Topic: Using Arduino to access a hard drive wirelessly, how to...? (Read 4379 times) previous topic - next topic
MattTuck
Is it possible to use Arduino and a BT shield to store files on a external hard drive?
michinyon
If you can build a sata interface on your shield,  why not ?
It is certainly possible,   whether it is practical to try and implement,  I don't know.
An arduino is going to have trouble providing and receiving  the data at the rate that a hard disk will accept.   I don't know how slow it is possible to run them.
GoForSmoke
An Arduino with BT and USB host capability might run an external HD with USB interface.
I guess it would be cheating to stick a BT dongle on a laptop and use that run the HD?  :D
Sorry, best I've done is SD.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
Grumpy_Mike
I would say no.
You would need to have a Bluetooth interface to the HD do you have that?
If not then something like the HD running off a Raspberry Pi with a BT dongle might work.
raschemmel
#4
Jul 19, 2014, 08:20 am Last Edit: Jul 19, 2014, 08:42 am by raschemmel Reason: 1
Not for you
Did you see any Bluetooth HDs on Sparkfun or Adafruit ?
Why?
If they can't do it what chance do you think you have if you are asking if it is possible?
Does that sound like a question someone would ask  if they hzd more expertise than Spafkfun or Adafruit?
It is a completely reasonable and fair question. Unfortunately the answer is no if it is not available as a product right now. If you can find
it then you'll have your answer.
I know someone who could do it in 10 minutes or less:  Cloe O'Bryan.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
GoForSmoke
I actually have USB HD adapters. Got mine through Geeks.Com but Tiger Direct sells them too.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&srkey=usb%20hard%20drive%20adapter
That might put HD within reach of a Mega ADK...
Robin2
Think how much overhead the SD card library adds to an Arduino - and it can only work with 8.3 filenames and other restrictions.
For all practical purposes there is no way an Arduino (apart from a Yun perhaps) could access a hard disk.
And what would be the point. You can easily get multi-gigabyte SD Cards. What possible use could  an Arduino with 0.000 002 GB of SRAM be to a 500GB hard disk - or vice versa.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
GoForSmoke
SD cards have an MCU that supports DOS FAT is why Arduino only uses DOS FAT with them.
It's more a matter of access speed and bus.
I did run IDE on 4 to 10 MHz 8088's once we got IDE drives. Speed doesn't *have* to be incredible.
You can USB an HD, the drive electronics handles the buffering. It's probably simpler than it used to be.
The thing is that it just seems like a waste to hook an AVR to an HD, like putting a sidecar on a moped.
A Due, Yun or Galileo is justified.
raschemmel
Don't you need a USB HOST  shield to run a HD fron an arduino ?
Was it an ALTAIR 8800 ?
PeterH
Is it important that you access the hard drive directly? As soon as you introduce a PC between the Arduino and the hard drive, the problem becomes much simpler to solve. If you can find/write an Arduino NFS or SMB client, it would also be easy to add a network interface and access network attached storage, windows file shares, NFS shared drives etc.
Robin2
... and DOS FAT is simple compared to NTFS or EXT3 or whatever system is now used on hard disks.
...R
GoForSmoke
You do if you're going to 'face the HD through a USB adapter!
Altair ran 8080. He did call that the 8800, didn't he? Almost the first commercial PC?
Isn't that the first company that Gates took down? I'd say rightfully so but it's the first time I know of where someone else did most of the work and Bill got most of the money (because the lawyer was hired by his father).
Well, okay, the lawyer may have gotten most of the money but the talent got the least. And I forget that guy's name so see how that works, I don't curse his name at least once a year.
The 8088's for me started in Jan 1986 when the IBM clones and clone parts hit the fests.
The difference between doing your own tech and not was spending less than half sticker price or not.
GoForSmoke
...R
Believe it or not, you can format a drive however you like and use it on most PC operating systems.
I have a media player that uses FAT32. The same drive with USB adapter works on my PC.
I did mention that putting a hard drive on an AVR does not make sense?
It may be possible, but why bother? A server should have more RAM than the controller board!
raschemmel
Quote
Ok, I don't get it. How do you do that ? [Arduino]<===>[server]
Can you show a block diagram that includes all the required components between the two ?
I assume the idea you are describing revolves around an Ethernet Shield . Is that correct ? (or are there other components rquired ?)
GoForSmoke
Possibly a Mega ADK which has USB host built in, a USB HD adapter and a hard drive.
Adapters just available at Tiger Direct above. I have one, but from Geeks. they work. $20 + shipping.
You don't believe that hard drives can no longer run FAT do you?
Did I mention it would be slower than with a PC? Or that it wouldn't make sense? Pretty sure I did.
