XD
Hola buenos días!
michinyon
That looks OK.
Didn't you figure out yesterday,   you need to correct the type casting in that line of the program ?
michinyon
Your problem is,  -14657 x 4 + x3 << 3
will be evaluated on the arduino as a 16 bit number,   and it will overflow.   That is your problem,  right there.   You need to force that calculation to be done as a 32 bit int,   before you get to the bit where it overflows,   not afterwards.
michinyon
You can see right there on the Bosch datasheet,   where they refer to all their 16 bit numbers as "shorts".
Nobody discussing the arduino ever mentions "short".    Ints on the arduino are "short".
The only people who ever explicitly talk about "short" ints,   are the people who are thinking that an int is 4 bytes,  because that's the devices they use.
_Leo_
Jakob, would nice if you could do the same tests  :)
Leo
_Leo_
After taking into account the pointers given by "michinyon" and doing numerous tests here the latest version:
Code: [Select]
  Bosch Pressure Sensor BMP085 / BMP180 library free
  readout routine for the Arduino platform.
  Version 1.2  7/2014
  www.ALTDuino.de
#include <Wire.h>
uint8_t osd;                                // Oversampling delay
// Hardware pressure sampling accuracy modes:
// Standard              OSS = 1
// High                  OSS = 2
const uint8_t oss = 3;                      // Set oversampling accuracy mode here
  Serial.println("");
       if(oss == 0 ) osd =  5; // Ultra Low Power       OSD =  5ms
  else if(oss == 1 ) osd =  8; // Standard              OSD =  8ms
  else if(oss == 2 ) osd = 14; // High                  OSD = 14ms
  else if(oss == 3 ) osd = 26; // Ultra High Resolution OSD = 26ms
  delay(100);
  int32_t b5;
  Serial.print(T, 2);
  Serial.print(P, 2);
void init_SENSOR()
  Serial.println("");
  uint32_t b4, b7;
  b6 = b5 - 4000;
  x3 = x1 + x2;
  int32_t b3_tmp = ac1;                          // Improved b3 calculation which also uses less program code.
  b3     = (b3_tmp + 2) >> 2;
  x1 = (UT - ac6) * ac5 >> 15;
  x2 = ((int32_t)mc << 11) / (x1 + md);
  b5 = x1 + x2;
  T  = (b5 + 8) >> 4;
  return b5;
  int32_t value;
  uint8_t value;
  uint16_t value;
Leo
michinyon
diego3vsan
hallo.
first I have to say thankyou to all of you for so nice and accurate code.
now...
I'm using Arduino Due with "your" code, the last posted by Jacob, I think I have some calibration problem here.
Todays local pressure is 1021 but the sensor is reading 1018mb.
Altiture is about +40m above sea level but sensor giving me -41m.
Same result regardless OSS (0,1,2,3).
here the result I have:
ac1 = 8180;
ac2 = -1252;
ac3 = -14376;
ac4 = 33262;
ac5 = 25253;
ac6 = 19971;
b1 = 6515;
b2 = 52;
mb = -32768;
mc = -11786;
md = 2666;
UT = 28643;
Temperature: 25.60 C, 78.08 F
UP = 41993;
Pressure: 1018.23 mbar, 30.07 inHg
Altitude: -41.32 m, -135.58 ft
UT = 28642;
UP = 41996;
Pressure: 1018.26 mbar, 30.07 inHg
Altitude: -41.57 m, -136.39 ft
UT = 28644;
UP = 41995;
Pressure: 1018.29 mbar, 30.07 inHg
Altitude: -41.82 m, -137.21 ft
Any suggestion please?
thankyou
diego
robtillaart
I suspect the math in the code overflows due to intermediate results, resulting in incorrect sign.
not checked
Change the integer types from int to long or float   (16 bit to 32 bit)
give it a try
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
